Old 06-02-2008, 02:14 PM
STMARTIN84's Avatar
Dealer : Thomasville Toyota
2003 Toyota Tundra
Last Online: 06-11-2008 11:13 AM
STMARTIN84 is on a distinguished road.
STMARTIN84's Photo Albums
Default Towing Question
OK, the wonderful topic of towing again. I have a 2003 Tundra access cab, 2WD. I have a camper that is rated at 7000 GVWR. Can this be towed by my tundra for short flat surfaces? Also, my driveway is a steep incline for about 150 to 200 feet, can this be backed up to store it?
2003 SR5 Tundra
K&N Cold Air Intake
Flowmaster Exhaust (Y-cut off)
Bull Bar w/Hella Driving Lights
Bilstein HD 5100 Shocks
Aftermarket External Trans Cooler
Old 06-02-2008, 02:35 PM
STMARTIN84's Avatar
2003 Toyota Tundra
Default Re: Towing Question
this is more specs on the TT
Hitch Weight: 650 lbs. Dry Weight (inc. hitch): 5,059 lbs.Gross (GVWR) weight: 7,000 lbs.
2003 SR5 Tundra
K&N Cold Air Intake
Old 06-03-2008, 12:14 AM
Only Toyota for me's Avatar
Dealer : Karl Malone Toyota
2008 Scion tC Daughter's car
Last Online: 11-21-2009 03:00 AM
Images: 44
Only Toyota for me will become famous soon enough.
When you say camper, i assume you mean a travel trailer right?
The tow capacity for your truck is 7100 lbs (i think, but you may want to verify this in the owner's manual.)
The GVWR is total weight including trailer, not what the trailer itself weighs. ULVW is what the trailer weighs dry. So if the ULVW is 5000 lbs, you can put 2000 lbs worth of stuff in the trailer.
Yes, it can be towed with your tundra but you must have a good WDH and brake controller. I also recomend at least a 6-ply LT tire for the truck.
Backing up your steep driveway could be a challenge because you don't have 4wd lo, but depends on the hill. I'd do a test tow before you buy it.
Old 06-03-2008, 07:49 AM
STMARTIN84's Avatar
2003 Toyota Tundra
Yes a travel trailer. Thank you for the reply. I do have 6 ply tires and a brake controler. If I don't carry any of the tanks full or maybe just a little fresh water (enough for road emergencies) I think I should be ok. I actually had a desiel that I pulled this trailer with and I couldn't afford the gas anymore so sold it. I've pulled this trailer with my tundra before, but then bought that desiel now I'm back to the Tundra. Missed it! I'm nervous about the driveway though.
2003 SR5 Tundra
K&N Cold Air Intake
Old 06-03-2008, 07:50 AM
STMARTIN84's Avatar
2003 Toyota Tundra
Only Toyota for me.....I've noticed you have a Jag Travel trailer. So do I. This unit I'm reffering to is a 29JB hitch pull with a WDH.
2003 SR5 Tundra
K&N Cold Air Intake
Old 06-04-2008, 03:10 AM
Images: 44
I do have a Jag, but it's a 5er & it's a pretty nice one but i've had a couple issues with it & i'm concerned how it's going to hold up. It's only 2 years old so we'll see i guess.
Good luck with your setup & let me know how it works out.
