Alignment and Uneven Tire Wear
I've read with interest the threads regarding uneven tire wear and alignment. I understand there is a specific recommendation by DJ about the settings, which I have copied down.
I just recently had an alignment on my '03 Tundra at 21065 miles. The Dunlops were wearing on the sides (rear tires) so I replaced them with Cross-Terrains. I now am seeing unusual wear on the Cross-Terrains.
Here are is my current alignment:
Front Caster Left: 1.9
Front Cast Right: 1.9
Front Camber Left: -0.3
Front Camber Right: -0.4
Front Toe Left: 0.10
Front Toe Right: 0.10
Total Toe: 0.20
Their readout shows:
* Caster specifications of an allowable minumum of 1.6, maximum of 3.1
* Camber specifications of an allowable minimum of -0.8, maximum of 0.7
* Total toe specifications of an allowable minimum or -0.10 to 0.30
Is that toe allowable range correct?
Any thoughts on my alignment with respect to tire wear?
Thanks very much,
coburn
