OEM alloy wheels sticking to hub?
+ Reply to Thread
Results 1 to 6 of 6
Thread: OEM alloy wheels sticking to hub?
  1. #1
    Veteran Member czechm8's Avatar
    Join Date
    Sep 2004
    Location
    Clive, IA
    Posts
    1,772
    Liked
    26 times
    Images
    25
    Rep Power
    1367
    Default OEM alloy wheels sticking to hub?
    This weekend I took off my factory alloy wheels and changed over to my 3 season wheels & tires. I had lots of trouble un-sticking the front wheels from the hubs this year and wondered if anyone else had this problem.
    To break the front wheel free I literally had to loosen all the lugs, take the vehicle off the jack/stands, then start it up, pop it in gear and slam on the brakes after about a foot of travel. They were really stuck. I had to do this about three times on one wheel before I could feel it break free.
    The lugs and wheels suffered no damage, but I don't want to go to this extreme every time I swap out my wheels.
    I cleaned the hubs a little and sprayed some WD-40 on them before I bolted up the after-market wheels.
    Maybe I should pull them off and do a better job of cleaning them.
    What can I treat the hubs with to prevent this in the future? Grease?
    05 Sequoia 4x4 Ltd. Phantom Grey Pearl, Weld 20" wheels on Michelin tires, MagnaFlow cat-back, Amsoil fluids, custom 15" overhead DVD system, Eclipse NAV system w/camera, Sirius tuner, HD Radio tuner. HAT tweeters, Scanspeak mids and DLS coaxials, TRU B-2110 and H-1 amps, 13" eD sub, iPod hookup. SilverStar Ultra lamps, Bilsteins all around.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Lurking Member tundranator's Avatar
    Join Date
    Feb 2005
    Location
    los angeles CA
    Posts
    48
    Liked
    2 times
    Rep Power
    15
    Default Re: OEM alloy wheels sticking to hub?
    i use this ani-seize hub compound. its silver in colour and works great. im not sure what its called but i'll make sure to check and post again. its available at most auto parts stores.
  4. #3
    Join Date
    Sep 2004
    Location
    Clive, IA
    Posts
    1,772
    Liked
    26 times
    Images
    25
    Rep Power
    1367
    Thread Starter
    Quote Originally Posted by tundranator
    I didn't know they made one specifically for wheel hubs! I've used the copper based ones for spark plugs in aluminum heads before.
  5. #4
    Veteran Member ICON's Avatar
    Join Date
    Nov 2005
    Location
    Monson,ma
    Posts
    564
    Liked
    3 times
    Images
    8
    Rep Power
    266
    It's a galvanic reation between dissimilar metals, alloy rims against steel hubs. The WD-40 wont do anything, tundranator hit the nail on the head: Antiseize. I really don't think which one you use matters. I use the silver antiseize on just about everything. Clean off as much rust as possible and cover the hub where the rim sits w/a light coating of the compound and put some on the threads of the lugs, just enough to coat the steel is enough. The rims and lug nuts will come off everytime like nothing from here on out. Just don't keep pilling it on there, if it gets too much on there i recommend cleaning it all off and starting fresh.
    '06 AC SR5 4x4
    '05 Honda Foreman 500S 4x4
    '04 Honda Shadow Sabre 1100
  6. #5
    Join Date
    Sep 2004
    Location
    Clive, IA
    Posts
    1,772
    Liked
    26 times
    Images
    25
    Rep Power
    1367
    Thread Starter
    Quote Originally Posted by ICON
    Makes sense. When it gets warmer here I'll pull them off and treat them so I don't have to go through that episode again!
    Thanks.
  7. #6
    Supporter Yellbird's Avatar
    Join Date
    May 2000
    Location
    Chicago, IL
    Posts
    329
    Liked
    1 times
    Rep Power
    16
    I use a product called Wheel Mate that goes between the hubs and wheel and it makes really easy to get the wheel off. I think they were $19 at Autobarn and have no problems since using them.
    Quote Originally Posted by czechm8
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
  1. 11-29-2009, 12:49 PM
  1. Wheel Selection FAQ
    By OKCTundra in forum Tires and Wheels
    Last Post: 12-14-2007, 06:26 PM
  2. News|Stories|Photos|Videos
    By Possum in forum Off-Topic
    Last Post: 01-17-2007, 03:36 PM
  3. Clear Coat Alloy Wheels
    By Malachi in forum Tires and Wheels
    Last Post: 03-13-2006, 01:14 PM
  4. Tacoma: Question... About OEM Wheels for the Taco
    By TundrastruckDave in forum Tires and Wheels
    Last Post: 10-15-2004, 05:08 AM
  5. Warning - Problem W/ Black Alloy Wheels
    By jjc in forum Tires and Wheels
    Last Post: 05-07-2004, 09:22 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
