Some TS members have used 235/85-16 tires on their Tundra. I am curious how the Tundra handled with this size tire? Did you notice any difference in the following compared to the stock size that came on the Tundra:
Ride?
Handling?
Power Loss?
Less Gas Mileage?
2004, Toyota Tundra, 4x4, Phantom Gray
SR5, Access Cab, TRD Pkg., Towing Pkg., LSD
Extang Lift Off Tonneau
Bedliner
Colgan Custom Bra
Nasta S.S. Nerf Bars
"The Seat Cover Factory" seat covers
Air Box Mod/Stock Filter
Hankook Dynapro AS RH03 265/70-16 on Alloy Wheels
Hankook Icebear W300 245/70-16 on Steel Wheels
It was me.
Cooper Discoverer M+S Light Truck 235/85R16. Awesome tire in mud, slush & snow. Rode and handled perfectly. My son bought the 2000 from me with those skins on it. Drove it last week again. Just fine.
I like and run big rubber, however those 235's were the most sensible tire I've ever owned.
This habit is worse than drugs ...............
As mentioned HERE I'm running 215/85/16 10 ply radials.
I run 50 psi and other than the sound of the tread the thing I've noticed is reduced lateral traction at speed.
4 wheel drifts are kinda fun in a Tundra
Sorry, forgot your other questions.
It's only a 31.78" dia tire. Not much larger than stock 30" rubber. They roll better than my 33" 285 meats do.
Yes, I noticed that the height is about 1 inch taller than my current 265/70-16's. That's what I'm considering for my truck but I'm a little hesitant because I don't want to compromise ride, handling, power loss, and less gas mileage. Although, a 235/85 may give me the height I'm looking for but since it is a narrower tire, it may roll just as easy as the 265's I have on now. Not sure just speculating.
Bedliner
Colgan Custom Bra
You will not compromise ride, handling or fuel mileage with that Cooper tire. They roll very easily due to the 235 sizing. It is a super tire in heavy rain also.
Nope. I have the big brake kit so have to run 20" rims. Can't get tall narrow tires in that size. Been running my Wrangler AT/S LT275/65R20 all winter. No problems in rain or snow or slush. HOWEVER, once the tread gets down I would not want to run them in snow or slush. Impossible to find many tires in 20" that don't have those stupid thin 45 sidewalls.
Tall tires with narrow tread are optimal for fuel economy. That's why the Corollas of the
1980's had ultra tall and narrow P155/80/13 tires. The downside is high speed cornering capability is deminished. In some social circles narrow tread is perceived as wimpy.
On my last truck ,99 Dodge 3/4 ton, had a set of Cooper 255-85-16. They were 33.21'' tall and a really good A.T. tread, and 19/32'' tread depth.The guy I sold the truck to wore 'em down to nothing after 45000 miles and called the tires junk. Truck weighed in at better than 7000 lbs so I think the Coopers were up to the task.
I have been running my 255/85 R16's for a while now and I love them. They are BFG M/T's and measure in a 33.4" tall with 19/32 tread. Although...i could use some gears now....
I have pictures in my gallery, but here is one
__________________ David~2001 Toyota Tundra 4X4 TRD SR5~SSautochrome headers~Single 2.5" exhaust w/ Flowmaster 50 series delta flow muffler~K&N FIPK intake system w/True-flow filter~ASP underdrive pulley~Hellwig Anti-Sway Bar(removed)~Powertrax No-slip~Bilstein 5100 front and rear w/ Deaver 10 pack~Diff breather mod~255/85 BFG M/T on Wheelers Black Steelies Type B~Custom Rocksliders~Skid Row front skid plate~Custom Transfer case skid plate
It was me.
Me too. Those are my winter tires. I live in AK and see my fair share of snow and ice. I got a set of those with studs and I can go any where I want in the winter. No chains needed!
