Old 10-01-2007, 05:32 PM
Dealer : Steet Toyota of Johnstown
2001 Toyota Tundra,
2001 Toyota 4Runner SR5 w/moon roof
Last Online: 04-27-2009 05:31 AM
dirtytundra is on a distinguished road.
dirtytundra's Photo Albums
Default Towing set up on my truck
My 2007 order was damaged in transit. They had to go with a 2008 which is great but I want my truck....
I need some input about a couple of dealer installed towing options that are on the Toyota build/price site and were included on my 2007 order.
On my '07 I ordered a Tekonsha prodigy brake control system and Reese weight distribution hitch bar (Max Hitch Wt. 1200 lbs.; Max GTW 12,000 lbs.)
Anyone have any experience with these? Should I get them? I need to tow my Kubota L-48 backhoe (filled tires) and dump trailer. About 11,000 pounds.
You help is appreciated.
FYI there may be some surprises with the '08 but that is all I am allowed to say.
Old 10-01-2007, 05:36 PM
guntech's Avatar
Benny Hill
Dealer : Prestiqe Toyota
2003 Toyota Camry,
Images: 71
guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything.
guntech's Photo Albums
Default Re: Towing set up on my truck
Tow capacity is 10,100 pounds.
Old 10-01-2007, 05:42 PM
PACER's Avatar
Dealer : Uebelhor & Sons Toyota
2009 Toyota Tundra,
2009 Lexus IS250 AWD
Last Online: Yesterday 09:55 PM
Images: 11
PACER is on a distinguished road.
PACER's Photo Albums
I hope there is an increase in the tow rating on the 2008 Tundra for your sake because 11,000 lbs. is more than what the 2007 Tundra is rated for. Congratulations on the new truck whenever you get it.
Old 10-01-2007, 05:49 PM
dkizerian's Avatar
Dealer : Mark Miller Toyota
1997 Toyota T100,
2007 Toyota Tundra DCSB SR5 Slate
Last Online: 11-04-2009 04:17 PM
dkizerian is on a distinguished road.
dkizerian's Photo Albums
Honestly, if you're towing that much regularly, why not go with a 3/4 ton or better that was designed and rated for that much? there is a pretty big difference between a good 1/2 ton truck, and a 3/4 ton Diesel.
The prodigy brake controller is great. You can probably find it for cheaper than at the dealer
A good weight distribution hitch is a necesity.
Old 10-01-2007, 06:01 PM
2007 Toyota Tundra,
2006 Scion xB White "Toaster",
- Other - E-350 XLT Extended
Last Online: 10-29-2009 03:29 PM
rignerd is on a distinguished road.
rignerd's Photo Albums
Thumbs up Re: Towing set up on my truck
I would get both the brake controller and the weight distributing hitch. You are pushing the limit for half ton trucks like the Tundra and they will get you a little safety margin. That assumes that your trailer has electric brakes, if not then don't waste your money on the controller.
Old 10-03-2007, 08:28 PM
2001 Toyota Tundra,
Thanks for the help.
Old 10-03-2007, 08:38 PM
Dealer : Rice Toyota
2001 Toyota Tundra,
2007 Toyota Tundra Silver Sky DC w/XSP
Last Online: 10-18-2009 01:07 AM
reidsworks is on a distinguished road.
reidsworks's Photo Albums
The Tunrdra is rated at 10100lbs regardless of having weight distributing hitch. Exceeding the rated tow capacity violates the law for one thing and could void your warranty.
Old 10-03-2007, 08:54 PM
L R H's Avatar
Dealer : Lagrange Toyota
2007 Toyota Tacoma R/CAB SR5 PreRunner
Last Online: 11-23-2009 12:52 AM
L R H is on a distinguished road.
L R H's Photo Albums
If you do decide to get the prodigy from the dealer, make sure the dealer tech does not install it until you point out exactly where you want it, since there is no exact designated spot to mount it. Toyota parts does handle the prodigy, but I bet dealer cost is higher than one could get it for, and since it is plug & play you could do it yourself (if you choose) As for the weight distribution bars Toyota does not handle them as far as I know, so they will prob just run down to the local parts store and get them; so do they know exactly what part you need or want? If you do not wish to do it yourself, why not try a good reputable trailer/RV dealership as they do this stuff every day, and no wiring/plumbing is being done to your truck, so there is no warranty problems. I have worked at dealers before and have seen the problems that can sometimes happen when dealers are asked to do things outside of there normal tasks.
EDIT: when you say weight distribution weight bars; are you talking about the ball mount, or the spring bars to spread some of the load to the front axle?, Either way, the trailer should be present to know what amount of drop is required for proper trailer tongue height
Old 10-03-2007, 09:11 PM
mc71454's Avatar
2007 Toyota Tundra DC 5.7 TRD 4x4
Last Online: 11-04-2009 12:51 PM
Images: 9
mc71454 is on a distinguished road.
mc71454's Photo Albums
And if the unfortunate happens like an accident, you will be ticketed and automatically placed with some degree of fault...
What about all the weight of the mud that will be on the trailer and the Kubota from time to time. Probably should not be using a Tundra for your intended purpose.
Tom B.
2007 - DC TRD 4x4, Slate, 5.7 SR5, Toy-Tech 3", 285/75/18 Toyo's Open Country AT , Bedrug, Truxedo Tonneau, N-Fab Nerfs, Eclipse NAV, MB Quart, RFosgate, etc., Snow-Way, TRD Sway Bar
1971 Chevy Monte Carlo Street/Strip - 10.31 @ 130
1970 Chevelle 454 LS6 Power
1987 Olds 442 - Stock
Racing Web Page
Old 10-03-2007, 09:28 PM
CrewMaxCrushinU25's Avatar
Dealer : Toyota Scion of Hollywood
Last Online: 09-21-2009 06:43 PM
CrewMaxCrushinU25 is on a distinguished road.
CrewMaxCrushinU25's Photo Albums
listen man the tundra was built like a 3/4 ton dont sweat the 11000 lbs i towed a 13000lb more less, 33' ft Larson 330 Cabrio boat like 3 different times with my boss the people at the boat storage said man i think u need a dually i told em man i think u need to hook that big boy up so we can go in the water was cake pulling it out on 4hi was nothing the tundra is a champ
CrewMax Crushin U SR5 4x4 TRD
Old 10-03-2007, 09:29 PM
flinchlock's Avatar
Last Online: 10-21-2008 07:28 AM
flinchlock is on a distinguished road.
flinchlock's Photo Albums
Originally Posted by L R H View Post
As for the weight distribution bars Toyota does not handle them as far as I know...
"Tekonsha Prodigy Brake Control System" AND "Reese Weight Distribution Hitch Bar" => Toyota Tundra Truck Accessories
Mike
2007 Tundra Reg Cab Long Bed 4x4 4.7L
Old 10-03-2007, 09:54 PM
asianflava's Avatar
Dealer : Classic Toyota Scion of Round Rock
2001 Toyota Highlander,
2007 Toyota Tundra CrewMax
Last Online: Today 03:03 AM
asianflava is on a distinguished road.
asianflava's Photo Albums
Check online stores and I'm shure you'll find the P3 cheaper. I got my P3 for cheaper than a Prodigy plus no tax and free shipping. Installation was also a breeze, thanks to the prebuilt harness.
Old 10-03-2007, 11:28 PM
L R H's Avatar
Mike
flinchlock, thanks for pointing that out.........
That is why I added my edit question at the end, I wasn't sure if he was talking about the weight dist spring bar setup, or just calling the ball mount by that name.
dirtytundra most likely knows what he is talking about, but sometimes the dealer people do not, especially if dirtytundra tells the salesperson and the salesperson tells the service and then the parts dept. Things get lost in the translation.
I saw the early promo Tundras at the dealers back in Feb/Mar, the ones pulling the heavy trailer, on 4 separate occasions, and only once was there a spring bar setup installed. Don't know how many of these trucks were on the road, the trucks could have been the same one every time for all I know, but only once was the tow setup correct and legal. So even Toyota does not know how and when weight distribution bars are need, or didn't care. It is good that Toyota offers the complete pkg, but I bet they charge a premium for it.
Old 10-04-2007, 07:58 AM
2001 Toyota Tundra,
Thanks for the heads up about controller location. Anyone with pics showing theirs? I trust the dealer so I am going to leave it to them. Already met personally with the parts and service guys.
It is a weight distribution bar that as I understand it helps spread the load down the frame. Weight is close - depends on how much fuel is aboard and how close my estimate is for the filled tires (17.5L-24R4 & 10-16.5R4 because someone might ask). Tractor weight is only 7,760 dry, but my dump trailer weighs 4,350.
Most of the time I would tow it with my regular equipment trailer. Once a year or so I would need to use the dump. Want to be prepared since I know I will end up doing it.
Old 10-04-2007, 09:45 AM
mxsjw's Avatar
Jedi Ninja in Training
Dealer : Toyota of Puyallup
- Other - 2003 VW Passat,
Images: 10
mxsjw's Photo Albums
My P3 location, I ordered an extra dash panel in case I screwed this one up or decide to remove the controller.
Full install here...Tekonsha P3 Modded Dash Install
Beer please!
Truck Tents???? hikeside 1Gen-Tundra 25 06-16-2009 11:21 AM
5th Wheel Towing mrbreez Towing 65 02-28-2009 06:56 PM
TRD Spare Tire Diff From Set of 4 on Truck Daytripper Tundra 16 10-01-2007 04:25 PM
Imagine you are shopping for a NEW truck... TundraMaxxer Tundra 14 02-12-2007 03:05 AM
Drum vs. Disc for towing dsrtrcr01 Towing 5 03-23-2006 05:25 PM
