Re: Trailor lighting problems
Green is right turn signal & yellow is left and that is the standard color code with all trailers and vehicles. Brown is side marker/park/running lights and white is ground, also industry standard. Can't get much more simple than that. If the tow vehicle has brake lights that are separate from the turn signal lights, an adapter is required. A very good ground between the tow vehicle and trailer is required or else trailer lights won't work correctly.
'07 RCSB 5.7L SR5 Silver Sky Metallic (The Silver Bullet) Yep....it's gotta HEMI
Never argue with an idiot. They will bring you down to their level and beat you with experience!
