Go Back   Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Towing
Old 05-03-2009, 04:10 PM
Last Online: 06-06-2009 12:04 PM
JLinder is on a distinguished road.
JLinder's Photo Albums
Default Help w/ equal-i-zer setup
I have a 08 DC 4x4 and a Jayco 27BH. I'm trying to get my hitch set right, and moving the L brackets down 1 hole does nothing, and the next hole up I'm worried might be to much. I weighed the truck w/ trailer, these are the weights:
Loaded w/bars on
FA 3300#
RA 3300#
Both Axles 6700# (don't ask me why it's different)
Loaded w/no bars
3100#
3700#
Both Axles 6800#
For what it's worth the trailer weighs 5150# on the axles w/ full fresh water but none of our stuff.
Am I transferring more weight than I should be, or does that look about right?
2008 Tundra DC SR5 4x4 5.7 TRD
Old 05-04-2009, 12:39 PM
Moderator
Dealer : Performance Toyota
2008 Toyota Tundra Slate SR5 4x4,
2005 Toyota Sienna XLE
Last Online: Yesterday 09:01 AM
Images: 23
tomhole's Photo Albums
Default Re: Help w/ equal-i-zer setup
Looks good to me.
Tom
Old 05-08-2009, 03:11 PM
jdubh's Avatar
Dealer : Bert Wolfe Toyota
2008 Toyota Tacoma,
2008 Toyota Tundra Limited 4x4 DC BlueS,
- Other - 2005 Accord EX-L
Last Online: Today 01:57 AM
Images: 9
jdubh is on a distinguished road.
jdubh's Photo Albums
Loaded w/bars on
FA 3300#
RA 3300#
Loaded w/no bars
3100#
3700#
Both Axles 6800#
Forget the L brackets, put them at the starting position that the manual suggests. Throw in 8 washers on the stop that goes against the hitch. That made the biggest difference for me. Weigh your axles without the trailer to use as a starting point. Then when you put the bars on you should see an almost equal amount of weight go to each axle. So if your hitch is 600lbs then 300 should go to each. I have set it up before and put more weight on the front axles than the back...you want it even. If you put a piece of tape above your wheels you can measure the drop in inches and it should be equal.
2008 Blue Streak Metallic Double Cab 4x4 Limited 5.7L
2009 Outback 310BHS Sydney Edition 10,060lbs 35'10"
Prodigy, Retrax, Equal-i-zer, Load Lifter 5000
