Tires and Wheels Discussions and experienced advice about tires, wheels, traction control, proper balancing, improving tire life and more.
This is a discussion thread titled "Installed 2.5" Cornfed Lift - Re-alignment Results", within the Tires and Wheels forum, part of the Technical & Vehicle Assistance Forums category.
Old 06-01-2004, 06:46 PM
imjin's Avatar
Defiant ut Terminus
Dealer : McGeorge Toyota
imjin's Photo Albums
Last Online: Yesterday 03:20 PM
imjin will become famous soon enough.
Default Installed 2.5" Cornfed Lift - Re-alignment Results
Here's some data for those getting ready to install a Cornfed 2.5" front lift spacer and a 1.25" rear block. As far as I know, my alignment was in pretty good shape prior to the lift, or at least it felt like it. It's interesting how much out of whack the alignment can get with this small of a lift. It really threw the toe off.
http://www.tundrasolutions.com/photo...cat/500/page/1
Mods: Mickey Thompson Classic II | Cornfed 2.5" Lift | Differential Drop Spacers | 930 Inner CV Boots | ProtechEZLift Limit Straps | Spintech Sportsman XL Muffler | Brembo Front Brake Rotors | A.R.E. Z-Series Cap w/ Thule Rack | Stubbs Rock Sliders | Hellwig Anti-Sway Bar | 285/75/16 BFG All Terrain TA KO's | VIAIR 400C Air Compressor w/ 2.5 gal tank | Front clear corner lamps | Odyssey PC1700T battery | Optima Red Top 75/35 battery (backup starter) | Hellroaring 95300A Isolator/Combiner | Truspeed Calibrator
Old 06-01-2004, 07:46 PM
DJ DJ is offline
Dealer : Fowler Toyota
2001 Toyota Sequoia,
DJ's Photo Albums
DJ will become famous soon enough.
Total toe is fine, but caster is really bad. I suggest you read DJ's Alignment Setting Recommendations and then have it aligned again.
Old 06-01-2004, 10:01 PM
imjin's Avatar
Defiant ut Terminus
Question
Where do the shops get that specified range for total cross caster of -0.5 to 0.5? Was that a Toyota issued spec? I read your link on alignment (DJ's Alignment Setting Recommendations) and have a much better understanding of it, but I know next to nothing about alignment, so forgive my inquiries if they seem challenging... I'm just trying to figure out what's what. When you said in it that the Toyota "in spec" caster value of a 1/2 a degree is unstable, I understand the steering axis could be pitched too far in either direction, but could a lesser caster value be OK in some cases, or is my cross caster value of -0.3 way too low? Should I be able to tell, just by the way the steering feels, if it's pitched too far and the oscillation effect takes place that you mentioned?
Old 06-01-2004, 10:22 PM
DJ DJ is offline
DJ's Photo Albums
The Toyota Repair Manual lists specs for camber, caster, SAI, and total toe. It does not list a spec for cross caster.
The problem with your alignment is not cross caster (i.e. the difference between left and right caster), it is low caster at both the left and right wheels.
There is no way to predict whether or not your truck will vibrate due to steering instability with the caster settings it now has. What can be predicted is that it is much more likely to vibrate with its low caster settings than it would if caster were higher, and it is likely to be sensitive to ruts in the road, to wind drift, and to "wander", meaning you have to pay careful attention just to keep it going straight down the road.
I suspect you would notice the problem quite well if you had it aligned to my specs. Been there, done that.
Old 06-01-2004, 11:22 PM
imjin's Avatar
Defiant ut Terminus
Ah, I see now. Thanks for the explanation.
