Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Tires and Wheels
LinkBack (21) Thread Tools Display Modes
  #46 (permalink)
Old 11-25-2008, 06:45 PM
RIjon's Avatar
The emblem & panel guy
Dealer : Valenti Toyota
Last Online: Today 08:43 AM
Images: 25
RIjon will become famous soon enough.
RIjon's Photo Albums
Default Re: Anti-seize on lug nut studs, why or why not?
Jeeez, people will argue about anything
I will always anti-seize my studs..... on any vehicle. Galling is no fun and completely unnecessary,
As far as torque ratings go.....it's not so much what the torque number is...it's the fact that ALL of them are the same. This will insure that the rotor does not warp when heated and cooled.
If you have ever built anything high performance that required specific torque specs (ARP Studs,bolts, ect... ) You will ALWAYS be told to use a lube when torquing.
To add to this, every time you loosen/tighten your studs you are generating heat. This will react differently between materials and without a lubricant, this can promote galling. Good luck!
2008 Tundra 5.7L RCSB
Custom Switch panels and Emblems for your tundra. PM for details
READ IT, LEARN IT, STAND FOR IT
http://www.usconstitution.net
Si vis pacem, para bellum
  #47 (permalink)
Old 11-25-2008, 11:35 PM
2009 Toyota Rav4
Last Online: 11-26-2008 11:48 PM
Extracheese is on a distinguished road.
Extracheese's Photo Albums
I personally have never seen or heard of an issue with putting an anti-seize compound on lug nut studs. Never had one loosen. I have lubed hundreds of vehicles studs. As far as the warpage is concerned, on most Toyota's it would require that you warp the hub too, as the studs are pressed into the bubs on almost all of them as the rotor hat is just sandwiched between the rotor and rim. Just food for thought. My first post, but nowhere even close to my first Toyota.
  #48 (permalink)
Old 03-08-2009, 12:00 PM
Dealer : Stevens Creek Toyota
Last Online: 08-16-2009 10:56 AM
akauth will become famous soon enough.
akauth's Photo Albums
As someone pointed out, the bigger deal is to match (and balance) the torque to each of the nuts all around to avoid any issues.
  #49 (permalink)
Old 03-21-2009, 10:17 PM
waiting tundra's Avatar
Dealer : Ray Brandt Toyota of Metairie
Last Online: 11-21-2009 11:26 PM
Images: 1
waiting tundra is a glorious beacon of light. waiting tundra is a glorious beacon of light. waiting tundra is a glorious beacon of light. waiting tundra is a glorious beacon of light. waiting tundra is a glorious beacon of light. waiting tundra is a glorious beacon of light. waiting tundra is a glorious beacon of light.
waiting tundra's Photo Albums
I'm not a engineer or any kind of scientist, I'm a boilermaker in a oil refinery for 25 years. I use 20 to 30 cans of neverseeze a week on every size bolt one can imagine. I don't work on space shuttles or jet fighters. I work on compressors,pumps, tanks vessels, stuff that runs for years at temps up to 2000 degress and 2000psi untill it breaks or comes down for maintance. Neverseeze is the best stuff you can put on your lugs in my opinion period. In fact I use it on everythang when I work on my vehicles & have been for years. You may break a lug trying to take a tire off that has rusted up, but breaking a lug by neeverseeze with 83#'s torque no way. In fact torqueing a clean neever seezed stud is the most accurate way to make sure the right amount of torque is applied. I use a torque wrench on 1000's of bolts a year and this is the proper technique. rebuild a pump or compressor without doing this and you will pay for it when you have to tear it back down. You will change your tire on the side of a road one day.
  #50 (permalink)
Old 03-21-2009, 10:38 PM
Dealer : Fremont Toyota
2002 Toyota Tundra
Last Online: Yesterday 10:59 PM
Triple BB is on a distinguished road.
Triple BB's Photo Albums
Anti-seize for me. Been using it on my lugs for a lot of years...
  #51 (permalink)
Old 03-22-2009, 02:09 AM
HOGWILD's Avatar
Dealer : American Toyota
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
Last Online: Today 09:46 AM
Images: 12
HOGWILD is a splendid one to behold. HOGWILD is a splendid one to behold.
HOGWILD's Photo Albums
Wheel Tech - Wheel Lug Torquing
  #52 (permalink)
Old 03-22-2009, 02:25 AM
This is exactly why I use it. When you live with something until it literally dies, you have a different attitude. I like to be able to take things apart near the end of it's useful life 20 years later and not have them break on me as I replace the parts. It's just so much easier and I've never had a failure. It just seems like common sense to me but I can see the argument against it. It's just not a strong argument, that's all
Certainly, rusted threads are NOT going to allow you torque a bolt to the proper tightness.
I've NEVER stripped threads from overtightening (that would be the biggest problem) or had a bolt fail from being overstretched.
Alan
LinkBack to this Thread: http://www.tundrasolutions.com/forums/tires-and-wheels/44792-anti-seize-lug-nut-studs-why/
Posted By For Type Date
Air tool question - Page 3 - PeachParts Mercedes ShopForum This thread Refback 06-09-2009 11:42 PM
Air tool question - Page 2 - PeachParts Mercedes ShopForum This thread Refback 06-09-2009 05:16 PM
2005 Toyota Tundra Lug Nut Size | Wednesday, May 27, 2009 | Result #2406, Kool Toyota Yaris Cars This thread Refback 06-03-2009 06:03 AM
American Muscle Car Gallery, American Motorcyclist Association Motorcycle Club, American Muscle Cars For Sale - Salvagemotorcycles This thread Refback 03-08-2009 03:42 AM
AutoElements :: Anti-seize on your lug nuts/bolts? This thread Refback 02-18-2009 11:55 AM
Air tool question - Page 3 - ShopForum This thread Refback 11-05-2008 07:45 AM
BMWBMW • View topic - Stupid Question about Lug Nuts This thread Refback 10-02-2008 07:17 AM
First Fuso FM from RUF Inc - Page 5 - Expedition Portal Forums This thread Refback 09-27-2008 11:45 AM
Air tool question - Page 2 - ShopForum This thread Refback 09-26-2008 03:46 PM
antisieze compound on lugnuts?? - Bob Is The Oil Guy This thread Refback 08-23-2008 01:11 AM
BMWBMW :: View topic - Stupid Question about Lug Nuts This thread Refback 06-11-2008 04:43 PM
Oversized Lug Nuts? - LX Forums Modern Mopar Muscle This thread Refback 05-15-2008 11:29 AM
Rear Wheel Stud/Wheel Hub Bolt Distress - RX8Club.com This thread Refback 09-13-2007 09:50 AM
Bob Is The Oil Guy: antisieze compound on lugnuts?? This thread Refback 08-30-2007 12:55 AM
Bob Is The Oil Guy: antisieze compound on lugnuts?? This thread Refback 08-27-2007 02:36 PM
Bob Is The Oil Guy: antisieze compound on lugnuts?? This thread Refback 08-26-2007 07:19 PM
Bob Is The Oil Guy: antisieze compound on lugnuts?? This thread Refback 08-26-2007 04:54 PM
Rear Wheel Stud/Wheel Hub Bolt Distress - Page 2 - RX8Club.com This thread Refback 07-02-2007 01:32 PM
Rear Wheel Stud/Wheel Hub Bolt Distress - RX8Club.com This thread Refback 06-11-2007 12:19 AM
TTORA Forum - Rusting Lugs This thread Refback 12-17-2006 03:53 AM
RX8Club.com - Rear Wheel Stud/Wheel Hub Bolt Distress This thread Refback 09-21-2006 06:01 PM
Lug Nut Torque? Tire Rotation RWB Tires and Wheels 8 07-02-2008 09:55 AM
HELP: ASAP: Stripped Lug nut (security style) mmarlatt Tires and Wheels 6 03-05-2005 04:35 PM
What size socket wrench for the wheel lug nut maverick2003 4Runner 2 03-14-2004 11:16 AM
What is lug nut size on 2002 Tundar SR5? fpb Tires and Wheels 4 08-14-2002 02:24 PM
what is the correct lug nut torque? fpb Tires and Wheels 3 07-01-2002 04:28 PM
