Just curious to see who is doing any towing in the new Tundras with a 6" lift. My wife and I are thinking about getting a 21-23' toy hauler (probably around 8k lbs loaded) and I need to figure out what I need to get my lifted truck ready.
What and how much do you lifted guys tow?
__________________ You might be a bulldog if.... you're too lazy to beg.
______________________________________________
2008 Toyota Tundra Ltd DC 4x4
Options: TRD, Nav, XM Sat
Suspension: Fabtech 6" Performance Lift
Wheels/Tires: 35x12.50 BFG M/T KM2 on 18x9 Pro Comp 6088
Extras: AMP Research Steps
Future: Line-X, custom springs, Dynamat and audio upgrades.
Might want to ask the same question on rv.net as there are some folks towing with lifted trucks there. I can't offer any advise as I don't have any experience in this area.
Mines a first gen. Tundra with a 6" lift. I tow a 5,600 lb (weighed on the scales) 26' Outback travel trailer. I had to get a new 'deep drop' shank to account for the lift. That was really the only towing mod I had to make after the lift. I already had a Prodigy brake controller. Eventually I added a Reese dual cam HP anti-sway unit to my weight distribution hitch and that was night and day better than the orginal friction style anti-sway device. What a pile that was! I also went to a larger tire (315x17x16) and I regeared my truck to 4.88's which then brought me back to slighly lower gearing than stock.
I don't know if you've gone to larger tires, but if you did, that will affect your towing performance. I don't know if the aftermarket has caught up and provided new gears for the 2nd gen. Tundras. But with a trailer of that weight, I would strongly suggest regearing if you have larger than stock tires. Your tranny will thank you!
Addtionally, I would recommend a tranny temp gauge so you know exactly how hard you're working it. The very best place to put the sending unit is in the tranny pan. I bought an Auto Meter gauge, sending unit and 'A' pillar mount. Again, I don't know if the aftermarket has a similar setup for your truck.
Hope this helps.
Hope this helps.
Thanks for your thoughts. Unfortunately, there are no aftermarket gears for the newer Tundra available yet, but I plan on upgrading as soon as they are available. My limited already has a trans temp gauge, so I'm good there too.
