Old 04-30-2009, 01:49 PM
Last Online: 05-03-2009 08:58 AM
rbkeeney is on a distinguished road.
rbkeeney's Photo Albums
Default Class III extension wobble
I have a class III hitch on my RV right below the spare tire. I put an extension on so the I can easily attach by Hoveround carrier. The extension and the carrier both wobble. How can I tighten these receivers to remove the wobble?
Thanks.
Old 05-01-2009, 01:44 PM
Dealer : Mark Miller Toyota
2007 Toyota Tacoma
Last Online: Yesterday 10:05 AM
Corban_White is on a distinguished road.
Corban_White's Photo Albums
Default Re: Class III extension wobble
Either attach some tie downs from the corners of the carrier to the bumper/frame/whatever you can find or you can shim the receivers so they are tight. Soda/beer cans cut up and wrapped around the 2" square work well for this. IMO the tie downs will be a better solution tho.
Old 05-01-2009, 04:51 PM
Moderator
Dealer : Performance Toyota
2008 Toyota Tundra Slate SR5 4x4,
2005 Toyota Sienna XLE
Last Online: Today 07:07 AM
Images: 23
tomhole's Photo Albums
Is your RV a Class A or a trailer?
Tom
Old 05-03-2009, 08:58 AM
I have a class C RV. I was thinking of using wooden shims. If they work out then I do not have metal on the road.
Old 05-07-2009, 10:19 PM
TundraBay's Avatar
Dealer : Wayne Toyota
2007 Toyota Tundra,
Last Online: 11-16-2009 10:10 PM
TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One.
TundraBay's Photo Albums
similar problem with bikes on a front mounted rack easily solved by using bungies to the brush bar / bumper assembly.
[Tundra Bay]
Proud Member CBTMA
Radiant Red
