Go Back   Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Towing
Old 04-30-2009, 12:52 PM
Dealer : Acton Toyota of Littleton
Last Online: 10-28-2009 03:57 PM
Images: 4
redbullguy is on a distinguished road.
redbullguy's Photo Albums
Default What's the best WD hitch set-up?
07 CrewMax 4x4 5.7l tow package towing 980lbs hitch weight, 7200lbs loaded 32ft travel trailer.
New to this whole thing and you guys seem to have some good info..
Thanks
Old 04-30-2009, 12:58 PM
mxsjw's Avatar
Jedi Ninja in Training
Dealer : Toyota of Puyallup
- Other - 2003 VW Passat,
Images: 10
mxsjw's Photo Albums
Default Re: What's the best WD hitch set-up?
Gonna be moving this on over to the towing forum.
The guys that tow day in and day out hang over there.
Beer please!
Old 04-30-2009, 02:27 PM
2005 Toyota Tacoma
Last Online: 10-16-2009 01:27 PM
droolingmess is on a distinguished road.
droolingmess's Photo Albums
Basically they all do the same thing though some combine sway control. Get what works best for you, fancy isn't always best. Really just depends on how much money you want to spend, how often you are going to tow and the conditions you will normally tow under. As for best that's really just a matter of opinion. My set-up, Prodigy P3 brake control, stock Toyota receiver, Husky 1000 lb WDH and sway control and by Monday Airlift Ride Control 59500.
Old 04-30-2009, 09:10 PM
Moderator
Dealer : Performance Toyota
2008 Toyota Tundra Slate SR5 4x4,
2005 Toyota Sienna XLE
Last Online: Yesterday 09:01 AM
Images: 23
tomhole's Photo Albums
Reese Dual Cam with 1200 lbs bars or Equal-i-zer with 1,000 lbs bars. Nothing fancy, just flat out work.
Tom
Old 05-06-2009, 03:31 PM
Dealer : Frontier Toyota
2005 Toyota Tacoma
Last Online: 08-18-2009 10:16 PM
markks2000 is on a distinguished road.
markks2000's Photo Albums
If you want the best give ProPride a call: ProPride 3P Trailer Sway Control Hitch for safety while towing I run a ProPride and it is amazing! I used to use an Equal-i-zer, and it was great with a smaller (21') trailer and my Tacoma, but wouldn't handle my new trailer. I stepped up to the ProPride because I didn't want to buy a new truck. The ProPride works as advertised and controlled the trailer. But I still didn't feel safe towing a large trailer with the Tacoma. So here I am with a 2008 Crew Max.
For a brake controller, I recently changed out my Prodigy with a TruControl Gold. That thing is fantastic!
Markk
Old 05-08-2009, 03:14 PM
jdubh's Avatar
Dealer : Bert Wolfe Toyota
2008 Toyota Tacoma,
2008 Toyota Tundra Limited 4x4 DC BlueS,
- Other - 2005 Accord EX-L
Last Online: Today 01:57 AM
Images: 9
jdubh is on a distinguished road.
jdubh's Photo Albums
I have the prodigy p3 and the Equal-i-zer 12K. No problems with sway, distributes weight properly, paid $300 shipped for it.
2008 Blue Streak Metallic Double Cab 4x4 Limited 5.7L
2009 Outback 310BHS Sydney Edition 10,060lbs 35'10"
Prodigy, Retrax, Equal-i-zer, Load Lifter 5000
Old 05-15-2009, 11:25 AM
Dealer : Mountain States Toyota
Last Online: 11-06-2009 05:57 PM
kt001 is on a distinguished road.
kt001's Photo Albums
I think they are all pretty much the same. I have an Equalizer WDH. The sway control is "bult in" so there is nothing more to add on when hooking up the trailer. Be sure to get a WDH that is rated for your trailer weight.
Look on the internet to buy a WDH. You can probably find one for $200-300+ cheaper than one at your local RV dealer, even after paying for shipping.
Old 05-24-2009, 05:44 PM
Geodude's Avatar
Dealer : Bel-Air Lexus Toyota
2001 Toyota Sequoia,
2001 Toyota RAV4
Last Online: Yesterday 09:00 AM
Geodude is on a distinguished road.
Geodude's Photo Albums
Check out the Hensley Arrow - the top of the line towing system for no sway, and weight distribution. The ProPride is more or less the same thing. The original designer of the Hensley and another guy split off and have apparently made some improvements.
Both work on the same principle and I'm sure either would give you the best towing experience possible. I have more info on my Hensley Arrow on my web site. JD and Beastlet here on TS is installing a ProPride today, so he might be worth asking as well.
2001 Toyota Sequoia SR-5 4WD
2001 Toyota Rav4
2005 Starcraft Antigua 305QBS travel trailer
Our Excellent Camping Adventures!
Old 05-24-2009, 07:58 PM
TundraBay's Avatar
Dealer : Wayne Toyota
2007 Toyota Tundra,
Last Online: Yesterday 10:00 PM
TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One.
TundraBay's Photo Albums
For a couple of years we used the Equal-i-zer on a 4,500 lb 24' trailer behind my wife's Acura MDX. (We were right on rated capacity). It tracked very true, never had the tiniest bit of sway, and rode dead level at all times, regardless of (over)loading.
Then I read in the MDX handbook that they didn't allow WDH at all. It was time for a bigger trailer anyway
[Tundra Bay]
Proud Member CBTMA
Radiant Red
Old 05-26-2009, 11:12 AM
JD and Beastlet's Avatar
2005 Toyota Sequoia Limited 4x4
Last Online: 11-04-2009 12:54 PM
JD and Beastlet is on a distinguished road.
JD and Beastlet's Photo Albums
Speak of the ...
Yes, I did the install Sunday. Here she is in all her glory:
I haven't written it up on my website yet but I did document the installation in nearly 100 pictures (with comments).
Like the Hensley, the ProPride 3P eliminates sway instead of attempting to control it through friction. We were running with an Equal-i-zer 1k/10k before but with the relatively short wheelbase of the Sequoia with a 30" trailer the ProPride was a logical upgrade.
And no, they are not cheap. :P
Old 05-27-2009, 10:23 AM
Dealer : Copeland Toyota
Last Online: 11-06-2009 07:32 AM
Images: 7
1jeep is on a distinguished road.
1jeep's Photo Albums
another vote for the reese dual cam HP, had it for a few years and it has been good to me.
I am sure the hensley is a good setup, but a little on the high end of the price scale for me.
old 2007 Tundra DC 8' bed 5.7 4x4
new 2008 ford f350 oil burner
Old 05-29-2009, 09:35 PM
Flyguy108's Avatar
Dealer : Bondys Toyota
2008 Toyota Tundra Desert Sand Mica,
1999 Toyota Sienna Sable Pearl
Last Online: Yesterday 03:02 PM
Flyguy108 is on a distinguished road.
Flyguy108's Photo Albums
Post Deleted
2008 Toyota Tundra 5.7 Crew Max
2008 Keystone Passport 280BH
Curt 1000/10000 WDH
Prodigy P3 Brake Controller
Friction Sway Control
Old 07-22-2009, 02:57 PM
Now I have! Check out my 3P page for installation procedure and towing reports.
But then, neither is your rig. And the precious cargo in the seats of the tow vehicle... priceless.
2008 Starcraft ST 2700BH behind 2005 Toyota Sequoia Limited 4x4.
Linked by ProPride 3P 1400, stopped by Prodigy, guided by Garmin nüvi 760.
2006 Fleetwood Sun Valley - sold March 2009 / 2006 Dodge Caravan - traded April 2008
Old 09-03-2009, 10:36 AM
Dealer : Toyota of Whittier
Last Online: 10-20-2009 10:05 PM
Rex Wayne is on a distinguished road.
Rex Wayne's Photo Albums
To each his own ... I looked at the install pics (nice job of taking pics, by the way) of that .. apparatus.. wow ..
The name "Rube Goldberg" comes to mind.
My unqualified opinion is that it is overkill .. to the extreme .. but hey, it's your money..
And if I had spent that much on a trailer hitch, I too would sing it's praises to any and all, every chance I got.
But, best of good luck to you..
And of course I could be completely wrong ...
Rex
Old 09-06-2009, 09:00 PM
2008 Toyota Tundra DCLB
Last Online: Yesterday 05:46 PM
Images: 16
nomadic is on a distinguished road.
nomadic's Photo Albums
that hitch is way cool and way way expensive, it is about double of an air ride one, i run with a normal sway control on the tool trailer and as long as a load it right i get no sway. i was driving in Georgia today and even had a hard time making the trailer sway. i think a large part of sway control is how you load the trailer.
2008 DCLB work truck, diamond plate running boards , Firestone air bags
95 civic HB b18c1 “built” toy
I’m in your town or will be soon…
