Originally Posted by deebie47
Anybody out there got any tips for safe, proper towing of an 8400 lb. (loaded), 26' travel trailer. I have a 2008 double cab, 4WD, Limited? You know - tow mode or not, cruise control, engine braking, which gear for best performance and MPGs? Thanks in advance
Good WDH is a necessaty.....equilizer, hensley arrow. Also you need a good inertia type brake controller like the prodigy or p-3. 10 ply tires should be on the list also, and air them up to 60psi all around. Also be sure you have at least 10-15% tongue weight which would be 840-1260lbs.
Tow mode----yes.
cruise control----no except for downhill. This will provide you with the engine braking automatically.
I use S-5 when i tow, it stays out of 6th that way & on the freeway seems to be the right gear.
Best mpg?---stay under 65mph.
