Old 09-24-2007, 02:38 PM
Dealer : Maplewood Toyota
Last Online: 10-30-2009 06:15 PM
John2001 is on a distinguished road.
John2001's Photo Albums
Default 2001 Tundra scaled weights
I went across a CAT scale to check my weights and WD settings before a 2 week trip to Colorado. Full gas tank and propane. Empty waste tanks. Otherwise loaded and ready for 2 weeks out.
scale numbers:
truck and trailer: steer 2960, drive 2660, trailer 3840 gross 9460
truck only: steer 3020, drive 2540, gross 5560
The thing that has me confused is when I set up the Equilizer the front end squat about 1/4" and the rear about 3/4" yet the scale shows the front end lighter with the trailer connected. The only explanation I can think of is if the scale op weighed while I was out of the truck during the truck and trailer pass. Any other ideas? Also the front GAWR is almost to the limit without the trailer. (3160 per the door sticker) The truck with passengers had maybe 600 lbs on it. Is this normal?
Thanks
2006 Tundra 4x4 V8 SR5 AC
ScanGauge II
Old 09-24-2007, 11:16 PM
RockyMtnRay's Avatar
2003 Toyota Tundra
RockyMtnRay's Photo Albums
Default Re: 2001 Tundra scaled weights
scale numbers:
Thanks
You're probably ok.
First, you being out of the cab on the trruck/trailer combined weighing would certainly account for all of the the lighter weight on the front end. Actually, since over 60% of the front seat driver/passenger weight goes onto the front suspension, the true combined rig weight on the front is likely more like 3075~3100 lbs.
Second, as a point of reference, the front axle weight of my '03 4WD with just me (~195 lbs) and maybe 50 lbs of cargo in the cab is around 2650 lbs. Depending on how many people (especially largeish adults) and cargo you had in your cab, your ~3000 lb front weight is within reason.
Third, don't take those scale weights as accurate to the exact pound. I've had my truck and trailer weighed three times, with roughly equal loads each time, and the per axle weights have varied as much as 200 lbs. I'd guess those scale weights (and accuracy of any given reading) are probably only good to about plus/minus 2 or 3% (or plus/minus about 60~90 lbs).
Ray
Old 09-25-2007, 02:53 PM
I think the scale accuracy at these light loads is probably the biggest unknown. Somewhere I read they are 60000 lb scales, so we are talking about 2% of their full scale reading when weighing a Tundra. Anyway I happy to see the weights all fall into the reasonable range for my 2001. The trailer pulled great, other than some of the long grades in your beautiful state where we hummed along in 2nd. Thanks for the reply Ray.
ScanGauge II
5.7L swap murfdaddy Tundra 62 11-08-2008 05:06 PM
Tundra CrewMax Reveal - Remarks by Jim Lentz TS Support Toyota, Scion & Lexus News 0 01-07-2007 04:38 PM
Toyota Stages World Debut of All-new 2007 Tundra CrewMax At The 2007 North American.. TS Support Toyota, Scion & Lexus News 0 01-07-2007 04:33 PM
Question zerofear66 1Gen-Tundra 3 11-26-2006 10:26 AM
Engine noise, 2001 Tundra????? Doug S Engine & Drivetrain 6 04-22-2004 07:40 AM
