Old 08-19-2007, 11:10 PM
Dealer : Scott Nichols Toyota
2002 Toyota Tundra
Last Online: 05-26-2008 10:56 PM
rchaney99 is on a distinguished road.
rchaney99's Photo Albums
Default 2002 Tundra - Towing capacity question.
Hey all -
I have a 2002 Toyota Tundra Access Cab V8. Came with a tow package on it. I am wondering what a reasonable weight to tow is? I have a 1988 Layton (Skyline) Funtime trailer that weights over 6,000lbs loaded. Has anyone towed anything this heavy on a regular basis? If so, what did you have to do to make the towing experinace a good one with this kind of weight? I have a Tekonsha P3 I just installed. That is all I have done so far. No air bags for shocks, etc has been done. Thanks for any help.
Old 08-20-2007, 12:15 AM
Only Toyota for me's Avatar
Dealer : Karl Malone Toyota
2008 Scion tC Daughter's car
Last Online: 11-21-2009 03:00 AM
Images: 44
Only Toyota for me will become famous soon enough.
Default Re: 2002 Tundra - Towing capacity question.
Originally Posted by rchaney99 View Post
Hey all -
I had an 02 A-C as well. It towed my 6200lb (dry) 5er okay, but it was a little much for it.
Is the 6000lbs fully loaded w/ water & everything?
Oh, i had an extra leaf spring added to mine & it helped. Airbags would be a good choice though. I also had an intake, & 3" exhaust & 50 series flowmaster on it.
It will do it okay for you and you have the best brake controller on the market. Just be sure to follow the maintenance requirements to a tee. And change the tranny fluid about every other oil change.
Old 08-20-2007, 09:17 AM
rambrush's Avatar
Ever the explorer
Dealer : Findlay Toyota Scion
2006 Toyota Tundra,
2003 Toyota Avalon
Last Online: Yesterday 07:29 PM
Images: 83
rambrush will become famous soon enough. rambrush will become famous soon enough.
Send a message via AIM to rambrush rambrush's Photo Albums
Have you actually weighed this? empty and loaded and scaled it to see how much weight is on each axle? What is the tounge weight?
I take it you do have a WDH ?
Air bags are good addition as well.
I would believe you are pushing the envelope with that unit
ARB Sahara,Front Springs www.coilsprings.com Firestone Ride-rites 2245, Hell roaring technology dual battery setup, Wrangler dual battery tray, (2) Odyssey PC1200T batteries, Tru-speed recalibrator, Toyo open country MT 265x75x16's, USA Spec PA-15,AmSteel 7/16 x 90' synthetic winch line, 100' AmSteel 7/16 extension rope, Fumoto quick drain #F103N.
Future Ideas
Winch Warn 16.5ti coming soon..
Sliders Stubbs
Lockers ARB
Viar 460c w twin 2.5 gal tanks
255 x 85 x 16's
4:56 gears
Skid row skid plate package
Old 08-20-2007, 10:00 AM
Herbicidal's Avatar
Just a Herbicidal maniac.
2001 Toyota Tundra,
2008 Toyota Yaris Sedan 'S' Flint Mica,
2009 Toyota Corolla 'S' Barcelona Red
Last Online: Yesterday 11:43 PM
Images: 150
Herbicidal's Photo Albums
I have a 2001 4x4 and our 26 foot Outback TT (weighed at the scales trimmed out for camping) comes in at 5,600 lbs. Our longest trip to date was to Yellowstone this past June. Just about 900 'towing' miles each way. ZERO problems. Since our return, we have also done two coastal camping trips. The first was about 120 miles each way and the most recent was up to the Redwoods above Eureka, about 200 miles each way. Last year we did two trips to Oregon and some more coastal trips. The year before that, we towed down to southern CA and back, this included towing over the infamous section on I-5 known as the "Grapevine". We also do an annual trip to Mt. Lassen every October, another 200 miles or so each way. I try not to let the Outback get dusty from lack of use.
I have JBA headers and the Unichip pnp module. I use a Drawtite hitch with with Reese (same company) 1,000 lb WD bar and their HP Dual anti-sway setup. I also have a Prodigy brake controller and larger tranny cooler with A-pillar mounted temp gauge with the sending unit in the tranny pan. The tranny temp normally runs about 165-180 while towing during the summer months. I usually tow between 55 and 60 mph. On the steep grades I watch the tach, not so much the speedo. I find running at or slighly below 4,000 rpm works quite well. The hottest I saw it run on the trip to Yellowstone was 215 degrees, but that was climbing a pretty good grade and the temp dropped rapidly on the downhill side. I'm also running Amsoil synthetic in the tranny. I now have 110,000 miles on my Tundra. All's good!
Like rambrush suggested, get it weighed (axles and tongue) so you know exactly how much you are towing vs a guesstimate. Personally, I would not go much above what I tow now with my truck. Don't carry water in your trailers holding tanks unless you must, water weight adds up fast!
Happy camping!
7000 mile trip with 3000 mile towing with Tundra and Outback BaseCamp Towing 20 02-25-2008 08:55 PM
NY Times - Behind the Wheel | 2007 Toyota Tundra StatCoder Tundra 0 05-07-2007 10:20 AM
Tundra, Tacoma, 4Runner - V6 Abilities Towing Capacity JohnJCronin Towing 8 02-25-2005 10:07 PM
2002 Tundra Trailer Harness Questions hf1001 Towing 8 01-04-2005 03:46 PM
HID auxiliary lowbeam photos nhparrot Electrical & Computer Systems 1 03-28-2002 09:06 PM
