Re: Being to careful?
Hi,
IMHO, I don't think you being too careful, especially if your going to fully load it and use it a fair amount. The tundra can handle stopping that trailer without brakes, just keep in mind your stopping distance will be increased. I would get the brakes with it since it could be the difference between avoiding an accident and having one in emergency stop scenerios where someone runs a light or cuts you off.
I would see what type of brakes you can get with the trailer, if hydraulic/pressure activated brakes are all you can get on it, the brake controller is of no use to you.
If the trailer does have a "brake by wire" actuator, and you install the brake controller, you won't interfere with towing things that have a 4 pin, as your 7 to 4 convertor only propigates the signals for: brake lights, running lights, and turn signals.
Hope this helps.
2006 Tundra DC, 20" EVO Velociti Wheels, Limited, TRD
2001 Tundra AccessCab, Limited, TRD
1993 Toyota Pick Up, Extended Cab
