Well, I finally got the 285's! I ended up going with Yokohama Geolandars AT+II. I must say that these tires a pretty smooth and quiet on the road! Check my gallery for some pics.
"If your not obsessing about something, you're probably not into it enough." - Chris Thile
2001 Tundra Limited *SOLD*
2005 Ford Excursion Limited PSD
1996 Ford F-250...Runnin' on Veggie Oil
1946 John Deere A
MODS: Hellwig, Custom Duals w/ Flowmaster 40 Series and Dr. Gas X-pipe, Daystar Bushings, Cornfed 2" Front Spacers, TRD AAL, K&N FIPK, 16x8 Weld Outbacks, 285/75R16 Yokohama Geolandar's, Access Cover, BedRug, Putco Bed Rails, PP Bull Bar, WeatherFlectors, Prodigy Brake Controller, Brown Bread Sound Deadener, '05 Taillights, AMSOIL ATF
2001 Tundra TRD Access Cab 4x4, SAW/Camburg coilovers, TC diff drop kit, Wheeler's Offroad AAL and Bilstein 5100's, LT265/75R16 BFG AT KO on Wheeler's black alloys, True Flow intake tube and filter with a modded air box, JBA titanium coated headers, Magnaflow 11226 muffler with stainless steel pipes and resonator removed, Skidrow front skidplate with custom made aluminum side shields, extended rear diff breather hose, Hawk LTS brake pads, Wheelers stainless brake hose kit, Helweig swaybar, Downey Offroad front swaybar link kit and cv joint boots,TRD "posi" 3rd member, debadged, backseat-power outlet-map lamp-taillight mod, Optima red top, TRD mirror covers painted flat black, Viair 300P air compressor, blacked out mouldings, bumpers and grille emblem
They come close to the plastic under the bumper, but so far I have no rubbing!!
Hey, I just noticed that this was my 1,000th post!!! Wuu Hoo!!!!
Hey Shawn,
Do you like 'em better than your previous set of tires?
__________________ 2000 Toyota Tundra V8 Ivan Stewart Edition
2.5" Shocks by Sway A Way (Camburg)
King Coil Springs 650lb x 14"
11pk Deavers w/ 5100 Bilsteins
LT285/75R16 Nitto Terra Grappler Load Range D 122Q
Weld Racing Renegade 16x8 3 5/8 BS
JBA Titanium Coated Headers
Eclipse AVN5435 Unit
'05 Tail Lights
Clear Corners
TRD LSD soon!
Well, I have only had them for 3 days now. But, so far they are quieter than the BFG AT ko's......I will have a better opinion after a couple months. Man, I love the look on the truck though!
1946 John Deere A
I had cornfeds and they really gave a harsh ride because they increase the spring rate greatly. I switched to spacers that sit in top of the coilover mounting plate and I'm alot happier now.
I love the Cornfed's! I have had them on the truck since 2002. Yes, they do firm up the ride, but now the tundra rides like it should (like a truck!). If you have any more questions feel free to ask.
1946 John Deere A
Hey, im new here and this is my 1st post.. so hey all
Sorry to just cut in but i don't know where to post my question hehe...
Well here goes.
With 285/75/16s ..i recently leveled 2" on the front of my '01 AC tundra and running on 285/75/16s on stock rims with no problems on rubbing or anything of that sort. Now im planning to get 16x8 pro comp rims and to my knowledge, stock alloy rims are 16x7. Am i gonna get rubbing issues from 16x8? The Pro Comp Series 1069's backspacing is 4" ..well at least that's what they claim.
Can someone please tell me what the safe BS is for 285/75/16x8 on a 2" lift is? I did see a post up there by hockeyfreak about it being safe for his 2" but it IS for a different type of rim (Weld Outbacks).
Someone PLEASE correct me if I'm wrong.. 16x8 with 4inch backspacing will clear the frame... but I don't know about the bumper valance..
16x8 (4.5 bs i think) and I've been good.
Tundra is gone...*Map Light mod *Keyless Upgrade *Monster ICruze *Nitto Terra Grappler AT 285/75/16 *Black Helo Maxx 8 16x8 *4x4 TRD Coils *4x4 TRD Shocks *Daystar 2.5" Spacer Kit *Bilstein 5100's *P.A 3" Body Lift *Toyota Drop-in Bedliner *Toyota LSD *Toyota Hood Protector *VentShades *Debadged *Tint *Flowmaster 50 Series Single Exhaust *Clear Corners *Chrome Nerf Bars*
Nissan 350ZR is here...350zen,org
I don't know much about backspacing ..but if it is 4.5, is that an option for that specific rim? Will I be able to choose a different bs for the same rim? i e, will pro comp's 1069 16x8 have 4 as well as 4.5 bs? or would i have to settle for a whole other rim?
and thx
2001 SR5 V8 - 2" Ready Lift spacer - 3" PA bl -305/70/16 on 16x8 Pro Comps - true dual Magnaflow - Air Raid throttle body spacer - True Flow Cold Air Intake - Gen 3 Altezzas - indiglow blue Halo Reverse Glow Gauges - Arctic White Headlights - _____
It depends on the rim.. Some Manufactuers will have many different backspacing, some will not.. You just have to take a look. Ordering online or brick and mortor? I know there are people running 16x8 with 4inch backspacing.. Cubic22 was running 4" Backspacking on an '02, VERY similar.
Stan
I just put black alloys from Wheelers Offroad and I only have slight rubbing at the pinch weld. Wheelers also sells procomp alloys that are not black. You should contact him. He knows his stuff.
