Old 09-07-2007, 08:12 PM
Dealer : Toyota of Glendora
Last Online: 09-16-2009 09:32 PM
the shop is on a distinguished road.
the shop's Photo Albums
Default Any one towing their Tundra
Hi, I'm new to the Tundra forum and wondering if anyone out there are towing their truck behind ther motorhome?
Old 09-07-2007, 08:13 PM
Dealer : Midwest Toyota
2007 Toyota Tundra,
- Other - 2007 Honda Odyssey
Last Online: 03-11-2009 12:23 PM
impilot is on a distinguished road.
impilot's Photo Albums
Default Re: Any one towing their Tundra
Don't think you can...at least with the 4x4 version. I am pretty sure I remember reading that in the owners manual.
2007 5.7L Tundra CrewMax Ltd 4x4 in Radiant Red
Old 09-07-2007, 08:28 PM
I tow it know, 07 crewmax 4/4 . I had to put a drive line disconnet on it to tow 4 down, Just wondering if anyone else tow theirs and had any problems. I took it to OR. and back,the only problem I had was a dead battery when I got there. You have to leave the steering unlocked and hope you remember to turn off every thing. Bill
Old 09-07-2007, 08:57 PM
Dealer : Toyota of Muncie
2003 Toyota Tundra,
- Other - 2000 Accord
Last Online: 10-13-2009 01:11 AM
lukewaterhouse is on a distinguished road.
lukewaterhouse's Photo Albums
I read somewhere that the Tundra cannot be towed as a dingy. Think it was on the Toyota website in there FAQ. Some cars like the Corolla are ok to tow and others are ok to tow as long as you let the drive components cool after a short trip (30 miles?). But as far as the Tundra is concerned, don't dingy tow it. Use a vehicle trailer.
Roads are for people without 4x4
2003 Tundra Sr5
4x4
4.7L Iforce
90,000 miles
Tonneau Cover
Tow Hitch
.45 Taurus 24/7 hidden under the front console tray
Old 09-07-2007, 09:01 PM
Only Toyota for me's Avatar
Dealer : Karl Malone Toyota
2008 Scion tC Daughter's car
Last Online: Today 01:03 AM
Images: 44
Only Toyota for me will become famous soon enough.
Don't do it, use a trailer.
Old 09-07-2007, 09:27 PM
Thanks for the feed back, I'v bin towing the tundra 4x4 since 01 with no problems. I'm now towing the 07. The drive line disconnect works great and is the only way you can tow the tundra .
Old 09-18-2007, 10:58 AM
ctw41's Avatar
Dealer : Lighthouse Toyota Scion
2000 Toyota Tundra Limited 4WD,
- Other - 07 Jayco Motorcoach
Last Online: 11-14-2009 10:03 PM
ctw41 is on a distinguished road.
ctw41's Photo Albums
Any reason you can't tow a manual transmission in nuetral? What about a 4wd with the transfer case in Nuetral? I'm considering upgrading my Tacoma 4 door auto trans to a Tundra manual trans. I'm unbolting the driveshaft and rebolting it to a bracket I installed inorder to disconnect the driveline now.
Old 09-18-2007, 10:08 PM
If you have a manual trans and a manual transfer case there should be no problem. I use the Remco drive line disconect.
Old 09-18-2007, 10:53 PM
jkd jkd is offline
Dealer : Prestige Toyota
Last Online: 10-08-2009 06:12 PM
jkd is on a distinguished road.
jkd's Photo Albums
Yessir, #1 reason is because the trans input shaft is not turning but the output shaft is so the pocket brgs between the input shaft and output shaft stub are turning abnormally fast and don't get lubed. #2 Since the input shaft isn't turning, the countershaft gear is stationary so all the gears on the mainshaft are stationary although the mainshaft is turning fast. If you tow far enough, most all of these gears end up galded to the mainshaft---translation-BIG bucks for repairs. When towing, the powerflow is directly opposite of what takes place when the engine is driving the vehicle. Hard to explain, maybe Google up a pic of any transmission showing the powerflow and it might make it more clear.
With that said, you can sometimes get by towing a manual if enough gear lube works it's way into the right places, but a guy is definitely taking a chance. Generally, the larger the trans the more sure you are to damage it.
http://sports.webshots.com/album/180135797kNEIOu
2007 LTD DC Blue Streak (her's)
2007 LTD DC Salsa Red (his)
'91 F250 5spd diesel with ATS Turbo
Old 09-18-2007, 11:02 PM
guntech's Avatar
Benny Hill
Dealer : Prestiqe Toyota
2003 Toyota Camry,
Images: 71
guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything.
guntech's Photo Albums
Dude, you have any pictures of your 07 Tundra hooked to the back of your motor home ???? That must really turn heads.
I think what everyone is getting to is that you will probably get away with what you are doing (the way you are set up) for a while, but it will probably bite you in the butt later with excess tranny wear.
Old 09-18-2007, 11:23 PM
jkd jkd is offline
jkd's Photo Albums
Nope, he said he has a Remco unit, his trans and transfer case are out of the picture.
Old 09-30-2007, 11:40 PM
Here's a couple of shots of the set up. The 07 is a little heaver than the 01, but it still works fine.
Any one towing  their Tundra-116-1633_img.jpg   Any one towing  their Tundra-116-1635_img.jpg
Old 10-01-2007, 02:06 AM
Dealer : Longo Toyota
Last Online: Yesterday 02:11 AM
cmax4fishing is on a distinguished road.
cmax4fishing's Photo Albums
with taht being said what happens when a 4x4 gets stuck in the sand and gets towed out? are u damaging anything? is it dependant upon the distance being towed is when damage occurs?
Old 12-12-2007, 06:02 PM
Dealer : John Eagle Sport City Toyota
Last Online: 09-15-2009 11:53 PM
willieboy is on a distinguished road.
willieboy's Photo Albums
It is all about heat. So for short distance, you are fine, but long distances = bad news. Go with a remco or equivalent drive line disconnect.
Willieboy
'08 Tundra Crewmax SR5, 2x4, Pyrite, JBL + A.R.E CX Topper
'02 Suburban LS
Old 12-12-2007, 09:58 PM
Thats what I have been using.
07 tundra price anyone post this yet? dbuschbaumjr Pricing and Dealers 17 10-30-2007 08:19 AM
Tundra Towing herb.keller Towing 2 06-29-2007 05:03 PM
Question zerofear66 1Gen-Tundra 3 11-26-2006 10:26 AM
Toyota Unveils Long Bed Versions Of All-New 2007 Tundra Full-Size Pickup Truck TundraSoul Toyota, Scion & Lexus News 0 09-18-2006 01:42 PM
Tundra Towing Experiences rcdave Towing 4 03-24-2005 02:27 PM
