Go Back   Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Towing
Old 03-22-2009, 02:02 PM
Dealer : Germain Toyota Scion of Sarasota
2003 Toyota Tundra,
2003 Toyota Camry
Last Online: 08-29-2009 06:37 PM
kingbert99 is on a distinguished road.
kingbert99's Photo Albums
Default Suspension replacement for towing
Hey gang,
I've got an '03 2WD access cab Tundra with TRD pkg and stock bilsteins. Truck's got about 70k miles and started towing a 20' toy hauler last year. I'm starting to suspect my shocks are failing due to the bouncing I get on highway and city bumps.
I'm looking for a few things:
1) Advice on how to tell if the shocks need replacement
2) Recommendations on what to get if they need replaced
3) Value in adding air bags to the new set-up if needed
Since this deals with towing and suspension, I didn't know which forum it should go under. Please point me in the right direction if I need to re-post!
Thanks,
KB99
Old 03-22-2009, 02:45 PM
Moderator
Dealer : Performance Toyota
2008 Toyota Tundra Slate SR5 4x4,
2005 Toyota Sienna XLE
Last Online: Yesterday 09:01 AM
Images: 23
tomhole's Photo Albums
Default Re: Suspension replacement for towing
KB,
Do you use a weight distribution hitch with your trailer?
Tom
Old 03-22-2009, 08:19 PM
2003 Toyota Tundra,
2003 Toyota Camry
Tom,
I do. I have a WD/Swaybar combo unit whose brandname escapes me at the moment. I have the hitch set up pretty well now (it took some tweaking) but intend on making a trip to the scales in two weeks just to be sure.
For some reason I feel like I'm committing a minor crime asking about air rides when I have a WD hitch, but this forum is the best source of knowledge for someone to set me straight before I get in over my head and waste time/money.
So, long answer to your question is, "yes...I use a weight distribution hitch."
Old 03-22-2009, 09:50 PM
Moderator
Images: 23
Excellent. Then you are looking to add airbags for the exact same reason I added them to my 2005 and now my 2008 Tundras. You could just add the Rancho RS9000 adjustable shocks. That might be just the ticket for your situation.
If you do decide to add bags, they are easy to install and will accomplish what you desire: less bouncies. I would also recommend LT tires vs. P rated. That helps a lot. And keep those tire pressures at max on the trailer.
Let us know what you decide.
Tom
Old 03-25-2009, 09:27 PM
2003 Toyota Tundra,
2003 Toyota Camry
I went online looking for the Ranchos and it looked like the RS9000s were only available in the rear for 4WD models. I've got a 2WD model -- can anyone confirm if they're limited one way or the other?
I just noticed that my profile says "lurking member." Wow. That's pretty ominous. I feel dirty now for some reason.
So back to the shocks...any love for a 2WD?
Old 04-02-2009, 03:34 PM
Dealer : Toyota of Temecula Valley
2007 Toyota Tundra,
2005 Scion xB,
2001 Toyota Tacoma XCab 4X4
Last Online: 11-05-2009 10:22 PM
svedspx is on a distinguished road.
svedspx's Photo Albums
The Rancho 9000xl's are available for the rear in both 2wd and 4wd. They are only available for the front in 4wd trucks. I've had a set on my RCSB 2wd for a year and a half and I'm happy with them. I started towing a 7200# 5th wheel and added airbags. The airbags and shocks make a good combo.
