Old 03-22-2009, 12:45 PM
Dealer : Toyota of Whittier
Last Online: 10-20-2009 10:05 PM
Rex Wayne is on a distinguished road.
Rex Wayne's Photo Albums
Default Tundra ... can't find 5th wheel to fit..
I can not find any 5th wheel trailer that is within the specs. available on my 2008 SR5 DC.. with the tow pkg..
I can have a GCVW of 13,500 .. and the truck GVW is 6700 ...
and the door sticker says it can only load 1350 .. (people, gas, cargo, and guitars)
Does anyone know of a 5th wheel that would not push the Tundra over it's factory set limits...
(my insurance agent told me to stay within the factory limits, or I could be on my own if I were in an accident.. He said the weights and limits are now one of the first things that they look at to try and void your coverage)
I want a 5th wheel , but I want to be "legal" ...
Rex..
Old 03-22-2009, 01:22 PM
Dealer : Earnhardt Toyota
Last Online: 06-20-2009 02:33 PM
RLitwin is on a distinguished road.
RLitwin's Photo Albums
Default Re: Tundra ... can't find 5th wheel to fit..
You are going to have to get a really small light 5th wheel, they are out there. It just isn't worth it when you can get everything you need/want in a standard TT while staying legal.
Old 03-22-2009, 06:17 PM
cwit's Avatar
Dealer : New Country Toyota
2007 Toyota Tundra,
2006 Toyota Camry-Solara black moon roof
Last Online: Today 04:03 PM
Images: 3
cwit is on a distinguished road.
cwit's Photo Albums My eBay
You could get another agent my wife is my agent and she says your agent is not right. I tow a crossroads Zinger that the factory says is a half ton camper. If your agent were right a good one third of campers would be in trouble.
Charlie & Linda
Old 03-22-2009, 08:23 PM
TundraBay's Avatar
Dealer : Wayne Toyota
2007 Toyota Tundra,
Last Online: 11-16-2009 10:10 PM
TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One.
TundraBay's Photo Albums
Or more.
Towing thread:Tundra as Tow-Mobile: 1,200 miles, 12,000 lbs, 10 MPG
[Tundra Bay]
Proud Member CBTMA
Radiant Red
Old 03-22-2009, 11:16 PM
Only Toyota for me's Avatar
Dealer : Karl Malone Toyota
2008 Scion tC Daughter's car
Last Online: Today 03:00 AM
Images: 44
Only Toyota for me will become famous soon enough.
Rex..
It sounds like to me Rex, that you have the 4.7L motor. Is that correct?
My 5.7L DC TRD has a GCWR of 16000 lbs, and GVWR is 7100 i beleive. Really, IMO the main thing you need to be concerned about is the GAWR listed in the camper section of your manual, when concerning a fifth wheel. It's wise to NOT exceed these ratings.
The GAWR of my truck is 4150 rear and 4100 front, which is 8250 total. I have a 6200lb (dry) 5th wheel trailer with actual weights being 7500 mostly loaded for camping. I have actually weighed this setup. Please see thread in this section titled ' 5th wheel actual weights ' to see more.
I am within my GAWR of the truck with this trailer, that has a 1250lb pin weight.
It is not hard to exceed the 7100lb GVWR of this truck with a 5er. But if you stay within the GAWR you will be perfectly safe.
Yes, you should be able to find a 5er that would work. But with your truck having those ratings, i don't know.
Here is mine, before i lifted the trailer.
Old 03-23-2009, 12:11 PM
Thanks for the input ..
I have a question, Charlie .... did you have to replace the tail light assy, because the pressure of that heavy 5th wh. pin weight blew out the tail light ???
Seriously, thanks for the input ... I am going to talk to my agent(s) real hard.
Rex
Old 03-23-2009, 06:33 PM
I appreciate the opinions...
Here is what I am looking at .... what do you think?
'08 DC (Tundra Grade) 4.7 V-8 ................. GVWR = 6700 lbs
Truck's GCVW .................................................. ..=13,500 lbs
Truck's GAWR Rear .............................................= 4,000 lbs
Truck's Tow Capacity (per factory window sticker...= 8100 lbs
Truck's Payload Capacity(door pillar 1340).window sticker ..=1535 lbs
Truck with full tank of gas, 2 people, 5th wheel hitch
(and factory accessories....) ............................... =6140 lbs
Trailer ....(KZ 265RS) ......................empty weight ....=5845 lbs
Trailer hitch (pin) weight ....................................= 880 lbs
I will have Hellwig Air Bags, and Hellwig Rear Stab. Bar.
I will never travel with full water tanks..
But I will have propane bottle full (just one full)
Well, what do you think ..... am I going to be OK with this set up?
thanks,
Rex
Old 03-23-2009, 11:36 PM
Images: 44
'08 DC (Tundra Grade) 4.7 V-8 ................. GVWR = 6700 lbs--Over 320lbs, but IMO perfectly okay with a 5er.
Truck's GCVW .................................................. ..=13,500 lbs--1515lbs under so you are a-okay if you don't load the trailer heavy. But you need to be aware of the fact the trailer will be easily 1k lbs over dry weight mostly loaded.
Truck's GAWR Rear .............................................= 4,000 lbs--Okay.
Truck's Tow Capacity (per factory window sticker...= 8100 lbs--Okay here
Truck's Payload Capacity(door pillar 1340).window sticker ..=1535 lbs--Is this what you are going off of? If you are,you're over weight by 320 lbs. But IMO you shouldn't go off this with a fifth wheel. Go off GAWR, which states what the truck can ACTUALLY handle.
I will have Hellwig Air Bags, and Hellwig Rear Stab. Bar.--IMO, this does increase the payload capacity along with D rated tires.
I will never travel with full water tanks.. I try to as well when i know i'll have water available where im going.
But I will have propane bottle full (just one full)--You should keep both full, but this isn't much weight.
thanks,
Rex
Note above responses in red.
To answer your question; yes you'll be just fine. You're barely above GVWR, and below GAWR for your truck. Well below GCWR as well. I would tow this trailer with no worries if i were you.
The most important weights to stay within for safey reasons are; GAWR and GCWR when towing a fifth wheel.
Old 03-24-2009, 12:11 AM
Thank you for your response ..
Is there a way to figure out what is the weight on the rear axle..
Without actually putting the rear of the truck on a scale?
Rex
Old 03-24-2009, 02:59 AM
Images: 44
Rex
Had to go back a few pages here to find your answer.
Yes, but you need to go to a cat scale and weigh the setup. You could have someone else tow the trailer there and meet up to weigh it. They actually have 3 pads on the scales; front, drive axles, and trailer. When i weighed mine, i think i didn't pull far enough ahead.
Empty, the tundra DC is about 2600 lbs on the rear axle. So you have about 1400 lbs you could haul ( 5er or camper that is ).
I bumped the ' fifth wheel actual weights ' thread so you can read up on it. Some good info there.
Old 03-24-2009, 09:29 AM
Thank you for all your help..
Rex
Old 03-24-2009, 05:30 PM
Dealer : Toyota of Temecula Valley
2007 Toyota Tundra,
2005 Scion xB,
2001 Toyota Tacoma XCab 4X4
Last Online: Today 11:20 AM
svedspx is on a distinguished road.
svedspx's Photo Albums
Just for comparison, I just picked up a 5th wheel a couple of weeks ago. Here are the specs after I weighed in at a Cat Scale. All the weights are with driver only.
Truck
07 RCSB with SAP and tow package deleted.
12k class 4 hitch
16k 5th wheel hitch
3/4 tank of gas
Ride rite (Firestone) air bags (15# to achieve ride height equal to stock)
Rancho 9000xl adj. shocks (#7 setting)
Trailer
05 Aljo 2605 27' 5th wheel
6440# factory Dry weight
940# factory Dry Pin weight
Full water and propane
Cat Scale weights
Ratings / Actual
Front axle truck 3900 / 2780
Rear axle truck 3950 / 3440
Gvwr truck 6600 / 6220
Gawr truck 7850 / 6220
Gcwr truck and tlr 14000 / 12260
Trailer axle 8000 / 6040
Pin weight ? / 1100
Trailer(tow rating) 8900 / 7140
It's amazing how fast the weight adds up when you're fully loaded and ready to go. After we camped for the weekend I stopped by the scales on my way home to see what the fully loaded trailer weighed. I found that since the fresh water tank was over the trailer axle and the gray and black water tanks were in front of the trailer axle, when the water transfered to the gray and black tanks it added about 150# to the pin weight. I also had a generator, bundle of fire wood, bike and BBQ box in the bed of the truck. These are maxed out weights in the camping mode. Although I've towed several travel trailers before, this is the 1st 5th wheel and what a difference. We had a storm blow through with some pretty strong cross winds and no sway at all. It was like the trailer was part of the truck.
Front axle truck 2780 (3900 rating)
Rear axle truck 3780 (3950 rating)
Gvw truck 6560 (6600 rating)
Trailer axle 6180 (8000 rating)
Pin weight 1340 (? rating)
Trailer 7480 (8900 tow rating)
Gcw 12740 (14000 rating)
Old 03-24-2009, 09:59 PM
Truck
12k class 4 hitch
16k 5th wheel hitch
3/4 tank of gas
Trailer
Cat Scale weights
Ratings / Actual
Pin weight ? / 1100
I would have thought that you would have been over your GAWR of 3950..
What is "SAP" ?
Well, I do find these sort of reports encouraging..
Rex
Old 03-25-2009, 07:44 AM
mudfuel07's Avatar
Dealer : Gatorland Toyota Scion
- Other - 07 Mako 29RLFW,
2007 Toyota FJ Cruiser The Wifey's
Last Online: Today 05:52 PM
Images: 18
mudfuel07 has blessed us with their presence. mudfuel07 has blessed us with their presence. mudfuel07 has blessed us with their presence.
mudfuel07's Photo Albums
SAP=sport appearence package
Take a look at what I tow behind mine, I'm probably overweight with mine, but I've had no issues towing it.
Pulling Mako 29RLFW 5'er
Old 03-25-2009, 10:02 AM
Moderator
Dealer : Performance Toyota
2008 Toyota Tundra Slate SR5 4x4,
2005 Toyota Sienna XLE
Last Online: Today 07:07 AM
Images: 23
tomhole's Photo Albums
Mako 29RLF:
Dry weight: 8164 lbs
GVWR: 11,510 lbs
Dry Hitch weight: 1350 lbs
Your probably way overweight.
Tom
