275/65/17 tires on 05 Access Cab 4X4
+ Reply to Thread
Results 1 to 6 of 6
Thread: 275/65/17 tires on 05 Access Cab 4X4
  1. #1
    Join Date
    Nov 2004
    Location
    Batesburg, SC
    Age
    78
    Posts
    28
    Liked
    0 times
    Thanks
    0
    Rep Power
    11
    Question 275/65/17 on 05 Access Cab 4X4
    I have a 05 Tundra Limited 4X4 due in the last week of Jan. I plan to replace OEM 265/65/17 (@ 30.7")with Michelin Cross Terrains same day of delivery. Will 275/65/17 ( @ 30.9")fit without clearance issues. Tire Rack shows 275/60/17 (@ 30") as optional, but I would prefer the extra inch the 275/65/17 provide.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member ToyzOnly's Avatar
    Join Date
    Sep 2004
    Location
    Carmichael, CA
    Posts
    528
    Liked
    0 times
    Thanks
    0
    Rep Power
    11
    Quote Originally Posted by walkerb
    I have the 17" wheels and tires also. I've been researching this too and never even considered 275/65/17. At dicountpartcenter.com they have a tire size calculator. On the first page click on tires and then click on tire size calculator. It's slow to react so be patient.They indicate you're diameter will go from 30.6 to 31.1.I don't have your answer because I'm still running the stock size. Hope this is helpful. Dave
    1998 Toyota Avalon XLS
  4. #3
    Junior Member btc1's Avatar
    Join Date
    Jul 2004
    Location
    Spring Branch, TX
    Posts
    105
    Liked
    0 times
    Thanks
    0
    Images
    5
    Rep Power
    11
    Default Tires
    Do yourself a favor and put the 2.5 leveling kit on there......I put a 2.5" revetek lift and stuck Nitto Grappler 295/75/17s on it...........Check out those tires....I have 50,000 on them on my tahoe, so I put them on my 2005 Tundra Double Cab 4x4.......Great Tires!
  5. #4
    Supporter TundrastruckDave's Avatar
    Join Date
    Jun 2004
    Location
    Wilson, NC
    Age
    53
    Posts
    1,537
    Liked
    0 times
    Thanks
    0
    Rep Power
    12
    Quote Originally Posted by btc1
    Hey btc1,
    Sure would like to see some pics of your DC as well as the tires!
    Thanks,
    Dave
    Mods to Date:
    Mods to Come:
    265/75/16 BFG A/T's,
    Possible Mods:
  6. #5
    Join Date
    Nov 2004
    Location
    Batesburg, SC
    Age
    78
    Posts
    28
    Liked
    0 times
    Thanks
    0
    Rep Power
    11
    Thread Starter
    Question MIchelin 275/65/17
    According to the Michelin spec chart thr 275/65/17 has a diameter of 30.9 vs 30.7 for the 265/65/17. It has a width increase from 10.4 to 10.6. I don't know how 'tight' clearances are, but I'll let you know the results.
  7. #6
    Join Date
    Sep 2004
    Location
    Carmichael, CA
    Posts
    528
    Liked
    0 times
    Thanks
    0
    Rep Power
    11
    Now I'm not so sure about the accuracy of the "tire size calculator's"you see online. And then the manufacturer says something different.They made the tire so they should know. And I'm now hearing a specific tire size differs in specs from manufacturer to manufacturer. Keep in mind that our stock rim width is 7.5"and the michelin spec chart is showing section width on an 8" wide rim. Most tire places or manufacturers offer a 30 day trial period so if it starts to rub you can take them back.And that's a good thing.
    Dave
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
