I would like to get a set of aftermarket wheelsets, and now I can narrow it down to Enkie, but still can't decide which rims to get. There is a Deep Six 20" which supposely fit well on the new '05 Tundra including no interferrence with the tires sensor. Check out picture at http://www.enkei.com/TruckSpecPAGES/deepsixSpecs.html
On the other hand, Enkei Phatt 20", I thought might look better on a white '05 Tundra, but not sure if there is any problem. Some of the rim the hup might not fit at all even though size and everything else is correct. Not to mention it also interfer with tires sensor. check out picture at http://www.enkei.com/TruckSpecPAGES/phattSpecs.html
So, with these two choices, I am not sure what to get. Both of these are about the same price. If you have any experience or suggestion, please send post it on here.
the deep six is the same as the enkei/toyota trd rims on mine, just different name. look at my pictures for ideas. the other onese look to heavy duty for our trucks.
__________________ 2003 Toyota Tundra V8 4x4 AC Exterior: Trd Off-Road package, Trd Skid Plate, Borla Side Exit Exhaust, 15% Llumar tint, Enkei Deep Six 20's, 275/55/20 Scorpion ATR, Bilstein 5100's, Toytec add-a-leaf, UWS Lo-Pro Toolbox Interior: Alpine 9851, CDT 6.5" components, Alpine MRP-F240, MRD-M300, ED SQ 10, HK USP 9mm.
Showroom Shine Details Premium Automotive Detailing
www.ShowroomShineNC.com
How sure are you with the Phatt will not work with Tundra? I am leanning toward the Phat that this point, but if you mention it might not work then I won't order it.
Originally Posted by bwilder10h
The Deep six looks real nice as you can see if you search for Enkei in the photo section.
The Phatt will not work on the Tundra due to the small centerbore.
Is there any interferrence with pressure sensor in anyway with the Enkei you have on now? Or any other problem?
I have to admin the more I look at it, the more I really wanted. I am just afriad it might cuase problem with the pressure sensor since I heard lots about on this topic.
I like the look of the Enkei deep six wheels. The Enkei website indicates center bore of 78 or 84 mm Is this right? I have an 01 looking for 20" wheels and 295/45s. w/ 106 center bore. Wheel hunting has been a nightmare. So many variables.
On a 9" wheel how much backspace is needed to accomadate that big a tire? What are the specs on the Enkei wheel in question?
Are the different specs required for a 2X4 and 4X4? 01 to 05?
As others have stated, the Phatt won't work due to the bore. I found a set of brand new Deep Six on ebay and personally love the look. Pics are uploaded if you'd like to have a look.
The Enkei Deep Six posted on their website and the Enkei Deep Six from Toyota available for the Tundra are not the same. You can clearly see the difference in the pictures from my posting on this page Where to Buy Enkei Deep 6 Wheels? . Notice the Enkei's on their website have the lugs covered by the center cap and the Toyota Enkei's are exposed lugs and a bullet style center cap. You can also see the Toyota Enkei's up close in my photo gallery. The actual Toyota exposed lug Deep Six is ONLY available through a Toyota dealer because Enkei signed a contract with Toyota.
The other difference is the new style Deep Six (second release) available from Toyota parts departments are that they have TWO different valve stem holes to accommodate either low pressure sensor.
Phil
__________________ 05 White TRD D-Cab, SR5, Limited slip, 20" TRD Enkei's with BFGoodrich G-Force TA NT, All weather guard package, factory rear privacy glass with matching front door tint, Toyota bedliner plus bed mat, Toyota/A.R.E. color keyed tonneau cover, overhead console with temp, compass and Homelink, Toyota/Gentex electrochromatic mirror, keyless, mats, TRD aluminum front skidplate, Toyota/Bazooka VSE 100 watt self-powered subwoofer, TRD stainless exhaust tip, door sill guards, Custom TRD matched pin striping with Toyota logos, painted calipers with TRD letters, TRD billet aluminum third brake light cover with true TRD letters, Pioneer AVIC D-3 GPS head unit with IP Buss controlled Pioneer XM radio tuner and iPod interface, Pac remote(maintains steering wheel controls) Polk Audio speakers DB675 two way in rear, Polk DB6750 components in front powered by a Polk C400.4 4 channel amp, seperate amped Aura Pro Bass Shakers under each front seat, Bazooka EL series 8" 100 watt self-powered subwoofer with Polk Momo driver with quick disconnect, Memphis tweeters in rear, back-up sensors (very handy), foglight mod, Sylvania Silverstars in both head and fog lights, added rear halogen back-up lighting, BellTech 6700 1" lowering shackles, Hellwig anti-sway bar, Magnaflow 14586 Stainless muffler, Wheelskins two-tone leather steering wheel cover, Ventvisors for side and rear windows, custom lower grill insert, Hoppy tailgate spring. More to come!
