Go Back   Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Towing
Old 12-30-2008, 12:19 PM
Dealer : Miller Toyota
1995 Toyota Tacoma Sold,
2001 Toyota Tacoma Sold,
2005 Toyota Tacoma Sold,
2004 Toyota Corolla Commuter,
2008 Toyota Tundra CM 4x4,
1993 Toyota 4Runner Needs HG
Last Online: 11-04-2009 05:20 PM
ck25 is on a distinguished road.
ck25's Photo Albums
Default Towing thoughts - tractor
I've sold my 97 Dodge 3/4 ton diesel so I'm curious to know how well a 2008 Tundra CM 5.7 4x4 will tow my tractor. (I already know it has the power) Attached below is a pic of my setup of my dodge and trailer, I only ever used a antisway friction bar and it towed/trailered fine. On average I tow about 2-3 times a year and the trip is short compared to others about about 80 miles 1 way.
Not sure if an Equilizer or WD hitch would be needed.
Empty weight of the trailer I'm guessing is about 1500lbs (8'x14' car trailer)
Tractor weighs about 4000lbs
Therefore that puts me at about 5500lbs give or take.
I see alot of positive discussions about "Air Lift" bags and I did some research looking threw some older posts. I was hoping to find a releated search on a topic that discussed if you tow in excess of "X" weight then it would be advised you use "Air Lift" bags with the Tundra, as well the same topic with a weight distribution hitch.
If you could provide your thougths it would be helpful. My best answer is going to be hook it up and tow down the road a couple miles to see how it does.
thanks for your input.
http://s462.photobucket.com/albums/q...Tractor001.jpg
Old 12-30-2008, 01:36 PM
Dealer : Mark Miller Toyota
2007 Toyota Tacoma
Last Online: 11-05-2009 07:13 PM
Corban_White is on a distinguished road.
Corban_White's Photo Albums
Default Re: Towing thoughts - tractor
How far and how often do you tow it?
Old 12-30-2008, 02:30 PM
d-lo's Avatar
Dealer : Champion Toyota Scion of Austin
Last Online: 11-06-2009 02:17 PM
d-lo is on a distinguished road.
d-lo's Photo Albums
ck-
As infrequently as you tow, I don't think you need any additional equipment. I don't see any safety concerns with that set-up. If that trailer is loaded properly I don't see a need for sway control or weight distribution. Bags help take the weight off of your suspension to prevent sagging, but you should be well within payload with that trailer, so I don't see you sagging too much. I have Air Lift LiftLoader 5000 bags in my truck and LOVE them, but I do a lot of towing, and at night, which exacerbates the sagging problem because of inadvertently brighting people. The rear end does feel more solid, but my tongue weight can push 1,000 lbs. Does the trailer have brakes?
I'd say that you're safe for road testing and if it does sag and/or you feel squishy in the back, bags will help. With the size, shape, and weight of your trailer, I don't think a WDH or sway control will give you a benefit that is worth the cost and hassle.
2008 Tundra Crew Max Limited 4x4 5.7L
Sunroof
20" Wheels
Skid Plate Enhancement
XM
Anodized Aluminum 'T' Shifter
Stebel Nautilus 110dB Compact Air Horn
Air Lift LoadLifter 5000 Air Springs
Pulling:
2007 Fleetwood Evolution E3
Tekonsha P3 Brake Controller
a
Old 12-30-2008, 02:42 PM
scottnmos's Avatar
E PLURIBUS UNUM
Dealer : Nye Frontier Toyota/Scion
2001 Toyota Tacoma Xtra Cab....SOLD,
2008 Toyota Tundra 5.7 4x4 SR5 Crew Max,
2004 Toyota Tundra 4.7 4x4 DC SR5-Sold,
1993 Toyota 4Runner SR5 Wheelin' Machine
Last Online: Today 11:38 AM
scottnmos is a superior contributor. scottnmos is a superior contributor. scottnmos is a superior contributor. scottnmos is a superior contributor. scottnmos is a superior contributor. scottnmos is a superior contributor. scottnmos is a superior contributor. scottnmos is a superior contributor. scottnmos is a superior contributor.
scottnmos's Photo Albums
You should be fine. My biggest issue would be with the tongue weight. If your truck sags too much, then I would get airbags. I dont think that airbags are a necessarily total weight related issue so much as a tongue weight issue. You're good...
Old 12-30-2008, 02:51 PM
ck25's Photo Albums
Thanks for the feedback
The Dodge never really sagged much with this load unless I scooted the tractor all the way to the front of the trailer (never towed like that)
The trailer has brakes on both axles, I had a great Tekonsha Prodigy brake controller. However it went along with the truck when it was sold, I see some like the P3 so I'm looking into that model.
Old 12-30-2008, 03:43 PM
d-lo's Avatar
d-lo's Photo Albums
I have a P3 and have to say it's the best I've ever seen. Get one!
Sunroof
20" Wheels
XM
Pulling:
a
Old 12-30-2008, 10:45 PM
jdubh's Avatar
Dealer : Bert Wolfe Toyota
2008 Toyota Tacoma,
2008 Toyota Tundra Limited 4x4 DC BlueS,
- Other - 2005 Accord EX-L
Last Online: Today 11:59 AM
Images: 9
jdubh is on a distinguished road.
jdubh's Photo Albums
I just towed a 26'7" 5500lbs travel trailer from Columbus to Cincinnati and didn't use the w/d or antisway. Brought back a 35'10" 9000lbs travel trailer...needed it on that one, but not the small one.
2008 Blue Streak Metallic Double Cab 4x4 Limited 5.7L
2009 Outback 310BHS Sydney Edition 10,060lbs 35'10"
Prodigy, Retrax, Equal-i-zer, Load Lifter 5000
Old 12-31-2008, 01:11 AM
Last Online: 12-31-2008 01:13 AM
Jeremy Miller is on a distinguished road.
Jeremy Miller's Photo Albums
Really the good idea to towing the car or truck..I had towing of my old truck last month. i got more than i except...So i think this is the best option for it.
Old 12-31-2008, 11:44 AM
2007 Toyota Tacoma
Thanks d-lo! I must have been a lot more tired than I thought when I read the OP.
Old 01-01-2009, 03:30 AM
asianflava's Avatar
Dealer : Classic Toyota Scion of Round Rock
2001 Toyota Highlander,
2007 Toyota Tundra CrewMax
Last Online: Yesterday 03:20 AM
asianflava is on a distinguished road.
asianflava's Photo Albums
Your trailer looks like mine but mine says that it is 1700lbs. I initially had the car further on the nose but backed it off to center the weight on the front trailer axle. The extra length of the trailer ahead of the axles would still give plenty of the required nose weight. I didn't use an anti sway, air bags, or w/d hitch but it was pretty stable even with heavy crosswinds. Car haulers don't have the side profile as box trailers. The only "extra" equipment I have is a P3 brake controller.
Trailer 1700lbs + Car 4200lbs still managed 14.2mpg from Atlanta to Orlando
