Go Back   Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Towing
Towing Discussions related to towing and towing products.
This is a discussion thread titled "installing trailer brakes/controller on tundra?", within the Towing forum, part of the Technical & Vehicle Assistance Forums category.
Old 06-05-2008, 07:04 PM
Dealer : GO Toyota
wyzzard's Photo Albums
Last Online: 10-02-2008 08:30 PM
wyzzard is on a distinguished road.
Default installing trailer brakes/controller on tundra?
i'm picking up a utility trailer tomorrow, figure i should get some brakes as i'm hauling over a ton...has anybody installed electric brakes on a trailer and a brake controller on the tundra? i'm wondering how hard this is. i am mechanically-inclined but i don't know jack about trailers and brakes...is it pretty straightforward and about how much time is involved?
dealer wants around $250 for labor - but if i can get this done in under a couple of hours, i'll do it myself...
Old 06-05-2008, 07:30 PM
bilztrd's Avatar
Dealer : Carson Toyota Scion
bilztrd's Photo Albums
Last Online: Today 01:10 PM
bilztrd is on a distinguished road.
Default Re: installing trailer brakes/controller on tundra?
Brake controllers for the truck ... easy under an hour. Plug & play with the correct harness. Search for details
Trailer brakes....Depends on the trailer. I would probably leave that to a trailer shop.
Depends on the axles etc.
Old 06-05-2008, 08:16 PM
TundraBay's Avatar
Dealer : Wayne Toyota
2007 Toyota Tundra,
TundraBay's Photo Albums
Last Online: 10-07-2008 10:52 PM
TundraBay is on a distinguished road.
Many trailers come with electric brakes. It might be cheaper if you're buying to get it with brakes already on than to pay shop time to have them installed. Could be a big job to to that yourself, involving new axles, wheels, etc.
If the trailer you get already has electric brakes, you only need the controller. I got Tekonsha Prodigy. Some people bought the Tekonsha P3 but you only need that if your trailer has electrically actuated hydraulic brakes, and very few do. The install was very simple. I soldered the wires from the Tundra harness to the appropriate wires on the brake controller -- took 15 minutes for that. Then I removed the kick plate on the driver's side - - two minutes. Plugged it together -- 10 seconds. Put the plate back on -- couldn't get the little white plastic slidy things to work (20 minutes of farting around), came into the house, did a search on TS, found the answer (remove the plastic things from truck, slide onto cover, re-insert into truck: 30 more seconds, screwed the brake controller above the gas pedal and above my right knee -- 5 minutes, used tie wraps --4 more minutes, and it all works!
Radiant Red
2007 Double Cab Limited
w/Graphite Leather Interior
Cold Weather Pkg and Block Htr. Brushed SS Stepboards,
Upgraded Tires: BFG A/T KO LT265 65 R 18,
Curt Front Receiver, with Warn 8000lb winch back/front mountable,
Diamondback Tonneau Cover.
Tekonsha Prodigy Brake Controller
DSP 16,000 lb 5th wheel hitch
Firestone Ride Rite 2445 Air Bags
Old 06-05-2008, 08:29 PM
martino4's Avatar
Dealer : Country Hills Toyota
2007 Toyota Tundra CM LTD 4x4,
- Other - 2007 Toyota Rav4 V6
martino4's Photo Albums
Last Online: 10-07-2008 10:51 PM
martino4 is on a distinguished road.
Send a message via Skype™ to martino4
What TundraBay said. If you buy also this RVWholesalers.com , Brake Controllers , Wiring Harnesses , Toyota Brake Control Wiring Harness for Prodigy Brake Control - 3040
you don't have to worry about soldering. Just plug and play.
Here is where i put mine.
black crewmax ltd red rock int
http://i193.photobucket.com/albums/z...4/IMG_0113.jpg
Old 06-06-2008, 01:05 AM
asianflava's Avatar
Dealer : Classic Toyota Scion of Round Rock
2001 Toyota Highlander,
2007 Toyota Tundra CrewMax
asianflava's Photo Albums
Last Online: Yesterday 10:23 PM
asianflava is on a distinguished road.
What bil said, controller install is easy in this truck, took me under an hour. The trailer brakes should be left to a trailer shop. Some axles can be retrofitted with brakes some can't.
If you are mechanically inclined, you can probably order a new axle from Dexter and install it yourself. That may be what the shop planned on doing anyway.
Old 06-06-2008, 06:30 AM
cwit's Avatar
Dealer : New Country Toyota
2007 Toyota Tundra,
2006 Toyota Camry-Solara black moon roof
cwit's Photo Albums
Last Online: Today 02:37 PM
cwit is on a distinguished road.
I have found the cheapest place for axle parts to be Northern tool.
Charlie
Old 06-06-2008, 10:13 AM
Dealer : Hudiburg Toyota Scion
mdlab's Photo Albums
Last Online: 10-05-2008 09:19 AM
mdlab is on a distinguished road.
Prodigy is the way to go with plug/play wiring harness for Toyota. I have a knack for screwing up the easy jobs, but even I did this in less than 30 minutes on my '06 Tundra. Do not pay a dealer for install, you can do this!
2006 Tundra DC SR5 4x2
Leer 100XL Cap
Lake Ridge, VA
LinkBack to this Thread: http://www.tundrasolutions.com/forums/towing/135113-installing-trailer-brakes-controller-on-tundra/
Posted By For Type Date
Towing on Tundra Solutions Forums | BoardReader This thread Refback 06-14-2008 10:18 PM
