Does anyone know if American Racing Baja's in a 16x8 will fit on a Tundra without a lift. I have read about the brake calipers interfering with certain rims. Also, would installing these rims on the stock tires cause additional vibration?
Originally posted by pghpp74 Does anyone know if American Racing Baja's in a 16x8 will fit on a Tundra without a lift. I have read about the brake calipers interfering with certain rims. Also, would installing these rims on the stock tires cause additional vibration?
You need to check the specs on back spacing and offset to see how they match up against the stock wheels. That will determine if they fit properly. The vibration issues are not caused by adding different rims. In general, the vibration problems arise when wheel/tire combinations are not balanced properly and/or possible worn suspension components.
John
The Toy: 2000 Tundra 4.7L TRD Limited 4x4 Red Pearl (23.0k Original Miles)
The mod list is long. Check some pics in my gallery for mod detail.
No, they will not fit!!!! I just went through this about a month ago and those were the wheels I wanted. It won't clear the brake caliper in the front.
hockeyfreak
"If your not obsessing about something, you're probably not into it enough." - Chris Thile
2001 Tundra Limited *SOLD*
2005 Ford Excursion Limited PSD
1996 Ford F-250...Runnin' on Veggie Oil
1946 John Deere A
MODS: Hellwig, Custom Duals w/ Flowmaster 40 Series and Dr. Gas X-pipe, Daystar Bushings, Cornfed 2" Front Spacers, TRD AAL, K&N FIPK, 16x8 Weld Outbacks, 285/75R16 Yokohama Geolandar's, Access Cover, BedRug, Putco Bed Rails, PP Bull Bar, WeatherFlectors, Prodigy Brake Controller, Brown Bread Sound Deadener, '05 Taillights, AMSOIL ATF
