Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Tires and Wheels
Old 04-23-2006, 12:06 PM
Dealer : Pauly Toyota
2003 Toyota Tundra
Last Online: 01-26-2008 01:43 AM
mikemock is on a distinguished road.
mikemock's Photo Albums
Default Wheel stuck
I recently replace my tires had observed in interesting phenomenon that distrubs me. The guys replaceing the my tires removed all the lug nuts and had a a very hard time removing the wheel. The wheel seem to be bonded to the axel. The had to use a mallet to get it off. They had explaind that they had a different car that took them several hours to remove the wheel.
I am concerned that one day I will get a flat tire and won't be able to remove the wheel. I think this can even be dangerous if I get a flat in the rain or in winter when the ground may be slippery, or if I cant find perfectly level ground to jack up my truck.
Has anyone else had this problem, and what is the best way to prevent it.
Can the tire be lubricated, and with what kind of lubricant?
Old 04-24-2006, 07:40 AM
Dealer : Don Jacobs Toyota
Last Online: 10-05-2007 01:36 PM
n2oiroc is on a distinguished road.
n2oiroc's Photo Albums
Default Re: Wheel stuck
spread anti sieze compound on the hub of the truck where the wheel touches.
Old 04-24-2006, 12:36 PM
Dealer : Toyota of Greensburg
2005 Toyota Tundra
Last Online: 11-08-2009 07:50 AM
cookiemech is on a distinguished road.
cookiemech's Photo Albums
. . . and before you do that, put a small wire wheel on an electric drill and clean up the mating surfaces on both wheel and hub.
I now have a six-pound dead-blow hammer so that we can always get the wheels off my friend's Tundra (with alloy wheels). That's why I have steel wheels on mine.
Old 04-24-2006, 07:50 PM
2003 Toyota Tundra
I guess I will have to remove the wheels now and clean them up.
I was hoping that there is some sort of lube that can be applied that will be safe for the metals involved (alloy wheels and steel axle/brakes).
I can't imagine that hammering on the tire with a large mallet is good for the alignment?
Old 04-27-2006, 09:47 AM
ICON's Avatar
Dealer : Lia Toyota Of Northampton
Last Online: 11-20-2009 02:38 PM
Images: 7
ICON will become famous soon enough.
ICON's Photo Albums
It happens w/alloys and steel rims since the hub isn't coated to prevent it from corroding, it bonds itself to the rim. Worse w/alloys due to dissimilar metals corroding faster than like metals when in contact with each other. Best solution is to wire brush the corrosion off the hub and rim then apply anti-seize to hub and lugs then reinstall. Makes taking everything apart much easier. I also anti-seize just about every bolt i remove for easy removal next time. I wouldn't worry about the alignment as much as a bent rim from the hammer, but when i do come across stuck rims usually a good kick to one side of the tire pops it loose.
'01 Tundra Reg Cab SR5 V8
'05 Honda Foreman 500S 4x4
'04 Honda Shadow Sabre 1100
Old 04-27-2006, 11:12 AM
Yellbird's Avatar
Dealer : Oak Lawn Toyota
Last Online: Yesterday 05:12 PM
Yellbird is on a distinguished road.
Yellbird's Photo Albums
I use a product called Wheel Mate which is 0.030 of an inch and goes between the hub and the wheel. Put one on each wheel and the wheels comes off with just a tap, problem solved. Got mine from AutoBarn.
Wheel Selection FAQ OKCTundra Tires and Wheels 1 12-14-2007 09:26 PM
Looking for a Spare Wheel Cover PagalDesi4Life Tires and Wheels 0 05-11-2005 03:50 AM
33" Spare Wheel Cover PagalDesi4Life Tires and Wheels 0 05-10-2005 03:33 PM
stuck wheel elp atc Tires and Wheels 4 02-12-2005 10:09 AM
Keeping 4wd active: Dry road use o.k.? molex Engine & Drivetrain 14 12-22-2003 04:05 AM
