Re: Differenet PSI 265/70 R17 LT Revo's question
I just put a set of the Load range E revos on my tundra and I have set them at 80 psi like the sidewall says. I noticed that the ride was a little rougher than the stock POS tires but I think that it is well worth it. I allways run my tirs a the sidewall rated presure as this is where I belive the tire will preform best. Personally I can not tell a differance bewteen tires at 30 and 50 psi. I also hat these tires in the mud today and they are wonderful. I dident even have to use 4wd where I was getting stuck in 4wd with the stock POS tires.
Hope this helps. Jeff
Jeff
07 Dodge Ram 6.7l cummins 6spd (on order)
05 DC Limited, nav, DVD, leather (sold)
05 Nismo Frontier, traded due to problems
03 Triumph Sprint S/T motorcycle
A Nissan Tech driving a Toyota
