Old 08-11-2007, 03:06 PM
MotownJG's Avatar
Dealer : Modesto Toyota World
2005 Toyota Tundra
Last Online: 11-24-2007 09:32 PM
MotownJG is on a distinguished road.
MotownJG's Photo Albums
Default REcommended First Travel Trailer?
I'm interested in buying a (probably) used travel trailer to tow with my Toyota Tundra Doublecab 2wdrive with tow package tand the 4.7L V8.
Any brand recommendations?
don't buy a trailer over _ years old?
Don't buy one?
Start with a cabover camper instead?
Apprecaite the responses.
John
John
2005 Tundra DC 2WD metallic silver w/Line X bedliner, hard tonneau cover, & amateur radio antenna on roof
Old 08-11-2007, 08:52 PM
FltTest's Avatar
Last Online: 07-06-2008 10:34 PM
FltTest is on a distinguished road.
FltTest's Photo Albums
Default Re: REcommended First Travel Trailer?
We really like our Outback by Keystone but the brand or type of trailer for you will depend a great deal on how you're going to use it. Things like number of kids, if any, regular trailer or toy hauler, and lots of other choices. Once you figure out what's important to you in a trailer then you can start narrowing down the models and brands based on what you're truck will tow. As far as used ones, if they've been maintained and everything is in good working order they can last a long time.
Mark
03 Expedition
Hopefully Tundra CrewMax Soon
Old 08-12-2007, 10:30 AM
Last Online: 05-29-2008 10:28 AM
1kzwoman is on a distinguished road.
1kzwoman's Photo Albums
Hi,
I answered this question for myself recently. I opted for a 17' Casita fiberglass travel trailer, ease of towing and resale value, as well a fitting my needs were key points of puchase. Check the casita forums as well as company website for more info.
Old 08-12-2007, 11:36 AM
mxsjw's Avatar
Jedi Ninja in Training
Dealer : Toyota of Puyallup
- Other - 2003 VW Passat,
Images: 10
mxsjw's Photo Albums
Please read my write up here in this thread...
New Travel Trailer
good luck!
Beer please!
Old 08-12-2007, 01:05 PM
HotRod8's Avatar
Lifetime Member
Dealer : Stampede Lexus Toyota
2003 Toyota Tundra,
1996 Toyota Corolla DX Plus
Last Online: 11-19-2009 10:49 PM
HotRod8 is on a distinguished road.
HotRod8's Photo Albums
I would suggest you shy away from a slide in camper unless it's a very light one. Those things are typically quite heavy and you will overload your rear axle. You also need to be very carefull of the weight of any trailer that you consider. In my opinion stick with a trailer that has a GVW less than the GCVW minus your trucks max GVW.
As the others have stated you need to know what you want to do with the trailer, where you will go, how many people, what length of trips, etc. Give this some serious thought, you don't want to buy the wrong trailer for your needs.
I have an Aerolite Cub, which is a hybrid travel trailer. This means that it has tent ends like a tent trailer with a hard sides like a conventional travel trailer. There are many manufacturers of Hybrids and they all have there advantages and disadvantages, I would suppose. The benefits, it is very light and gives us up to 4 full queen sized beds. I doubt there is another type of trailer that has that much sleeping capacity and can be pulled by a 1st gen Tundra. The cons, not good for cooler weather or in bear country.
Old 08-13-2007, 09:18 PM
Moderator
Dealer : Performance Toyota
2008 Toyota Tundra Slate SR5 4x4,
2005 Toyota Sienna XLE
Last Online: Yesterday 06:52 PM
Images: 23
tomhole's Photo Albums
Go to an RV show and walk through all the floor plans. I always tell folks, buy the floor plan you like (antually, the one your better half likes), from the dealer you like at the price you can afford. The right floorplan from a good dealer will go a long way towards enjoying your new trailer.
When you look at weights, look at trailers with a GVWR less than 6000 lbs. THe dealer will tell you you can tow anything. I was at a dealer yesterday getting a new switch for my slider. Looked at a couple of travel trailers. We like toy haulers and he showed us one with a GVWR of over 9000 lbs. Said I could tow it, no problem. I said my max tow limit was 6800 lbs. He said "no problem, that trailer is 5600 lbs dry. No way you're gonna load more than 1,000 lbs of stuff in it." Ok, ignore all salesman. Look for a trailer with a GVWR less than 6000 lbs. (I have the exact same truck as you do). The GVWR is ALWAYS on a sticker on the front roadside (driver's side, per se) on the outside.
As far as brands, I have been watching rv.net for nearly 4 years now and have not seen a brand pop out as stellar or horrible. At least not in the affordable price ranges. They all have about the same workmanship (average to shoddy, depending on the day it was built) and nearly identical appliances and pieces parts inside.
1. Floorplan
2. Dealer
3. Price
We have a 23' Hybrid travel trailer (Rockwood Roo 23SS) that we love. I am max'd out on all my weights by my Tundra does fine for us. I had to stop by a big RV dealer to get a part for my trailer and had the family with me. I came out after getting my part and they are crawling through all the travel trailers. I get the dreaded "Honey, can we tow this?" question and knew I was doomed. We'll probably be getting a new trailer next spring, if I know my wife.
Anyway, I would recommend joining rv.net and surfing the forums over there. It's free and loads of good people willing to give all of their opinions.
Tom
Old 08-13-2007, 09:49 PM
Dealer : Carson Toyota Scion
2003 Toyota Tundra
Last Online: 09-30-2008 12:03 AM
rcbuzzb is on a distinguished road.
rcbuzzb's Photo Albums
The lighter weight toyhaulers are versatile. We got one from Carson.
They have a whole range of them.
Carson Trailer - Home of the Fun Runner RV Sport Trailer
Old 08-17-2007, 04:45 PM
Dealer : American Toyota
2007 Toyota Tundra Limited CM
Last Online: 11-23-2009 05:10 PM
vikecowboy is on a distinguished road.
vikecowboy's Photo Albums
I pull an Outback 25RS-S (our first trailer) with my 05 DC with no problems. I pull at high altitude and in mountains.
Outback Division of Keystone RV manufacturers of Recreational Vehicles and Towable PopUps.
Old 08-19-2007, 11:53 AM
wolfie410's Avatar
Dealer : Darcars Toyota of Frederick
Last Online: Yesterday 08:51 PM
wolfie410 is on a distinguished road.
Send a message via MSN to wolfie410 wolfie410's Photo Albums
We pull a 25' Mallard Lite from Fleetwood. You can definitely find a substantially better deal from a private seller, as opposed to a dealer. You just need to be careful on your inspection.
Old 08-28-2007, 02:07 PM
MotownJG's Avatar
2005 Toyota Tundra
WOW. Thanks for all the replies - great advice. I knew it was a good idea to ask here.
California Ssate fair is on now and they usually have RV's somewhere on the grounds that I'll try and walk through for floorplans,etc.
John
John
Towing your travel trailer...??? Silver Doug 1Gen-Tundra 8 06-14-2007 09:04 PM
Towed my new Travel Trailer ZBoomer Tundra 47 05-31-2007 01:05 AM
05 Tacoma and travel trailer hillbillym16 Towing 3 09-16-2005 08:59 AM
What Front Pads for Towing? '01 Sequoia Jettix2 Towing 8 08-30-2005 04:08 PM
Travel trailer towing ?????? Stlmatt Towing 2 07-13-2004 08:01 AM
