Old 05-13-2008, 12:03 PM
Dealer : Germain Toyota Scion of Sarasota
2003 Toyota Tundra,
2003 Toyota Camry
Last Online: 08-29-2009 06:37 PM
kingbert99 is on a distinguished road.
kingbert99's Photo Albums
Default Trailer Sag on 2003 Tundra w/TRD Pkg
Hey gang,
I recently purchased a toy hauler and seem to have a sag in my trailer set-up that I can't remedy. The dealer set-up had a little tail dip in my truck and they claime that once loaded with toys, the weight would distribute more evenly and I'd be good. However, my toy hasn't been purchased yet and will only be a lightweight jon boat for bass fishing. As a result, I lifted the hitch slightly. I'm at the upper limits of the hitch and have raised it to the point where the trailer tongue jack can't reach the ball unless I put a block under the jack. I have managed to reduce the sag a little but still think I have room for improvement.
I've tried attaching some photos I took recently. I don't like the fact that even with a WD/sway bar set-up I still get the pronounced "dip" in my tail. Could part of it be the suspension on the TRD pkg just isn't stiff enough?
I'm considering installing air-ride/air-lift bags to stiffen the tail up a bit but want to make sure that's the right move. Am I addressing the symptom instead of the disease?
Many thanks!
KB99
Trailer Sag on 2003 Tundra w/TRD Pkg-tundra-with-trailer-1.jpg   Trailer Sag on 2003 Tundra w/TRD Pkg-tundra-with-trailer-2.jpg
Old 05-13-2008, 10:21 PM
Dealer : Magic Toyota
Last Online: 06-24-2009 10:00 PM
quarque is on a distinguished road.
quarque's Photo Albums
Default Re: Trailer Sag on 2003 Tundra w/TRD Pkg
Sag is inherent with TT's of any kind. Most WD hitches can remove some or all depending on the tongue weight. I'd get the air bags. They work. They get high praise on the forums. They are cheap (<$300). They are adjustable through an external air valve so inflate/deflate is very easy. You can remove them if you want/need to. They can lift up to 3000 lbs.
Old 05-13-2008, 10:37 PM
Tomace's Avatar
Dealer : Richmond Hill Toyota
2003 Toyota Tundra
Last Online: 11-19-2009 03:42 AM
Tomace is on a distinguished road.
Tomace's Photo Albums
I would look at adding a new leaf spring or two.
tom
Old 05-14-2008, 08:22 AM
Herbicidal's Avatar
Just a Herbicidal maniac.
2001 Toyota Tundra,
2008 Toyota Yaris Sedan 'S' Flint Mica,
2009 Toyota Corolla 'S' Barcelona Red
Last Online: Today 11:35 AM
Images: 150
Herbicidal's Photo Albums
I looked at your pictures but I don't see any weight distributing (WD) bars. Do you have some and I just can't see them?
I use 1,000 lb (rated) bars for towing our Outback 26RS. Tongue is over 800 lbs, so the WD bars are a necessity! Once adjusted properly, my truck and trailer sit nice and level together.
Old 05-14-2008, 12:55 PM
2003 Toyota Tundra,
2003 Toyota Camry
The bars get lost in the photo but they're installed. I was supposed to receive an Equalizer brand hitch with the purchase of the trailer but the generator platform on the trailer got in the way of the Equalizer's mounts. The hitch that's on there doesn't have a sticker that I can read anymore, so really, there's not telling what brand I have. That's a whole separate subject.
Now, I will say that I don't think I'm getting optimal use out of the WD system. When there was more pronounced sag in the beginning, I raised the hitch up and canted the ball back for more of a diagonal posture. I don't think I've hit the "sweet spot" between having the right hitch height and tilt. Either way, I think I need to beef my suspension up a little.
Old 05-14-2008, 03:46 PM
Herbicidal's Avatar
2001 Toyota Tundra,
Images: 150
Depending upon the model of hitch and so forth, you may be able to upgrade the 'weight' of those bars. If they are 750 lbs models, they may be undersprung for your use. Can you get a tongue weight of your trailer when it's loaded and I mean actual, not the one provided by the manufacturer? Judging by your pictures, the WD bars are not transferring enough weight back onto the front of your truck. I'm still not convinced that you need to upgrade your rear suspension unless you really want to.
Old 05-18-2008, 12:15 PM
Blackdogs's Avatar
Guest
Dealer : Star Toyota
2005 Toyota Tundra
Last Online: 06-25-2008 01:16 PM
Blackdogs is on a distinguished road.
Blackdogs's Photo Albums
I agree with Herbicidal.
Th obvious question is: With the gen set on the tongue, what is your tongue weight at the hitch ball? It looks like the tongue weight is exceeding the capacity of your WDH hitch/truck suspension. I also do not see your WDH spring bars in the photos. They should be clearly visible underneath the hitch. The problem with just beefing up the rear suspension is that this does not solve the excessive tongue weight problem. Even if the truck looks "level" too much weight on the hitch ball will remove weight from the front tires and severely affect your steering and tire wear. The uneven weight distribution can also affect trailer stability.
Also what is the weight of the trailer? Those toy haulers can be scarily heavy.
Old 05-26-2008, 11:36 AM
Life Member
Dealer : Toyota of Weymouth
2002 Toyota Tundra,
2006 Toyota Sienna
Last Online: 11-19-2009 10:33 AM
Remerson is on a distinguished road.
Remerson's Photo Albums
Another option is to install a roadmaster active suspension system. It is a bit cheeper than airbags and you never have anything to adjust. You simply hook up and go. I have them installed to handle the large amount of firewood that I collect on a regular basis, and I couldn't be happier. They also reduce sway quite a bit (no need for a Helwig) without giving a harsh ride.
Snowplowing with a Tundra
Adversity is an opportunity for heroism
