VCT-Gitano wheels
+ Reply to Thread
Results 1 to 5 of 5
Thread: VCT-Gitano wheels
  1. #1
    Junior Member 2002toytundra has done just about everything...and then some. 2002toytundra has done just about everything...and then some. 2002toytundra has done just about everything...and then some. 2002toytundra has done just about everything...and then some. 2002toytundra has done just about everything...and then some. 2002toytundra has done just about everything...and then some. 2002toytundra has done just about everything...and then some. 2002toytundra has done just about everything...and then some. 2002toytundra has done just about everything...and then some. 2002toytundra has done just about everything...and then some. 2002toytundra has done just about everything...and then some. 2002toytundra's Avatar
    Join Date
    Mar 2005
    Location
    Broken Arrow, OK
    Posts
    217
    Liked
    3 times
    Images
    3
    Rep Power
    961
    Default VCT-Gitano wheels
    Anybody heard anything on these wheels? They have a couple of designs that are really cool. Thinking about ordering some discountedwheelwarehouse.com says that there are a couple of styles that will fit the ol' Tundie.
  2. #2
    Join Date
    Mar 2005
    Location
    Broken Arrow, OK
    Posts
    217
    Liked
    3 times
    Images
    3
    Rep Power
    961
    Thread Starter
    Default Re: VCT-Gitano wheels
    Just an update I got the Gitano G9 and they came in the other day. The bolt patten and offset are just right on a 20x9 inch wheel. It looks like they had the center bore enlarged to fit the 108mm hub, they fit great. The wheels came with 275/45R20 Falken STZ04 tires. It took about three weeks to get them but the guys at discountedwheelwarehouse.com did send the ones that fit!
  3. #3
    Join Date
    Mar 2005
    Location
    Broken Arrow, OK
    Posts
    217
    Liked
    3 times
    Images
    3
    Rep Power
    961
    Thread Starter
    Angry Re: VCT-Gitano wheels
    Just FYI dont order a @#%$@)$*#@(*$@ thing from discountedwheelwarehouse.com!!!!!
    I just ent to have the tires re balanced as there has been a slight vibration since I got them and three of the four wheels are bent, they have a flat spot.
    I can't get anyone from the joint to return a phone call and the manufacturer isn't taking calls either. Guess I'm screwed for another 1000 dollars or so
  4. #4
    Join Date
    Mar 2005
    Location
    Broken Arrow, OK
    Posts
    217
    Liked
    3 times
    Images
    3
    Rep Power
    961
    Thread Starter
    Maybe they are going to work with me, I'm getting some Eagle Alloys 026, put on tomorrow. Gotta work those off the credit card now! Been told they will fit perfect, we'll see.
  5. #5
    Join Date
    Mar 2005
    Location
    Broken Arrow, OK
    Posts
    217
    Liked
    3 times
    Images
    3
    Rep Power
    961
    Thread Starter
    Got eagle alloys series 026 wheels with the Falken Ziex rubber now. They look great and fit, 108mm hub bore 6 x 5.5 and a 14mm offset. Look out if you get some wheels from Eagle, the new Tahoe uses a 108mm bore, 6 x 5.5 lug and a 40mm offset. Close to the Tundra but almost and inch and a half further inboard than what is needed by the Tundra.
    Also I was told that Falken has had problems with the belts shifting in the Ziex STZ04 tires, had not heard that before and have had no issues with mine, I like 'em.
    I'll get some pics in the gallery soon, if anyone cares.
  1. Wheel Selection FAQ
    By OKCTundra in forum Tires and Wheels
    Last Post: 12-14-2007, 06:26 PM
  2. News|Stories|Photos|Videos
    By Possum in forum Off-Topic
    Last Post: 01-17-2007, 03:36 PM
  3. Stock wheels peeling
    By Oafboy182 in forum Tires and Wheels
    Last Post: 12-15-2005, 05:39 AM
  4. HELP Bad luck with new wheels
    By AdamRmr in forum Tires and Wheels
    Last Post: 12-14-2005, 07:37 AM
  5. Tacoma: Question... About OEM Wheels for the Taco
    By TundrastruckDave in forum Tires and Wheels
    Last Post: 10-15-2004, 05:08 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
