Old 09-08-2004, 03:09 PM
scavoj's Avatar
Lifetime Subscriber
Dealer : Bohn Brothers Toyota
2004 Toyota Tundra 4x4 Double Cab,
2001 Toyota Sequoia 4x4
scavoj is on a distinguished road.
scavoj's Photo Albums
Default Increasing Tire Size and effect on electronics
I have a couple of questions regarding the change from the stock 265 70R16 to 75R16s on an 04 DC Tundra. Is there a way to correct the spedo reading (and therefore the ODO)? Also, does anyone know if there would be any effect on the VSC and TRAC system?
Joe
2004 Tundra Double Cab 4X4 Limited
Phantom Gray Pearl
TRD Off Road Pkg
Towing Pkg
VSC + TRAC, Break Assist, Auto LSD
Crome Tube Step Bars
All Weather Guard Pkg
6 CD In-Dash Changer w/Rear Audio Controls
A.R.E. Z-Series Cap
Line-X
Warn Trans4mer w/Hitch Receiver & Brush Guard
Warn 9.5ti Multi-Mount Portable Winch
Warn SDB-160 Driving/Spot Lights
Warn Rear Quick Connect Power cable
PIAA 1500 Back Up Lamps
Stant 10509 Locking Gas Cap
Old 09-08-2004, 03:41 PM
Last Online: 04-20-2009 11:13 AM
Emmette is on a distinguished road.
Emmette's Photo Albums
Default Change in tire size and ODO
I ran into the speedo problem when I bought my used Tundra with 75s instead of the normal 70s. When I was stopped for speeding, the officer had me going 5 mph more than my speedo read. I had my wife pace me in our Toyota van and confirmed that my speedo readout was 5 mph too low. I checked with the dealer, and they told me Toyota has a margin of error of up to 7mph, so they could not (or would not) recalibrate the speedo.
Old 09-08-2004, 04:02 PM
maisano's Avatar
Dealer : Freeman Toyota
2006 Toyota Tundra DC 4X4,
2007 Toyota Sienna
Last Online: 10-30-2009 04:29 PM
maisano is on a distinguished road.
Send a message via AIM to maisano Send a message via Yahoo to maisano maisano's Photo Albums
Default try this
http://www.miata.net/garage/tirecalc.html
i got this site from okctundra this has good info on it.
Old 09-09-2004, 08:41 AM
scavoj's Avatar
Lifetime Subscriber
Yea, this is the best tire size calcualtor I've seen. I found it probably about a year ago. It's been in my favorites since then. Thanks.
Originally Posted by Emmette
... I checked with the dealer, and they told me Toyota has a margin of error of up to 7mph, so they could not (or would not) recalibrate the speedo.
7mph !!! That seems pretty high. Thanks for the reply.
Does anyone know if the increased tire size will affect the VSC and Active-TRAC systems?
I'm going to call Toyota...but I'm probably going to get the same response I always get from them..."We don't recommend making any modifications to our vehicles"
Joe
Phantom Gray Pearl
TRD Off Road Pkg
Towing Pkg
A.R.E. Z-Series Cap
Line-X
Old 09-10-2004, 01:59 PM
toyotafreak's Avatar
Dealer : Quality Toyota Scion
2003 Toyota Sequoia
Last Online: 07-06-2009 08:56 AM
toyotafreak is on a distinguished road.
toyotafreak's Photo Albums
Default The speedo tells me we've got too much tire
Joe, this is in keeping with the thread title, but not with your question. The TS archives are friggin huge, which is a great thing, but I haven't made the time to get through all of it.
I've spent a significant amount of time bouncing indicated speed/odometry against GPS, and what I've found is that the OEM 265/65-17 Dunlops at recommended pressure yield an error of 4.7%. This is not based on a small or single sample, and is very repeatable. (Btw, if you reset the AVG MPH every tank, subtract 0.9 MPG for truth - anything beyond one tank the accuracy drops even further). So what am I getting at?...in terms of how the speedo is calibrated from the factory, their choice of tires is 4.5% too large.
I guess my crackpot head has had this wrong for a long time. The 1.047 figure I mentioned is the number I have to multiply the odometer reading by to derive true mileage. My problem is that I've always thought the OEM tires' diameter was too small, when in reality they're too big. 4.5% too big. A tire 4.5% too big requires a 1.047 odometer increase to show true miles traveled. A tire 4.5% too big also requires you to add 4.7% to your indicated MPH to find how fast you're really traveling. Not rocket science, but big for me cuz I've had the wrong idea the whole time, AND the wheel wells are empty enough, AND the highway RPMs are too high for decent mileage (not towing's concern either - that's what OD OFF is for).
Toyota original equipment:
Tire_________Diam____Circ________Error__________No tes_________
245/70-16----29.50----92.69----1.1% too big----SR5 Standard 2WD
265/70-16----30.61----96.15----4.6% too big----SR5 Standard 4WD
265/65-17----30.56----96.02----4.5% too big----OEM Upgrade 2WD & 4WD
275/45-20----29.74----93.44----1.9% too big----TRD wheelset
Next, I solved for zero error, which becomes 29.2" diameter and 91.72" circumference. Here's some other fictional sizes that zero out the speedo error (I specified aspect ratio and wheel size and let Excel determine tread width):
Tire_________Diam____Circ_____Error
238/65-17----29.20----91.72----0.0%
258/60-17----29.19----91.71----0.0%
281/55-17----29.18----91.67----0.0%
260/45-20----29.20----91.73----0.0%
292/40-20----29.19----91.71----0.0%
And finally, where real tire sizes fit:
Tire_________Diam_____Circ_____Error___________Not es
265/60-17----29.52----92.74----1.1% too big
265/65-17----30.56----96.02----4.5% too big----Upgraded 2WD & 4WD
275/55-17----28.91----90.82----1.0% too small
265/45-20----29.39----92.33----0.7% too big
285/40-20----28.98----91.03----0.7% too small
The whole problem with this now is that highway rpm and gas mileage would have to rise, although braking and acceleration would probably improve (maybe TRD's onto something here, as theirs splits the difference between speedo cal and the OEM 17's - probably results in a sportier feel).
So what now? I saw a 275/55-20 on a Sequoia at lunch and it looked real healthy. Fender looked pretty full. Wonder if he knows his speedo's off 8.5%. Can we pay to have a technican reprogram the truck's CPU ("need to drop the indications 8.5%".) In that case, we'd get accurate speedo/ODO indications while effectively changing our final drive ratio to a more highway-happy number.
Is it safe to assume that larger tires than stock result in better highway mileage, better tire wear, worse city mileage and worse braking?
2003 TOYOTA Sequoia SR5: 89K, TRD cat-back, fueled by Chevron; M1 oil/filter
2000 TOYOTA Epic S22: Powered by Lexus 1UZ w/VVTi, Chevron/M1
1995 TOYOTA Hilux: 206K, any gas, any filter, first 100K Castrol Syntec, GTX since
Last edited by toyotafreak; 09-10-2004 at 07:34 PM. Reason: originally got the error backwards ;-(
Old 09-29-2004, 07:04 PM
Thwarter's Avatar
Dealer : Piercey Toyota Scion
2002 Toyota Tundra
Last Online: 08-23-2009 09:24 PM
Thwarter is on a distinguished road.
Thwarter's Photo Albums
I had the same question now that I'm getting ready to replace my stock BFG Rugged Trails (265/70-16) with Michelin LTX M/S (LT265/75-16). While I didn't really like the BFG's (too slippery/squeally), I have about 38,500 miles on them so I can't complain about durability.
I think the real reason Toyota (or any other mfg for that matter) doesn't want people to modify the speedometer reading for different size tires is that some people may change it just to lower the mileage being counted on the odometer, regardless of what tire size they have.
Like others have said - when you get larger tires, you are in fact reducing the mileage that your odometer/speedometer registers. According to the specs for the above tires, the revolutions per mile goes down from 680 to 652. Technically this could raise the vehicle re-sale value a bit since the mileage shown on the odometer would be less than the true mileage the truck travelled.
It may only be 3.24%, but that's an extra 3,240 miles your truck really travelled for every 100,000 miles shown on the odometer. Another way of looking at it is when your speedometer says your travelling at 65 mph, you're really going 67.2 mph.
I went through this before when I had two different sized sets of tires for my 4Runner. I made a little sticky note with two columns: "Speedometer Reading" and "True Speed" and filled in half-a-dozen values to remind me I'm going faster than what the speedo says when I had the larger tires on the truck.
People should also factor this in when planning routine vehicle maintenance which is usually scheduled by mileage.
Old 09-30-2004, 12:15 AM
TMS2U's Avatar
Moderator
Dealer : Longo Toyota
Last Online: 10-01-2009 03:29 PM
TMS2U is on a distinguished road.
TMS2U's Photo Albums
With 4.88 gears and 35's my speedo runs 10% over actuall mph. I got a Dakota Digital unit to correct this. Haven't done the install yet tho
Old 10-01-2004, 10:51 AM
JeffD's Avatar
Last Online: 04-23-2007 11:02 AM
JeffD is on a distinguished road.
JeffD's Photo Albums
When I was running 33's I installed a speedo recalibrator and raised the speedo about 8% to get an accurate reading via gps. I don't remember what brand I got (it was not dakota) my only complaint was that the speedometer didn't move as smoothly as it did stock, it seemed to only move in .5 second increments.
2000 4x4 LTD AC Sunfire Red - Sold w/ 200K
2005 4x4 LTD AC Phantom grey w/ dark grey - Sold w/ 20K
Alpine CDA-9835, W/ KCA-420i, Focal 165KP front, Focal 165V Rear speakers. powered by 2 MMats SQ2150 amps. Alpine MRD-M501 powering a JL Stealthbox with Infinity Perfect 10D VQ
Sound deadened everything with Cascade VB2HD, and Dynamat Extreme
2005 G35 Sedan 6MT - Returned due to paint work on a 'new' car.
2006 G35 Sedan 6MT - all stock. Where do I hook up the trailer and where's the bass?
