Old 05-21-2009, 01:19 AM
Imdone's Avatar
2004 Toyota 4Runner,
Last Online: 10-31-2009 02:18 PM
Images: 23
Imdone is a splendid one to behold. Imdone is a splendid one to behold.
Imdone's Photo Albums My eBay
Default Hitch install
Class lll Hitch Install... (patent pending..)
Wouldn't you love to see how the trip went...? Good chance he ended up doin' some unintended off roadin' somewhere. Check the 'hills' in the background. Howja like to meet this rig on a two-lane road....coming down the mountain in your direction...?
She's hitched up and r eady to roll!! Amazin' how the extra weight smoothes out the ride.
Needed to air up the rear tires a bit ('bout 160 psi).
Added some super heavy-duty chain for extra support on the tailgate, (note the 'Heavy-Duty 'S' hooks to attach the chain) Also paid-up for some BIG Number 5/16 sheet metal screws to attach the Reese hitch frame to the tailgate (see 'em there? one on each side...) Likely two more through the carpet into the floor pan inside....
Yep, probably overkill, but didn't want the possibility of having an axerdent.
Most of the time was spent on the front porch whittling down that MASSIVE solid pine 4x4 to fit precisely down into the hole in the ball mount receiver.
Note also - The 14'x14' piece of 3/8' plywood on the underside of the tailgate to distribute the load more evenly and beef up that tailgate support.
'A MAN CAN'T BE TOO SAFE'...!!
RBP, ICON, CAMBURG, ALCAN, AMP RESEARCH, TOYO, ECLIPSE, SAVV, FOSGATE, KICKER, JL AUDIO, V-LEDS, PIAA, HELLA, MBRP, UNICHIP, TIMBREN, HYPERTECH
Old 05-21-2009, 09:12 PM
wolfie410's Avatar
Dealer : Darcars Toyota of Frederick
Last Online: Today 10:30 AM
wolfie410 is on a distinguished road.
Send a message via MSN to wolfie410 wolfie410's Photo Albums
Default Re: Hitch install
Nice...there isn't a single weak point in that setup.
Old 05-21-2009, 09:29 PM
TundraBay's Avatar
Dealer : Wayne Toyota
2007 Toyota Tundra,
Last Online: 11-16-2009 10:10 PM
TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One.
TundraBay's Photo Albums
how the hell does he steer that thing?
Hmm I wonder if this is how the guys on RV.net feel when I describe my Tundra with 5th wheel? Sort of similar creepy-crawly feeling that this story doesn't have a good ending?
[Tundra Bay]
Proud Member CBTMA
Radiant Red
Old 05-22-2009, 06:47 PM
Dealer : Toyota of Temecula Valley
2007 Toyota Tundra,
2005 Scion xB,
2001 Toyota Tacoma XCab 4X4
Last Online: Today 11:20 AM
svedspx is on a distinguished road.
svedspx's Photo Albums
I think you're right Tundrabay. This is not the first time I've seen pics of that tailgate setup. I believe I saw that set up over at RV.net used as a reference to the Tundra's towing capabilities.
Old 05-23-2009, 04:05 PM
Highwaylizard's Avatar
Dealer : Butler Toyota Scion
2004 Toyota Tundra Limited DC 4.7 4spd
Last Online: 11-17-2009 06:13 PM
Images: 64
Highwaylizard is a name known to all. Highwaylizard is a name known to all. Highwaylizard is a name known to all. Highwaylizard is a name known to all. Highwaylizard is a name known to all. Highwaylizard is a name known to all. Highwaylizard is a name known to all.
Highwaylizard's Photo Albums
Very astute observation and I must agree that all the weak points on that set-up are created equally - some are more equal than others.
I am not sure if this should be in the "You might be a redneck" thread or if it should be part of the Darwin Awards.
Crazy.
Highwaylizard 2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, self designed cold air intake using ram air principle, Fitch Fuel Catalyst, Aero Turbine, "Foolie Exhaust" from Aero Turbine back, True Flow Intake with True Flow foam filter, Mobile 1 in the engine, K&N oil filter, Royal Purple in the differentials. 3:91 gears in the front (Thanks Cajuntundra!) and rear (Thanks Nytrousboy!) differentials, Toyo H/T Open Country tires.
testis amotio per pera
150,620miles on the odometer Tundra Fuel Economy Blog
19+ MPG on the Highway at 75 MPH in a DC with a four speed automatic and a bad O2 sensor - not too shabby!
