Fifth wheel towing with crewmax
+ Reply to Thread
Results 1 to 14 of 14
Thread: Fifth wheel towing with crewmax
  1. #1
    Join Date
    Feb 2007
    Location
    cupertino
    Posts
    50
    Liked
    0 times
    Rep Power
    9
    Default Fifth wheel towing with crewmax
    I was reading my owners manual and saw this on page 475.
    "Current fifth-wheel trailer designs are not compatible with Short bed (crewmax models)"
    thats a bummer as I was planning on getting one down the road (2-3yrs time frame)
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Jan 2008
    Location
    Enterprise, AL
    Posts
    41
    Liked
    0 times
    Rep Power
    36
    Default Re: Fifth wheel towing with crewmax
    Yes, I was originally looking at the crewmax untill the RV dealer told us that you needed at least a 6' bed to pull the fifth wheel that we wanted to purchase. I went with the double cab with the 6.5' bed. I'm very happy with it. I have a 4yr old and a 7yr old and they have plenty of room in the back seat. I'm 6' and have sat in the back with them a couple of times and was very comfortable.
  4. #3
    Join Date
    Sep 2005
    Location
    Upland, CA
    Posts
    585
    Liked
    1 times
    Rep Power
    76
    People are doing it with some sort of an extension. It's not recommended by Toyota tho.
    2007 SR5 CrewMax, SiLver w/5.7 V8
    >Bakflip Tonneau Cover.
    >Rampage Running Boards.
    >Heavy Duty 6 ft. Rubber Bed Mat
    out of my 2000 Tundra cut to fit!
  5. #4
    Junior Member 2MTTundras's Avatar
    Join Date
    Oct 2007
    Location
    Montana
    Posts
    56
    Liked
    0 times
    Images
    1
    Rep Power
    8
    Quote Originally Posted by avnut View Post
    YEP. Same reason I went with the D-cab. Had just bought an 07 26 ft Sandpiper 5th wheel and decided to upgrade to the 07 Tundra from an 06 for the towing ability, wanted the Crewmax but just wouldn't work. There's really plenty of room in the Double cab so I ended up just as happy with it.
    2007 Tundra 5.7 DC TRD Radiant Red, 2 1/2 Revtek w/ 33/12.50 R18 Toyo MT's wrapped around Chrome Ultra Goliaths, Bushwhacker pockets, Unichip
    2008 Tundra 5.7 CrewMax TRD, JBL, Sunroof, Slate Metallic - just got it, leaving it stock for now.
  6. #5
    Join Date
    Jan 2008
    Location
    New England
    Posts
    34
    Liked
    0 times
    Rep Power
    8
    Well, PullRite has a SuperSlide that supposedly works for CrewMax best. See:
    SuperSlide
    The thing about the Tundra is that you have to choose between the tow package or the payload package (you can't have both). So your 5th wheel choices may be limited no matter what bed you have.
    What I have noticed is that most 5th wheel trailers seem to be geared for two people. We have the crew max so that we can carry our three little ones with comfort. I have yet to find a 5th wheel that fits those little ones as comfortably. When the little ones move on, and we move up to the big fivers, then we can also replace our CrewMax with a regular cab Tundra.
  7. #6
    Join Date
    Jan 2007
    Location
    cochrane
    Posts
    34
    Liked
    0 times
    Rep Power
    9
    Just did a trial fit up with a Weekend Warrior 5th wheel today. WOW it was like the manufacturer used a crewmax to decide pin box positioning. Fits like a glove, with lots of clearance for turning. No off-set hitch or slider hitch needed. Can not comment on other trailer makes though.
  8. #7
    Join Date
    May 2007
    Location
    Florida
    Posts
    513
    Liked
    0 times
    Rep Power
    9
    is anyone towing a goosneck trailer with Crew Max?
    -Greg
    (Sold to) References: keninsb, BamaDave, Sweet Mercy, Daily-Tundra, Hootbro, andito77, sodar, kcpake, roadking3, TACOMA915, barna6vi, matrix77, bds13, msaltx07, guyjones10, Marky_Mark, lucentking, dbllung, goingnorth52, TeXas_TRD, Verchu , lestodd40@hotmail.com, ajbush@hughes.net
    more references: bimmerforums.com, caraudio.com, audiogon.com, ebay.com
    www.abcregeneracja.com
    ABC-Regeneracja: profesjonalna naprawa oraz regeneracja bloków i zaworów ABC zawieszenia Mercedes S, CL, SL
  9. #8
    Join Date
    Jul 2007
    Location
    oceanside, ca
    Posts
    20
    Liked
    0 times
    Rep Power
    9
    Quote Originally Posted by thumper-darryl View Post
    Please post pics and details on Weekend Warrior and hitch setup when delivered. Must be new '08 trailer?
    Thanks.
  10. #9
    Don't argue with an insomniac. Frankenstein's Avatar
    Join Date
    Nov 2007
    Location
    Northwestern Ontario
    Posts
    5,565
    Liked
    11 times
    Rep Power
    37316
    Quote Originally Posted by campertom View Post
    SuperSlide
    It's a trailer ideally set up for families. Sure, it's a bit big for the Tundra (see specs, below) but with air bags for the extra weight there's no doubt that this truck will handle it. The rated payload is NOT due to frame strength, rear axle size, braking ability, or towing power. It's due to suspension designed for ride, and inadequate tires; both easy to fix.
    Cougar Model 314EFS Specifications
    Weight 8350
    Carrying Capacity 3335
    Hitch 1525
    Length 35' 4
    Width 8'
    Height 12' 0
    Fresh Water 45 gal.
    Waste Water 28 gal.
    Gray Water 56 gal.
    LPG 60
    Tire Size 225/75D15D
    Rim Size 15 X 6
    Not all 5th wheels are set up for two people only
    [Frankenstein's Monster]
    Proud Member CBTMA
    Radiant Red
    Cold Weather Pkg and Block Heater. Brushed SS Stepboards, TS Sticker
    Tires: BFG All Terrain T/A KO LT265 65 R 18, Diamondback SE Tonneau Cover.
    Curt Front Receiver, custom 8" extension, & Warn 8000lb receiver mount winch back or front,
    Tekonsha Prodigy Brake Controller DSP 16,000 lb 5th wheel hitch Firestone Ride Rite 2445 Air Bags & TRD Rear Sway Bar (Best, Cheapest Mod!)
  11. #10
    Join Date
    Aug 2007
    Location
    houston
    Posts
    295
    Liked
    0 times
    Rep Power
    8
    Quote Originally Posted by PENER View Post
    ...Me
  12. #11
    Supporter cwit's Avatar
    Join Date
    May 2007
    Location
    keeseville ny
    Posts
    1,355
    Liked
    9 times
    Images
    3
    Rep Power
    914
    They make at least half a doz. different style hitches to tow with the crewmax. I would use any of them, that being said I tow with a dc and love it . I want to see the pin hitch on a weekend warrior. I would trade my slider hitch and change pin hitches for that set up.
    Charlie & Linda
  13. #12
    Join Date
    Jan 2008
    Location
    Enterprise, AL
    Posts
    41
    Liked
    0 times
    Rep Power
    36
    That couger fifth wheel is the same one we have I think. I can't remember our exact model number. It has a bedroom in the back for the kids. I pull it with the double cab no problems. I try not to pull it anymore than necessary with any of the tanks loaded, but I have, and can barely tell it's back there.
  14. #13
    Join Date
    Feb 2008
    Location
    Manchester, nh
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Quote Originally Posted by cwit View Post
    the only problem is the picture you uploaded is a double cab
  15. #14
    Supercharged Member FIVEPOINTSEVEN's Avatar
    Join Date
    Oct 2007
    Location
    Clearwater Beach
    Posts
    4,495
    Liked
    7 times
    Images
    17
    Rep Power
    31
    Quote Originally Posted by toyotaguy203 View Post
    Because he drives a DC and that pic is in his signature every time he posts.
    2015 Tundra 1794 Edition Crewmax 4x4
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
  1. Replies: 300
    Last Post: 07-22-2009, 08:41 PM
  2. Replies: 20
    Last Post: 02-25-2008, 05:55 PM
  3. More Info On The New 07 Tundra Crewmax
    By LBCBMW in forum Tundra
    Last Post: 02-13-2007, 05:27 PM
  4. 2007 Regional Option Combo Pricing - CrewMax
    By StatCoder in forum Tundra
    Last Post: 02-06-2007, 11:30 PM
  5. Replies: 3
    Last Post: 04-14-2004, 08:03 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
