Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Tires and Wheels
Old 01-25-2006, 03:54 PM
Malachi's Avatar
Dealer : Toyota of Greensburg
2004 Toyota Tundra
Last Online: 11-20-2009 08:50 AM
Malachi is on a distinguished road.
Malachi's Photo Albums
Default Mounting Tires on Alloy Wheels
Do tire shops use a different machine to mount tires onto alloy wheels or do they use the same machine they use for installing tires onto steel wheels?
I just wondered if the alloy's will get scuffed when changing tires and whether I should be looking for a tire shop that knows how to change tires safely onto alloy wheels.
Old 01-26-2006, 08:16 AM
cleanb13's Avatar
Dealer : Boch Toyota South
Last Online: 11-20-2009 05:38 PM
Images: 20
cleanb13 is on a distinguished road.
cleanb13's Photo Albums
Default Re: Mounting Tires on Alloy Wheels
They use the same machine for both. There are precautions they can take to ensure that the wheel is not scratched.
2001 Tundra TRD Access Cab 4x4, SAW/Camburg coilovers, TC diff drop kit, Wheeler's Offroad AAL and Bilstein 5100's, LT265/75R16 BFG AT KO on Wheeler's black alloys, True Flow intake tube and filter with a modded air box, JBA titanium coated headers, Magnaflow 11226 muffler with stainless steel pipes and resonator removed, Skidrow front skidplate with custom made aluminum side shields, extended rear diff breather hose, Hawk LTS brake pads, Wheelers stainless brake hose kit, Helweig swaybar, Downey Offroad front swaybar link kit and cv joint boots,TRD "posi" 3rd member, debadged, backseat-power outlet-map lamp-taillight mod, Optima red top, TRD mirror covers painted flat black, Viair 300P air compressor, blacked out mouldings, bumpers and grille emblem
Old 01-26-2006, 11:28 AM
TundrastruckDave's Avatar
Dealer : Greenville Toyota
Last Online: 11-16-2009 09:37 PM
Just a little FYI...
Might not be a bad idea to reinforce that thought, by TELLING the shop of your choice to... be careful... when mounting the tires! Basically that's politely letting them know... they'd better not scratch the wheels.
Like I said... just a little FYI and Precautionary Thought.... .
Mods to Date:
Mods to Come:
265/75/16 BFG A/T's,
Possible Mods:
Old 01-26-2006, 04:13 PM
Malachi's Avatar
2004 Toyota Tundra
What precautions should they be taking? What should I be looking for?
By the way, did you have to put the 2" lift on your truck to fit the 265/75 to prevent rubbing or will they work on a 4x4 TRD stock without rubbing?
Old 01-26-2006, 04:22 PM
Malachi's Avatar
2004 Toyota Tundra
What if they do scratch it? What could I do?
Tundrastruck Dave (side note),
Does the Colgan Bra on your truck, have small puckering around the front edge of the hood, near the ends. Mine is new and I'm having a hard time getting the hood piece to fit smoothly along the left and right sides. About 3 inches in from each end is where it puckers. It doesn't seem to fit nice along the edges, seems a bit small. I don't know if this will stretch and loosen with time?
Old 01-26-2006, 06:07 PM
Well, if you tell the shop your concerns... BEFORE... they begin the work, I suppose you could ask... can they handle it and what will "they" do, if they do damage one of the wheels. My suspicions are... once you ask them this... if they "can't" do it without the possibly scratching a wheel, they'll just say they can't do it. I think I'd MUCH rather have them tell me "no", than have them "think" they can do it and end up damaging one. You could even ask... what precuations will they take, to prevent damage while mounting the tires. At least that lets them know, you'll be looking for damage... .
I think that little bit of puckering is probably normal. It will stretch some and some of that puckering may disappear. However, you probably "should" wait for a good warm day before you try it to intall it anyway. And yes, the "hood" section is the most difficult part of the installation. Just wait until you get a good warm day and set the bra out for a while in the sun. I promise... it'll be easier to put on.
Mods to Date:
Mods to Come:
Possible Mods:
Old 01-27-2006, 06:10 PM
DJ DJ is offline
Dealer : Fowler Toyota
2001 Toyota Sequoia,
DJ will become famous soon enough. DJ will become famous soon enough.
DJ's Photo Albums
They should be using machines designed for use with alloy wheels, but that doesn't mean they do. Such machines take care not to scrape tools around the rim, and the tools that do contact the rim are coated with a slick plastic to keep them from scratching.
You might want to see http://www.hunter.com/pub/product/tirechanger/index.htm for more info.
Largest Tires on 17" Stock Wheels (2005 DC) clongjax 1Gen-Tundra 4 12-30-2005 03:58 AM
What wheels for 275/70-16 tires and no lift??? Motorep Tacoma 1 11-05-2005 12:59 PM
Bigger tires on stock wheels TundraTaylor Tires and Wheels 4 06-15-2005 11:25 AM
