Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Tires and Wheels
  #16 (permalink)
Old 11-25-2004, 01:44 PM
Rlockyer's Avatar
Dealer : Crown Toyota Scion
2004 Toyota RAV4
Rlockyer is on a distinguished road.
Rlockyer's Photo Albums
Originally Posted by rx7vert
Ah. Nice to hear a technical side. I am just repeating what I have heard from some of the race teams I have talked to. The guy that manages the cars variables, including tire pressure, said that they saw less variation in pressure with tire temperature with nitrogen than with regular air.
It may have been the track conditions that they were testing on were giving substandard results.
Ya, there are too many variables to pin the fault on any one thing unless they have multiple sets of tires and are doing runs one after another.
Like I said... it's not a bad thing, and for certain applications, may be better, but it's nothing that we are going to notice on a personal vehicle.
Running the basic numbers, to get a change of 8psi, you need a temperature change of nearly 130^f
NASCAR will encounter changes that extreme.
2003 SR5 TRD V8
Traded in, 8-20-2005 with 125k trouble-free.
  #17 (permalink)
Old 11-25-2004, 05:53 PM
RoundOut's Avatar
2003 Toyota Sequoia SR5 4x4,
2003 Toyota Tundra SR5 4x4,
2003 Toyota 4Runner SR5 4x4
Last Online: 11-02-2009 06:22 PM
RoundOut is on a distinguished road.
Send a message via Yahoo to RoundOut RoundOut's Photo Albums
Originally Posted by Rlockyer
Pick up a Genesis, Asahi, or PST HP 120... 3500psi and only 5 pounds heavier (empty) than the AL80. Full, it's closer to 10 pounds heavier, but it's 50% more air
If I was still diving, or when I start again, I may do that. I have two AL 80's and have had them hydro'd once and fill them less than once a year, so each time I have to get them vis'd again, too. Kinda sucks. Maybe I should go ahead and get a compressor.
2003 Tundra SR5 4WD Access Cab Desert Sand Mica
Performance: Bassani cat-back exhaust, K&N FIPK, JBA Headers & Y-Pipe, Goodridge braided brake lines
Working mods: Tough Country front bumper, Camburg UCAs, Daystar 1" spacer & Sway-away 2.5" front coilovers & diff. drop spacers, Offroad Solutions manual hub kit, Kartek CV boots, Deaver 10 packs, BFG AT 285/75R16s on ProComp black alloy 16x8 rims, Rhino Liner, tool box, KC Slimlights, Form Fit bug deflector, Donnelly mirror, Muth Signal mirrors, "Tundra" HD floormats, Hi-Lift, Skid Row front, middle & rear skid plates, Custom rock sliders, Custom rear bumper & swing-out tire carrier, Icom 208H, CB, Backstopper backup sensors, auxiliary backup lights, Optima Red & Optima Yellow, Painless battery isolator, Champion 10K winch, Viair 400C, 4 gallon air tank, ARB Lockers front & rear, greasable bolts & sleeves for the Deaver leaf springs, Engle MT45.
Appearance & Comfort mods: Aftermarket Leather, desert sand mirror covers, dark grey fender flares, map light mod, de-badged all emblems, all black grille.
Future: Auxiliary fuel tank, replace tailgate w/ sand ladders
  #18 (permalink)
Old 11-26-2004, 12:41 AM
RoundTuit's Avatar
Dealer : Antwerpens Toyota Village
2004 Toyota Tundra,
2000 Lexus RX300
Last Online: 08-12-2008 02:57 PM
RoundTuit is on a distinguished road.
RoundTuit's Photo Albums
The primary reason nitrogen is used by the military is because it is inert.
If nitrogen is inert, where does nitrous oxide, amonium nitrate and nitric acid come from? I thought the inert elements were Group 0, nitrogen is Group V.
Just wondering, I'm not a chemist.
  #19 (permalink)
Old 11-26-2004, 02:52 AM
RoundOut's Avatar
I am no chemist either, but nitrogen is an element and nitrous oxide (NO2), amonium nitrate (NH4NO3) and nitric acid (HNO3) are molecules of multiple elements. The common threads among the three molecules you list is that they each have multiple bonds with oxygen atoms and cause rapid oxidation, or are oxidizing agents. Explosions, fire and rust are each forms of oxidation. One occurs nearly instantly (explosion), one rapidly (fire), and rust occurs more slowly over time.
For nitrous oxide, I presume that it helps combustion because there are more oxygen atoms in the nitrous oxide (two oxygen for every nitrogen) than there are in air (about 1 oxygen for every two nitrogens); and, they are injected under more than atmospheric pressure, i.e. blown like a supercharger, into the air/fuel mixture. Anybody with real knowledge, chime in here!
  #20 (permalink)
Old 11-26-2004, 12:16 PM
RoundTuit's Avatar
2004 Toyota Tundra,
2000 Lexus RX300
I do know the difference between elements, compounds and mixtures, and that was my point. Nitrogen bonds naturally (or does it always require an electric spark?) with other elements, and is therefore not inert -- at least according to my lame understanding of chemistry. I believe inert elements can be forced to bond with other elements under certain conditions, but I also believe it is rare to find compounds of inert elements in nature.
I have seen nitrogen described as inert more than once on this forum, and that has got me wondering. I just did a quick search and discovered that nitrogen is classified as inert even though it is not a group 0 element. Apparently that is because nitrogen is not very reactive in its naturally occurring N-N gaseous state. I guess that is the point Rlockyer was making.
As you can see, at my late age I am still unable to resist the temptation to demonstrate my ignorance in public. However, this did cause me to learn something, which I guess is good.
  #21 (permalink)
Old 11-29-2004, 03:05 AM
Rlockyer's Avatar
2004 Toyota RAV4
Nitrogen is inert inasmuch as it does not encourage oxidation of the base materials. The real "evildoer" is oxygen... removal of oxygen removes the possibility of oxidation, fire, or explosion. Nitrogen is the easiest thing to use as a replacement for oxygen. Other gasses would be just as effective, but more costly.
Nitrous Oxide does indeed increase engine power because it is a delivery vehicle for the extra oxygen. The O2 is released during either compression or combustion (I don't recall which). It is effectively a supercharger.
2003 SR5 TRD V8
  #22 (permalink)
Old 11-30-2004, 12:38 AM
rx7vert's Avatar
Drunk Redneck
Dealer : Bert Allen Toyota
2003 Toyota Tundra
Last Online: 10-29-2009 11:49 PM
Images: 6
rx7vert will become famous soon enough. rx7vert will become famous soon enough.
rx7vert's Photo Albums
Nitrous oxide is not used in vehicle to burn. Its main purpose is to cool the air so much that is is made more dense, therefore increasing power. It also breaks down slightly in the combustion chamber, adding compression, and making power.
I do know that nitrous is non flammable. If let out of a tank, it will blow out a candle, not blow it up.
this again is not from personal chemical testing, if I'm wrong, please correct me
  #23 (permalink)
Old 01-04-2005, 06:54 PM
Dealer : Hank Aaron Toyota
2002 Toyota Tundra
Last Online: 10-11-2006 04:14 PM
Supraman93 is on a distinguished road.
Supraman93's Photo Albums
ok maybe i'm wrong but wasnt the hindenburg (blimp) filled with nitrogen and it exploded? i would'nt really want my tires to explode while i'm driving!!
2002 Tundra, SR5, V8, Access Cab, TRD Offroad package, Putco Pop-up locker bed rails, clear side corners, Silverstar headlights and foglights, AVS bug deflector
  #24 (permalink)
Old 01-04-2005, 07:11 PM
Invid's Avatar
Dealer : Toyota of Riverside
2002 Toyota Tundra
Last Online: 09-26-2009 04:18 AM
Invid is on a distinguished road.
Invid's Photo Albums
That's incorrect the Hindenburg was filled with highly flammable hydrogen as well as being skinned in a highly flammable coated material.
Spintech 3332XL Muffler | Hellwig Rear Anti-Sway Bar | Updated 2005 Tail Lights | Updated 2003 Alloy Wheels | AMSOIL OAF-15 Oil Filter | Ultra-Strong Oil Filter Magnet | Synthetic Fluids all around | Line-X Bedliner | Osram Silverstars | Michelin LTX M/S tires | Custom Grille w/updated Body Panels | De-Badged | Optima Spiral Cell Gel Battery
LinkBack to this Thread: http://www.tundrasolutions.com/forums/tires-and-wheels/32956-nitrogen-vs-oxygen-filled-tires/
Posted By For Type Date
is helium more compressible than oxygen This thread Refback 02-01-2009 09:17 PM
Nitrogen For Your Tires - Lexus Owners Club (USA) Forums This thread Refback 06-06-2007 12:05 AM
