Originally Posted by VaTundra1
So I have been towing a pop-up camper for the past few days, and will be going on a weekend trip for Memorial day...
I took a look at the rear tires and it seems that the outside tread of the tires are getting more wear than the rest of the tire. Current tire pressure is 33-35 and the tires were rotated about 1,300 miles ago.
My question is: What is a safe rear tire pressure when towing a camper like I have.
i didn't see any mention of what tires you are using?check the amount of max psi on the tires and go from there usally your standard non d or e rated tires are only good for around 50 psi. i would think if you have standard you might try 40 and see how that works.
have fun on your trip you guys are brave going on memorial day.
i usually go the week after. much more relaxing and less hassel on the roads.
