Old 05-10-2008, 07:05 PM
JJB's Avatar
JJB JJB is offline
Dealer : Toyota Scion of Roswell
Last Online: 09-02-2009 11:26 PM
JJB is on a distinguished road.
JJB's Photo Albums
Default Prodigy P3 - doesn't turn off?
I just installed a Tekonsha Prodigy P3 controller in my Tundra. To make it easier, I ordered the 3040-P Toyota Brake Control Harness.
I plugged it in, and everything seemed good. Except it doesn't turn off. Seems this harness tapped into the battery connection, rather than switched power.
Did I get the wrong adapter? Or is there a way to turn it off? I didn't see that mentioned in the manual.
Also - this adapter harness had two white (ground) wires. One went from the back of the controller to the mating connector in the truck. The other white wire was a ring terminal I suppose for grounding the controller. Isn't the ground supplied through the harness, and therefore doesn't require an additional chassis ground?
2008 Tundra DC-Black 2WD SR5, 2004 Jeep Rubicon, 1998 Jeep Grand Cherokee 5.9LTD, 2008 Honda Pilot EX-L/Nav
Old 05-10-2008, 09:34 PM
Blackdogs's Avatar
Guest
Dealer : Star Toyota
2005 Toyota Tundra
Last Online: 06-25-2008 01:16 PM
Blackdogs is on a distinguished road.
Blackdogs's Photo Albums
Default Re: Prodigy P3 - doesn't turn off?
JJB:
Your brake controller is wired directly into the battery and bypasses the ignition switch. Think about it, would you want the brakes on your trailer NOT to work if you turned off the ignition or the truck started rolling without the key in it? The prodigy will turn off automatically after 15 to 30 min. and it will turn back on if you activate the brake pedal even with the ignition off.
Old 05-11-2008, 01:11 AM
core64's Avatar
Dealer : Norwalk Toyota
2005 Toyota Tundra Limited 4x4,
2008 Toyota Sienna Limited AWD
Last Online: 10-12-2009 10:00 PM
Images: 4
core64 is on a distinguished road.
core64's Photo Albums
Mine doesnt stay on for 15 mins, I would say more like 5-10 mins, it may be different for every unit. Turn you engine off, then check it after 30mins, it should be off by then. If it is still on after 30mins you might wanna call Tekonsha customer service.
Old 05-11-2008, 08:54 AM
JJB's Avatar
JJB JJB is offline
JJB's Photo Albums
Thanks all... I didn't leave it on long enough to see it time out. I'll plug it back in and be patient.
Oh, and I saw another thread discussing the extra white ground wire. I'll be looking for a good grounding location for that today.
Old 05-11-2008, 06:47 PM
Dealer : Magic Toyota
Last Online: 06-24-2009 10:00 PM
quarque is on a distinguished road.
quarque's Photo Albums
JJB - where did you buy it? Price?
Old 05-12-2008, 07:36 AM
JJB's Avatar
JJB JJB is offline
JJB's Photo Albums
Tekonsha P-3 Trailer Brake Controller - Proportional 90195 : Trailer hitch bike rack and trailer hitches - etrailer.com
Old 05-12-2008, 12:22 PM
asianflava's Avatar
Dealer : Classic Toyota Scion of Round Rock
2001 Toyota Highlander,
2007 Toyota Tundra CrewMax
Last Online: Today 03:03 AM
asianflava is on a distinguished road.
asianflava's Photo Albums
I got mine here, it's a little cheaper:
Tekonsha P3 Prodigy Series Trailer Brake Control
When I bought it, there was a $20 rebate from Tekonsha so I got it for $107, which made it cheaper than a Prodigy. You also get free shipping.
Last edited by asianflava; 05-12-2008 at 12:23 PM. Reason: Forgot about free shipping
Old 05-13-2008, 10:29 PM
thanks JJB and asianflava
Old 05-22-2008, 09:16 PM
GraetWhyte's Avatar
Dealer : Toyota Of Fort Worth
2007 Toyota Tundra DCab Ltd 4x4 Silver
Last Online: 09-25-2009 11:22 AM
GraetWhyte is on a distinguished road.
GraetWhyte's Photo Albums
I installed a "Pull to Open-- Push to Close" type circuit breaker. If the my P3 doesn't shut off I can manually open the circuit. Also I don't have to power it when not using it.
Old 06-02-2008, 10:18 PM
Dealer : Toyota of Tampa Bay
Last Online: 09-25-2009 10:11 PM
montecarlo31 is on a distinguished road.
montecarlo31's Photo Albums
I picked my P3 up for 115 out the door (i.e. FL 6% sales tax). I think that's a good deal. I also got my 20 dollar mail in rebate so it was really 95 bucks out the door. That included the harness for the truck but not installed.
