I searched, looked at the larger wheel faq, etc and ran out of energy before I trudged through the general discussions and found an answer to my question.
I have a set of TRD 20's and now I need some recommendations for tires.
I want a tire that isn't going to rub, but also don't want a large amount of wheel well showing.
I'd say definitely 275/55. Back when I was looking at 20's( I can dream after all), that was the size I would have gone for. It's just a little bigger than 265/75 which people run with no rub, but it's also just a little wider. I would just put a 1" spacer to make your truck level and assure you have no rub. You could go without a spacer, but may rub when turning under compression.
I like the 275/55 for the sidewall, it's substantial enough to still give you some rim protection and some 'shock absorbing' quality(cause those 20's will ride a little stiff). I have seen some runing 285/50, that's a nice tire. It's a little smaller diameter than the 275/55 but it's wider so not sure about rubbing with that either. /Mike
2001 2WD Silver Tundra: 4x4 TRD springs, Daystar 1", Carson AAL, red/blue Bilsteins, 265/75 Revo's, IS kit(minus bumper) and rims(hand polished), RF851X amp, Alpine HU, JL 6.5"XR comps, Qlogic with JL 8W3V2 subs. 185k miles and counting......
Still got those Moda's? I was really close in getting the 18's on those since it was on sale at tire rack but it was a pain to get a LT 285/65/18 from BFG's so I am stuck with my 16's.
Allan
2002 SEQUOIA SR5
2.0 SAW WITH TC UPPERS
LT285/75/16 BFG'S on 16X8 JAOS VICTRON EXCEL II
2.5 INCHES DOWNEY REAR COILS
JBA HEADERS WITH MAGNAFLOW MUFFLERS
TRUE FLOW AIR INTAKE KIT
I am loving the tires I am running. i got the reccomendation from the guys at SOS Performance. Scorpion Zero 265/45 up front and 295/40 in the back. These are the same diameter as stock tires and the wider rear tires even out the track on the truck. To remove unsightly fender gap you could try SOS's drop shackles, its a cheap quick way to improve the looks without sacrificing payload or performance. I have the shackles on my rig right now and have had no problems ( they will be 86'ed in favor of the 4-link soon)
Good Luck
__________________ 2004 Toyota Tundra RWD Access Cab:
4.7L i-force, Phantom Gray Pearl, Gray Interior,SR5, TRD Sport, Towing Package(Reciever Removed)
TRD Supercharger, TRD Air Filter, TRD Headers, Hi-Flow Cats, Bassani Dual exhaust, RAPS Intake, Denso Iridium Plugs, SOS Perf 2" front drop, SOS Perf 4-link, coil over rear suspension (4" drop),TRD Enkei 20X9.5 w/Pirelli Scorpion Zero 295/40 R20 Rear and 265/45 R20 Front, Glassworks Unlimited Hood , custom rollpan w/ dual rear exahaust outlet, SET flares, T3 Grill, Alpine CDA-9835 HU, Infinity Kappa Perfect 6.5 components up front, 6.5 Coaxials in back, Infinity Reference 560 watt 4-channel, Infinity Basslink-T Sub, Debadged, and paraplegic hand controls.
0-60 / 6.95 sec.!!! 350 RWHP
Planned for the near future(I have it, now I just need to get it on the truck!!): Unichip, BSM Color Matching
Planned for the less near future
Seat and Harness!,Rear Disc, Bigger front brakes(I spend time at Thunder Hill and Laguna Seca),IPT Valve Body, SOS/TRD Intercooler, Overdrive Pulley, Suggestions Welcome GO COUGS!!!
Allan
Allan...yeah, still got 'em. they're still sitting in my garage. got quite a few offers, but i haven't been home enough to box them up. i'm a bad seller.
bwilder10h...295/45s are another good size. the 265/50s and 295/45s are probably the closest you'll get to the stock OD.
