325's = 35's or 37's???
+ Reply to Thread
Results 1 to 2 of 2
Thread: 325's = 35's or 37's???
  1. #1
    Junior Member lsturbointeg's Avatar
    Join Date
    Apr 2006
    Location
    Temecula
    Posts
    285
    Liked
    0 times
    Rep Power
    10
    Default 325's = 35's or 37's???
    hey guys! i've been trying to look for the metric conversion chart but anyone know if a 325 is the same as a 35 or 37's?? i know a 315 is compared as a 35.
    2006 Toyota Tundra SR5
    RCD 6" lift / 5100 bilstein rear shocks / 3" custom body lift / 17x9 Pro Comp 6001 chrome finish / RhinoLining / Husky Black Tool Box / Leer Ladder Rack / 35/12.50r17 Pro Comp Xterrains / Valor IDA-700W 7" WideScreen / AVE AV-1520 15.2" TFT/LCD Flip Down Monitor / 8" Infinity Reference 850w subs / Custom Fiberglass sealed enclosure / MB Quartz DSD216 Discus Components front and rear / Kenwood KAC819 Mono Amp / PPI5440 5 Channel Amp / Power Converter w/ audio/video input
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member Mazutoytundra's Avatar
    Join Date
    Oct 2006
    Location
    Da Big Island
    Posts
    469
    Liked
    0 times
    Images
    14
    Rep Power
    34
    Default Re: 325's = 35's or 37's???
    It all depends on what the aspect ratio is.
    That number you posted up is the width of the tire in millimeters. So 325=12.79" wide. The conversion from millimeters to inches is 25.4.
    The second number for a metric tire, ex: 325/75/16 is the aspect ratio. You have to take that percent number and times that with the width of the tire.
    ex: 325 x 75% = 243.75mm
    That number is your sidewall height. Now times that number by two because a tire has two sidewalls.
    243.75 x 2 = 487.5mm
    Now convert that to inches
    487.5/25.4 = 19.19 inches
    Now add that to the wheel height or the third number for the metric tire
    19.19 + 16 = 35.19 "
    That is the height of the tire.
    So a 325/75/16 tire is similar to a 35.19" x 12.79" x 16" tire.
    Got it?
    I hope I helped you out.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
  1. ABS and 35s
    By sic402 in forum 1Gen-Brakes
    Last Post: 11-15-2006, 01:05 PM
  2. 35's question
    By Zero10 in forum Tacoma
    Last Post: 11-06-2006, 12:53 PM
  3. 33's to 35's??
    By chrislloyd in forum Off-Roading
    Last Post: 11-04-2006, 01:32 PM
  4. Fitting 35's
    By fltnlow in forum Tires and Wheels
    Last Post: 05-20-2004, 04:08 PM
  5. Replies: 4
    Last Post: 11-07-2002, 10:45 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
