Backspacing
+ Reply to Thread
Results 1 to 5 of 5
Thread: Backspacing
  1. #1
    Rookie zonie is on a distinguished road.
    Join Date
    Nov 2004
    Location
    Gilbert, AZ
    Posts
    7
    Liked
    0 times
    Rep Power
    0
    Default Backspacing
    I understand that the factory 16x7 Tundra wheels have 4.75" backspacing.
    Anybody know what it is on the 17x7.5's?
    I have heard that 3.5" backspacing is the minimum to clear the calipers. Correct?
    A lot of the wheel manufacturers only quote offset. What would be the offset of the factory wheels vs. a wheel with a backspace of 4"?
    Thanks
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member stile is on the right track. stile is on the right track. stile is on the right track. stile is on the right track. stile's Avatar
    Join Date
    Aug 2002
    Location
    Southeast
    Posts
    79
    Liked
    0 times
    Rep Power
    12
    I'm not sure about the 2005's, but I believe the previous model years ran anywhere from a 0mm offset (or 4.5" backspacing) to a 15mm offset (approx. 4.6" backspacing). I'm not sure on the 17" wheels, but I'm sure it's very close to that. This site allows you to compare sizes and will convert offset to backspacing for you:
    Big Wheels
    Hope this helps.
  4. #3
    Join Date
    Nov 2004
    Location
    Gilbert, AZ
    Posts
    7
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Default Great site
    Great! That site is Fantastic!
    Thank you!
  5. #4
    Join Date
    Aug 2002
    Location
    Southeast
    Posts
    79
    Liked
    0 times
    Rep Power
    12
    You're welcome, I stumbled across a post about it here (not sure where). So another ts member deserves the credit, not me . I just passed it along.
  6. #5
    Leader of Group Evil DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven's Avatar
    Join Date
    Oct 2001
    Location
    Snowy Highlands
    Posts
    10,421
    Liked
    48 times
    Images
    22
    Rep Power
    34450
    take a look at the diagram in the garage, it explains how backspacing, offset and other things are measured. clearing the calipers is a function of inner wheel shape and diameter--not all 16s will fit a tundra due to the shape of the wheel near the mounting surface. backspacing will change whether or not you hit the spindle, upper control arm, inner fenders etc. and changes the distance from the midpoint of the tire footprint to the hub. ideal dimensions would put the center of the tire footprint right at the axis of rotation of the ball joints...dunno what that is offhand, but i bet the stock wheels do it.
    -sean
    GFX by FreedomEagle50
    Manual Hubs
    OB's cup size: 36DD
    "some people will call you stupid but its worth a try because i know i also want one more inch."--SouthernTundraSC
Posting Permissions
  • You may not post replies
  • You may not edit your posts
