Who runs a 305/55-18 ??
+ Reply to Thread
Results 1 to 7 of 7
Thread: Who runs a 305/55-18 ??
  1. #1
    Veteran Member FiveOh will become famous soon enough. FiveOh will become famous soon enough. FiveOh will become famous soon enough. FiveOh will become famous soon enough. FiveOh will become famous soon enough. FiveOh will become famous soon enough. FiveOh will become famous soon enough. FiveOh's Avatar
    Join Date
    Jul 2006
    Location
    Austin
    Posts
    506
    Liked
    0 times
    Rep Power
    10
    Default Who runs a 305/55-18 ??
    I'm looking at throwing a set of Pro-Comp 18x10's with Nitto 404 305/55-18's on my '06 AC
    . Does anyone have pics of that size tire?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter Agent WD-40 is a splendid one to behold. Agent WD-40 is a splendid one to behold. Agent WD-40 is a splendid one to behold. Agent WD-40 is a splendid one to behold. Agent WD-40 is a splendid one to behold. Agent WD-40 is a splendid one to behold. Agent WD-40 is a splendid one to behold. Agent WD-40 is a splendid one to behold. Agent WD-40 is a splendid one to behold. Agent WD-40's Avatar
    Join Date
    Sep 2000
    Location
    The Motor City
    Posts
    2,905
    Liked
    0 times
    Images
    21
    Rep Power
    20
    Default Re: Who runs a 305/55-18 ??
    Quote Originally Posted by FiveOh View Post
    Be careful with backspace or you will be rubbing the frame on turns and the upper A-arm almost all the time. 4" BS or less would be better. I would test fit it before hand if you can.
  4. #3
    Join Date
    Jul 2006
    Location
    Austin
    Posts
    506
    Liked
    0 times
    Rep Power
    10
    Thread Starter
    4" BS min or max?
  5. #4
    Join Date
    Sep 2000
    Location
    The Motor City
    Posts
    2,905
    Liked
    0 times
    Images
    21
    Rep Power
    20
    4" BS min or max?
    Max is what I should have said. 3 5/8" would probably be even better than 4".
  6. #5
    Join Date
    Jul 2006
    Location
    Austin
    Posts
    506
    Liked
    0 times
    Rep Power
    10
    Thread Starter
    Anyone running this approx size?
  7. #6
    Junior Member qqqqqqqman is on a distinguished road.
    Join Date
    Jul 2006
    Location
    Orange County, CA
    Posts
    68
    Liked
    0 times
    Rep Power
    7
    Not quite.....I run Pro Comp 18x9 and Nitto 285/60R18. Backspacing on the Pro Comps is 4.75", which as Agent noted was not thought to be ideal, but I have NO rubbing issues at all. I have only a 2.5" Daystar front lift. If you don't lift more, I would assume you would rub somewhere.
    '06 Tundra DC, TRD Off Road...White...Daystar 2.5" front spacer lift...18"x9" Pro Comp Xtreme 6079 chrome with 285/60R18 Nitto Terra Grapplers...Hellwig sway bar...Line-X...tinted windows
  8. #7
    Join Date
    Jul 2006
    Location
    Austin
    Posts
    506
    Liked
    0 times
    Rep Power
    10
    Thread Starter
    Quote Originally Posted by qqqqqqqman View Post
    I'll probably go with the 18X9's also. (4.75" BS) with the 305/55/18's. So what are my chances of it not rubbing. The increase in radius should be about ~0.8", so my real worry would be clearence to suspension components.
  1. Durst-Armendariz Runs In The Finals At Las Vegas Sport Compact Nationals
    By TS Support in forum Toyota, Scion & Lexus News
    Last Post: 07-22-2006, 03:59 AM
  2. Who runs 22" wheels?
    By Canada Jeff in forum 1Gen-Tundra
    Last Post: 05-01-2006, 08:01 AM
  3. Did 0-60 runs today
    By 4.7 vvt-i in forum Off-Topic
    Last Post: 07-07-2005, 10:58 PM
  4. K&N FIPK dyno runs - '03 Sequoia
    By toyotafreak in forum Engine & Drivetrain
    Last Post: 01-06-2005, 05:04 PM
  5. Clock runs WAY fast!
    By nhparrot in forum Electrical & Computer Systems
    Last Post: 03-28-2002, 10:23 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
