Free Shipping at Buy.com!
FREE Personal Trainer Program
Tires and Wheels Discussions and experienced advice about tires, wheels, traction control, proper balancing, improving tire life and more.
This is a discussion thread titled "Toyo Open Country M/T's", within the Tires and Wheels forum, part of the Technical & Vehicle Assistance Forums category.
Old 03-11-2006, 08:08 PM
Dealer : Gateway Toyota Edmonton
WorkinTundra's Photo Albums
Last Online: 12-31-2006 08:02 PM
WorkinTundra is on a distinguished road.
Default Toyo Open Country M/T's
Hi,
I have a 2000 tundra 4x4 access cab and I recently bought some Toyo open country M/T's. They are 265/75r16
The manual says tires should be run at 26 front and 29 rear Psi.
What psi should I run these tires at?
Any help would be greatly appreciated
Old 03-11-2006, 08:26 PM
MtTrout's Avatar
Dealer : Kalispell Toyota
2007 Toyota Sequoia
MtTrout's Photo Albums
Last Online: Today 07:39 PM
MtTrout is on a distinguished road.
Default Re: Toyo Open Country M/T's
I have the Open Country A/T six ply tire and keep all four inflated to 40 lbs. If your tires are 4 ply they will require less. The tire shop told me to run them between 40-45 but the ride is too stiff at 45. Hope that helps.
Old 03-11-2006, 08:45 PM
When I got them from the shop they were at 60 psi???
like I said manual says 26 and 29 so not sure what to do with these
They are a 10 ply tire
Old 03-11-2006, 11:12 PM
MtTrout's Avatar
2007 Toyota Sequoia
That might be right, I have no experience with a ten ply but it makes sense because the more plys the tire has the more air they need. Hopefully someone else will chime in who knows more about this than I do.
Old 03-12-2006, 12:17 AM
Anyone else have any ideas???
what to run a ten ply tire at?
Old 03-12-2006, 01:10 PM
Any feedback?
Old 03-12-2006, 01:49 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
2004 Toyota Sequoia,
- Other - 1967 Mustang
mustang67408's Photo Albums
mustang67408 will become famous soon enough.
I run my YOKO MT's @ 42psi even tho it says 60. Anything abouve 45 for me is wayyyy to bouncy.
23 yrs with TOYOTA
Official Donahoe Certified Installer & Dealer
K.I.S.S.
Old 03-12-2006, 02:17 PM
hey ,
Thanks for the help. I just filled the front 40 and the rear 38.
I'll give that a try and see how it works out
Old 03-13-2006, 07:42 PM
Imdone's Avatar
2004 Toyota 4Runner,
My eBay Imdone's Photo Albums
Last Online: Yesterday 12:12 AM
Imdone is on a distinguished road.
I run my BFG m/ts at 40 F/R cold. Hot goes to 44psi F/R.
Work in progress...
Old 03-14-2006, 02:04 AM
HBjeff's Avatar
Dealer : Carson Toyota Scion
2005 Toyota Tundra
HBjeff's Photo Albums
Last Online: 08-29-2008 10:06 PM
HBjeff is on a distinguished road.
more pressure in the rear on a pickup, thats just wrong
05 tundra 4wd
-magnaflow 5x11x22
-donahoe
-camburg uca
Old 03-31-2006, 03:21 PM
2004 Toyota Tundra
G-money's Photo Albums
Last Online: 02-26-2008 02:58 PM
G-money is on a distinguished road.
How do you like your Open Country A/T's? Thinking of getting a set of those and heard they are good...soft ride, low highway noise, good grip. Would you buy them again?
Old 03-31-2006, 04:41 PM
Herbicidal's Avatar
Just a Herbicidal maniac.
2001 Toyota Tundra,
2008 Toyota Yaris Sedan 'S' Flint Mica
Herbicidal's Photo Albums
Last Online: Today 01:07 PM
Herbicidal is on a distinguished road.
Wow! Those are some high inflation numbers! I'm running my Toyo M/T's at 30psi front and 28psi rear. They are wearing quite nicely after 6,300 miles. Too much air and you'll be riding in the center of the tire and wearing it out. Too little and the edges will go first. There is a "chalk" test you can do by rubbing chalk all over the tread surface on one tire and driving straight ahead on a smooth, flat surface to see exactly how much of your tire is making contact. Then you adjust the air pressure accordingly.
I believe there is also a rule of thumb about the rating of your tires compared to the truck weight. Sorry I don't have the exact info on that. However, in my case I have weighed my truck on a public scale and it comes in at 5,300 lbs give or take 20lbs.
My daily driver - 2008 Yaris sedan 'S'. Tinted windows in the rear, TRD anti-sway bar for the rear, 17" rims - Samurai SC02 Hyper Black.
My favorite ride - a 2001 SR5 4x4. With - RCD 6" lift, JBA Titanium coated headers, JBA y-pipe, Unichip PnP, ARB rd-129 air locker (rear), Camburg UCA's, custom front Sway-A-Way coilovers, custom Sway-A-Way's with remote reservoirs and billet mounts for the hind-quarters, PolyPerformance limit straps with adjustable clevis's - mounts welded up by AJ at BentUp.com, Stubbs Welding rock sliders and custom front skid plate, 315/75/16 Toyo Open Country M/T's, on all 4 corners wrapped around 16x8 MB Motoring Blitz rims, cryo'd 4.88's set up by Inchworm Gear, Trenz billet grill upper, T-Rex billet grill lower, on board VI-AIR aircompressor and 3 gallon air tank from Wheelers Off-Road, Inc, AutoMeter A-pillar pod with transmission temp gauge (sending unit in the tranny pan), Long Tru-Cool LPD tranny cooler, 10" Flex-a-Lite tranny cooler fan w/thermostat, TRD billet oil filler cap, TRD air filter, TRD dual exhaust, and TRD add-a-leaf rear springs. Superlift TruSpeed Speedometer Recalibrator. Warn Trans4mer Grill Guard, brush guard and 9.5ti winch w/cover. Budbuilt traction bar. Wheelers Off Road Centric performance brake rotors: cross-drilled and slotted. Staun tyre deflators set for 13 psi. Our home away from home, 2004 Outback 26RS travel trailer with 15" MB Motoring Blitz rims to match the Tundra.
Old 04-01-2006, 12:42 AM
MtTrout's Avatar
2007 Toyota Sequoia
I plan on buying this tire until something better comes out. What I do is run them to about 50% then the Toyo dealer trades me for a new set at about 50% off. That way I always run on good tires.
Hey Herbicidal, are your tires 4 or 6 ply? This makes a big difference in inflation. I am running 40 PSI with 6 ply, 4 ply need less air pressure.
Old 04-01-2006, 09:50 PM
My toyo's are 10 ply and I'm running them at 44psi all around.
Mine are 265/755/16 and the max is 80 psi
Your larger m/t's are rated for a max of 60 psi
not sure if that makes the difference
Old 04-02-2006, 10:02 PM
Herbicidal's Avatar
2001 Toyota Tundra,
I just checked the sidewall and they are 10 ply, 65psi max inflation. That's interesting about the 50% deal...
