Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Tires and Wheels
Old 01-05-2005, 10:17 AM
Dealer : Condit's Toyota World Of Newton
2002 Toyota Tundra
Last Online: 01-21-2008 10:51 AM
tiremd is on a distinguished road.
tiremd's Photo Albums
Default Difficulty Changing Tires
Ok...anyone else having this problem?
I have a 2002 TRD Access Cab with have a second set of tires mounted on OEM wheels for winter use. When I attempt to change the tires, the wheels are basically 'stuck' on the hubs/drums even after removing all lug nuts. I have to literally beat on the backside of the wheel with a rubber mallet to remove them, repeatedly! This has happened the last two times I've changed tires. I know one trick is to loosen the lug nuts slightly then let the truck down to let the weight of the truck dislodge them. This time I greased up the mating surface as well as the center of the wheel, taking care not to get any grease on the lugs or nuts.
Any other tricks or tips to keep this from happening? I'm guessing the grease I put on there will only hold up for a little while.
Do the tundra wheels center on the lugs, or the center hub?
Thanks.
Old 01-05-2005, 10:47 AM
cleanb13's Avatar
Dealer : Boch Toyota South
Last Online: 11-20-2009 05:38 PM
Images: 20
cleanb13 is on a distinguished road.
cleanb13's Photo Albums
I've had the same problem with alot of cars. Clean the hub part of the disc/drum ( what the wheel sits on) with sandpaper to get the corrosion off and then use a small amount of grease (wheelbearing or multipurpose grease on the hub. Remember use a small amount, you want just a coating.
2001 Tundra TRD Access Cab 4x4, SAW/Camburg coilovers, TC diff drop kit, Wheeler's Offroad AAL and Bilstein 5100's, LT265/75R16 BFG AT KO on Wheeler's black alloys, True Flow intake tube and filter with a modded air box, JBA titanium coated headers, Magnaflow 11226 muffler with stainless steel pipes and resonator removed, Skidrow front skidplate with custom made aluminum side shields, extended rear diff breather hose, Hawk LTS brake pads, Wheelers stainless brake hose kit, Helweig swaybar, Downey Offroad front swaybar link kit and cv joint boots,TRD "posi" 3rd member, debadged, backseat-power outlet-map lamp-taillight mod, Optima red top, TRD mirror covers painted flat black, Viair 300P air compressor, blacked out mouldings, bumpers and grille emblem
