Old 04-07-2009, 08:50 AM
Last Online: 11-01-2009 09:16 PM
Joker is on a distinguished road.
Joker's Photo Albums
Default 800 lbs tongue weight
Is 800 lbs too much for an 07 Tundra. Just towing about 15 miles?
Thanks
Old 04-07-2009, 12:51 PM
Moderator
Dealer : Performance Toyota
2008 Toyota Tundra Slate SR5 4x4,
2005 Toyota Sienna XLE
Last Online: Today 07:07 AM
Images: 23
tomhole's Photo Albums
Default Re: 800 lbs tongue weight
For 15 miles, you should be fine. Is it a one time tow? Also, use the square 2" receiver, not a ball in the bumper.
Watch out for stopping as well. With that much hitch weight it must be a heavy trailer. If it has brakes, use them. If not, be careful.
If you plan to do this regularly, we'll have to talk more.
Tom
Old 04-07-2009, 01:50 PM
Towing 15 miles to the race track and 15 back. I am going to get a prodigy controller as well which I see is recommended for the Tundra
Old 04-07-2009, 05:26 PM
jdubh's Avatar
Dealer : Bert Wolfe Toyota
2008 Toyota Tacoma,
2008 Toyota Tundra Limited 4x4 DC BlueS,
- Other - 2005 Accord EX-L
Last Online: Today 03:48 PM
Images: 10
jdubh will become famous soon enough.
jdubh's Photo Albums
If you have the 5.7 I know you could tow it cross country as my trailer has a tongue weight of 950lbs and I go everywhere with it.
2008 Blue Streak Metallic Double Cab 4x4 Limited 5.7L
2009 Outback 310BHS Sydney Edition 10,060lbs 35'10"
Prodigy, Retrax, Equal-i-zer, Load Lifter 5000
Old 04-08-2009, 12:36 AM
Moderator
Images: 23
And you are using a WDH. That makes all the difference in the world. I just towed the camper home without the WDH engaged. Hitch weight is 750 lbs. The headlights were pointed at the sky. Dangerous way to tow for any length of time or frequency.
For the OP, if you plan to tow this load more than once, think about adding a WDH to level the load.
Tom
Old 04-09-2009, 04:36 PM
jdubh's Avatar
2008 Toyota Tacoma,
Images: 10
Tom
Of course, it says right on the hitch that if you tow anything with over 500lbs of tongue weight then you must use WDH. But even at 1000lbs tows fine for miles.
Old 04-17-2009, 11:29 PM
2008 Toyota Tundra,
1993 Toyota Truck
Last Online: 07-18-2009 12:02 PM
troyota71 is on a distinguished road.
troyota71's Photo Albums
hey fellas you talk about a" WDH" when towing with heavy tongue weight,what is a WDH? Please
Old 04-18-2009, 11:59 AM
Moderator
Images: 23
WDH= Weight Distribution Hitch.
This is a Reese Dual Cam:
This is an Eaul-i-zer:
Bith are high quality and work well.
Tom
Old 04-26-2009, 08:35 PM
Dealer : North Park Toyota of San Antonio
Last Online: 04-27-2009 11:12 PM
MarkM7208 is on a distinguished road.
MarkM7208's Photo Albums My eBay
I have an equalizer hitch for my TT, but this was the first time with it on my new TT which is a tiberlodge 30sky. The Rv center hooked up the hitch for me but still feel it is not correct. Had rough time pulling this weekend with the wind, kept bucking me all around, had to keep the TT at 55 or so to stay under control. Jdubh are you using any other sway control with yours just curious, my unit is 12'5" at the rear so I catch alot of wind. I still think the Tundra is still sitting too low in the rear, but not sure. Would like any thoughts from anyone on this.
Old 04-26-2009, 09:38 PM
2005 Toyota Tacoma
Last Online: 10-16-2009 01:27 PM
droolingmess is on a distinguished road.
droolingmess's Photo Albums
If you have the correct weight capacity WDH and have it adjusted correctly the back of your truck should not be down at all. Are you adding weight to the bed of the truck after you already have the trailer hooked up?
Old 04-27-2009, 09:48 AM
No, not putting anything else back there, the WDH is rated for 10K and I have gone through the setup process again, but something just doesn't seem right. The TT weighs just over 8k with everything in it, I'm curious if with the equilizer you need to be one size bigger than what you are towing. This unit came off of my older RV that weighed only 4900K and I was pulling it with my 05 Tundra Access cab and never had these problems.
Old 04-27-2009, 08:25 PM
2005 Toyota Tacoma
The spring bars for your hitch might be 1000 lb bars. That is what I use for my 21" trailer with 350 lbs tongue weight. At 800 lbs tongue weight you may need to get 2000 lb bars. Don't know if your ball mount will accept heavier bars though. Some hitches use a different ball mount for heavier bars.
Old 04-27-2009, 11:03 PM
Well I talked with Equalizer today about the issue, and they suggested that I lift up the L brackets one hole at a time and see if it helps out, or I can take apart the hole assembly and add another washer which both will result in the same effect. They told me that through the different dealerships have told them that actually setting them up per the instructions was not the case and it was better to increase the amount of height above the hitch in order to give the correct amount of lift. The spring bars are not the case according to them.
Old 04-28-2009, 02:23 AM
Only Toyota for me's Avatar
Dealer : Karl Malone Toyota
2008 Scion tC Daughter's car
Last Online: Today 03:00 AM
Images: 44
Only Toyota for me will become famous soon enough.
From what i remember, lifting the L brackets are a slight difference and the number of washers are a big difference in distribution. So if you need a lot of extra support, put another washer or two in. If minimal support is needed, then adjust the L brackets.
This is just from what i remember, years ago when i had a TT. Got a 5er now, so i don't need to mess with the bars.
