Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Tires and Wheels
Old 09-29-2004, 12:24 PM
auslandt's Avatar
Dealer : Classic Toyota Scion of Round Rock
2004 Toyota Tundra,
2008 Toyota Sequoia
Last Online: 11-16-2009 06:10 PM
Images: 5
auslandt is on a distinguished road.
Send a message via AIM to auslandt Send a message via Yahoo to auslandt auslandt's Photo Albums
Question New car / Bad Alignmnet? Or maybe not!
I just bought a 2004 Tundra DC (just means 3 months or so). It has less than 3000 miles but it's front tires showed excessive strange wear. The ouside of both front tires were feathered. Looking down on the tread from the top, the rear of the lug was lower than the front of the lug and the front edge was lipped up.
Also it had pulled ever so slightly to the right ever since I bought it. I just thought it was the slope of the road, but after the funny tire wear, I was convinced it had an alignment problem.
I took this to the Toyota Dealer I bought it from to have the alighnment checked, and to get its first oil change.
Well it turns out the alignment was dead on, but the tire pressure was 20 FL, 22 FR, and 26 RL and RR. The low tire pressure and 2 lb difference between front L and R was enough to simulate a bad toe in alignment problem.
Well aired up to 30/32 and she runs beautifully.
The service tech said the bad pressure was likley that way from the factory. They [toyota dealer] used to do a presales check of the entire vehicle and would have caught and corrected this issue. However, she said that recently Toyota [Company I guess] does not allow them to do this final checkup... and hence my issue.
Has anyone heard of this? I am curious who is responsible for proper tire pressure upon delivery. The wear on the tires was significant enough to see a lot of wear in under 3K miles. I am going to measure the wear, but I am guessing I have lost 15-20% of my tread. If true, shouldn't Toyota be on the hook for tire replacement?
- Matt
"A good friend will come and bail you out of jail...
but, a true friend will be sitting next to you saying, "Darn...that was fun!"
Old 09-29-2004, 02:30 PM
osteon.618's Avatar
Dealer : Toyota of New Orleans
2004 Toyota Tundra,
2004 Toyota Sequoia
Last Online: 12-04-2006 06:55 PM
osteon.618 is on a distinguished road.
osteon.618's Photo Albums
I purchased what looks like the same truck as you except an AC. I have 800 miles and it has pulled ever so slightly to the right. Its not a big deal but it has been nagging me. I'll certainly check mine out and let you know.
2004 Sequoia Limited - black / leather / sunroof / signal mirror / skid plate / tow package / running boards / rear spoiler /6 CD changer / DVD pre-wire
Mods - none
2004 Tundra Access Cab SR5 2WD - phantom gray / charcoal leather / night vision mirror / captains chairs / RS3200+ security / tow package / LSD / 17" wheels / stainless running boards
Mods - XM radio custom install / map light mod / Line-X / bed extender / arm rest mod / TRD 4x4 coilover leveling....
All lessons are repeated until learned.
Old 09-29-2004, 03:52 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
Matt,
The guy looking at you from your mirror every morning is the guy responsible for everything about your truck.
You really do get what you inspect, not what you expect.
Sure, the dealer's service was shoddy, and I think the story you were told was a CYA lie. Nevertheless, you own the truck and you are responsible. Buy a tire pressure gauge and check your inflation pressure at least monthly. I like 35 psi in the fronts and 32 in the rears, and you'll get lots of opinions on the best tire pressure.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
Old 09-29-2004, 04:39 PM
auslandt's Avatar
2004 Toyota Tundra,
2008 Toyota Sequoia
Images: 5
Originally Posted by KLS
Matt,
Yeah I know...
Maintained many a cars. Never trusted shop work. Always did it myself. This was one of the rareities. Left the dealer pulling slightly, never changed, tires got wear, I automatically jumped to the "alignment" conclusion.
My bad. Just hoped to curb others bads...
And although I am responsible for my vehicle, I would expect any new car to be 100%, without maintenance, up to the first oil change.
- Matt
Old 09-29-2004, 08:59 PM
osteon.618's Avatar
2004 Toyota Tundra,
2004 Toyota Sequoia
Just FYI, checked my pressures:
FR=27.5
FL=28.5
BR=28
BL=28
This is the 265/65/17 Dunlops 2 weeks out from purchase. I will also air up to 30 front and 32 rear. Thanks.
Mods - none
Old 09-30-2004, 09:36 AM
auslandt's Avatar
2004 Toyota Tundra,
2008 Toyota Sequoia
Images: 5
FR=27.5
FL=28.5
BR=28
BL=28
That 1lb might be the cause for the tug. Let me know if your slight pull goes away.
Old 09-30-2004, 09:59 AM
dsconstructs's Avatar
Dealer : Fairfield Toyota
Last Online: 10-04-2009 11:24 PM
dsconstructs is on a distinguished road.
dsconstructs's Photo Albums
Default my tire wear from day one also
auslandtI had the exact same tire wear you describe from brand new also. I tried DJs specs which helped some, generally feathering is toe alignment related. The thing is it never did stop scrubbing my tire's tread the way it was. What finally stopped it for me was steering rack bushings, from brand new there was too much movement in the rack. New bushings and I finally quite wearing my tires the same as you describe. I'd have it put on a rack and check to see how much your rack moves when grabbing a wheel and moving horizontally by grabbing the front and rear of the wheel by hand.
Anyways, just thought I'd add that to the things to check. I was a bit surprised to know that from brand new it was rack bushings all along for me.
Old 09-30-2004, 10:09 AM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
- Other - 1967 Mustang,
2005 Toyota Prius,
2005 Toyota Tundra DC,
2008 Toyota Sienna RAMPVAN
Images: 164
Who ever told you this is full of HORSE-HOCKEY.
The dealership is the last person to inspect the vehicle. Its called a PDI
P=pre
D= delivery
I= Inspection
there is a check sheet to be follwed and filled out accordingly.
KLS is correct we are all responsible for our own vehicles.
The roads here in NV suck. I usually end up checking my alignment once every few months, just to make sure. I did notice like DSCONSTRUTS, that there was less change in alignment measurements, after i changed the rack bushings.
25 yrs with TOYOTA
Old 09-30-2004, 10:18 AM
It would be a good excuse to go urethane bushings from OffRoad Warehouse.
The first time I changed it I just used a stock bushing, the one on the passenger side, and that solved the tire wear issue. Since then I've changed to the urethane bushings, even better.
