Old 08-05-2008, 07:54 PM
Dealer : Carousel Toyota
Last Online: Today 08:47 AM
horsehauler is on a distinguished road.
horsehauler's Photo Albums
Default Wiring back up lights on trailer
I have a 2000 tundra SR5 4wd and tow a physically large 7,000 lb twin axel slant load horse trailer. I want to add two lights to the tail end of the trailer for backing up at night in unlighted drives and low visibility areas etc.
While poking around in my OEM wiring harness I found an abandoned/extra yellow wire with grey tracer that is on the trucks back up light circut for the tail lights.
It is hot when you put the trans in reverse but my concern is it is a very light guage wire and I want to mount a couple of clear fog or after market driving lights. thought it would be great to wire directly to the reverse switch and have them on automatically but am concerned about overloading the harness and having a melt down if I have them on too long.
Perhaps LED'd would be a better choice for low amp draw but I haven't found any that are bright enough. I would like to get flame throwers to really light up the area I am backing into.
recomendations would be appreciated.
Old 08-07-2008, 08:29 PM
Geodude's Avatar
Dealer : Bel-Air Lexus Toyota
2001 Toyota Sequoia,
2001 Toyota RAV4
Last Online: Yesterday 07:33 PM
Geodude is on a distinguished road.
Geodude's Photo Albums
Default Re: Wiring back up lights on trailer
I wired the centre pin on the 7-pin Bargman connector to the backup lights on the Sequoia, and then ran about 32' of wire to a set of el cheapo mini fog lamps on the back of my travel trailer. IIRC I used about a 12 gauge wire if for now other reason than I had a bunch of it lying around. It has worked well over the past two years. I think I have pix of the lights on my site at www dot paushe dot com
I consider mine backup lights to warn people that a big box is coming their way, so they point straight back. A couple of friends mounted theirs farther forward and on the side of the trailer, just in back of the mud flaps and pointing out to the sides in order to get better light when backing up at night.
2001 Toyota Sequoia SR-5 4WD
2001 Toyota Rav4
2005 Starcraft Antigua 305QBS travel trailer
Our Excellent Camping Adventures!
Old 08-26-2008, 02:58 AM
Dealer : Toyota of Plano
2007 Toyota Tundra,
- Other - 2007 Mercedes C230
Last Online: Today 03:00 PM
Images: 76
07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything.
07DCwhiteSR5's Photo Albums
not sure what the abck of your trailer looks like but several boat trailer manuf'ers use LED light housings for backup lamps. ski boats mainly. but for what its worth, ive seen regular filement bulbs used as factory equipment on boat trailers for backup lamps also and they dont have any special wiring, they plug into the stock harness just the same so its apparently good enough for that as well as the poster above.
Old 04-09-2009, 08:39 PM
2001 Toyota Sequoia
Last Online: 06-29-2009 10:16 AM
jd50i is on a distinguished road.
jd50i's Photo Albums
If you feel the yellow/grey wire is too small for the lights, use it to control a relay and you can use a bigger voltage supply wire.
Old 04-09-2009, 10:14 PM
funfinder4's Avatar
Dealer : Atkinson Toyota
Last Online: 11-09-2009 02:41 PM
Images: 4
funfinder4 is on a distinguished road.
funfinder4's Photo Albums
Not sure about the older Tundra's but my '06 has this circit built into the factory 7-way plug already. I believe it's fused seprate of the trucks back-up lights too.
FunFinder4
'05 2500 Dodge DC 5.9L Cummins, cheap X2
'05 Jayco Jayflight 27BH TT
'06 Tundra DC TRD; Prodigy brake controller, Cyberdyne transmission gauge, ScanGauge II; Sold
'05 T-160 Shadow Cruiser TT; Sold
http://community.webshots.com/user/Funfinder4
Old 04-09-2009, 11:31 PM
BAD BONEZ BJ's Avatar
AKA blackmbj
Dealer : Priority Toyota
1993 Toyota Truck,
2006 Toyota Sienna XLE in Pear White,
2003 Toyota Tundra AC Limited 4WD,
1998 Toyota 4Runner Trade-In,
2004 Toyota Sienna Trade-In,
2004 Toyota Prius Trade-In,
2006 Toyota Highlander HV Trade-In,
1998 Toyota Celica Sold,
- Other - '81 Tercel - Sold
Last Online: 11-22-2009 01:17 AM
Images: 570
BAD BONEZ BJ will become famous soon enough. BAD BONEZ BJ will become famous soon enough.
Send a message via AIM to BAD BONEZ BJ BAD BONEZ BJ's Photo Albums My eBay
That'd be the way I'd do it. Then you can run whatever type of light you want.
BJ
2003 Tundra 4.7L V8 Access Cab Limited 4WD
w/ all factory packages, Black Onyx 202-rebadged. was stock 31K on 5/9/05, now 56K
Performance: DYNOed at 208 HP and 272 TQ
* UNICHIP (broken) * AEM Brute Force Intake * AEM DryFlow Filter * K&N DryCharger * AirRaid TBS * JBA Titanium-Ceramic Headers * JBA Y-Pipe * Gibson CAT-Back Dual Extreme Exhaust * PulseStar Pulse Plugs * Fitch Fuel Catalyst System * Optima D35 Yellow Top * Argus Battery Bug * Fumoto F103N Oil Drain Valve * RP Oils *
Exterior:
* Extang Full-Tilt Tonneau * Bedrug * Topline Tailgate Step * Mr. Gille Upper & Lower Billet Grille * WAAG Bumper Guards, front & rear * HT Side Step Nerf Bars * AVS Hood Protector * WeatherTech Vent Shades * JDM Black Taillights * TurnSmart Solar-power Mirror Turn-Signals * Altec 48" Line-of-Fire LED Light Kit * Altec 53" Screamer Amber Side Marker LED * PIAA Backup/Work Lights * 35 % Tinting * Bully LED Third Brake/Cargo Light *
Interior:
* Gentex Auto Dimming Compass/Temp Rear View * Garmin's Nuvi 660 GPS * Scan Guage II * Passport SR7 Radar/laser shifter *
Wheels/Tires:
* Moto Metal M0951 Gloss Black 17 in. Alloys * SpiderTrax 1.25" Wheel Spacers * Goodyear Fortera TripleTred radials P275/60R17 *
Suspension:
* Bilstein HD Shocks, F&R * Hellwig Rear Sway Bar & Helper Springs * TCS Poly Steering Rack Bushings * Wheeler's Front Sway Bar Bushings * Timbren SES Kit, Front & Rear *
Brakes:
* TRD Big Brake Kit (front) *
BAD BONEZ BJ
