Go Back   Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Towing
Old 05-26-2009, 11:25 AM
crah's Avatar
Dealer : Desert Toyota of Las Vegas
Last Online: 10-30-2009 02:05 AM
crah is on a distinguished road.
crah's Photo Albums
Default Nitto Terra E-Rated and Towing 5er
I just towed for the first time with the new E-Rated Nitto Terra Grapplers. Previous towing has been with the Michelin stock P rated tires. I have air bags also at 20 pounds.
55 psi in the rear, 45 psi in the front. Trailer listed dry weight is approx. 7500 pounds and I add about 1000 pounds at the max to the trailer, and no water in the holding tanks. Hitch weight is listed at 1,540 and only my wife and I in the truck with 3 little dogs at 15 pounds each.
The truck definitely handles the bumps much better over bridges. Side to side movement seems to be an issue, and the combined package seems to be more sensitive to the crosswinds compared to the P rated tires. I like the feeling of the P-rated tires better besides the bumps.
Do you think I have too much air in the tires? Will a sway bar help drastically? I don't want to lower the air pressure too much with the weight I'm pulling, and I know other guys are pulling with more air than me. Maybe 40 in the front and 45 in the rear. Let me know what you think.
2007 DC 4x2 5.7 SR5
Old 05-26-2009, 11:31 AM
mudfuel07's Avatar
Dealer : Gatorland Toyota Scion
- Other - 07 Mako 29RLFW,
2007 Toyota FJ Cruiser The Wifey's
Last Online: Today 11:22 AM
Images: 18
mudfuel07 is a splendid one to behold. mudfuel07 is a splendid one to behold.
mudfuel07's Photo Albums
Default Re: Nitto Terra E-Rated and Towing 5er
What size Nitto's do you have? I'm running 285/65R20 BFG's on my truck adn I air them all the way up(80psi) and don't notice any sway more than normal. I would think when you are towing, I would increase the air in your tires and that should help with the sway.
Pulling Mako 29RLFW 5'er
Old 05-26-2009, 11:42 AM
crah's Avatar
crah's Photo Albums
I have the 285/65R18 E rated. When it's unloaded, and I have the tire pressure at 50 front 50 rear, the truck sways way too much for my comfort. That's why I thought maybe it's due to too much air. When I first had the tires installed, they had the pressure at 65 psi all around, and that was dangerous. When I went around a bend in the road (at the usual speed), my VCS kicked on and I felt out of control. This was the same feeling on the freeway changing lanes. Any other comments or suggestions are welcome.
2007 DC 4x2 5.7 SR5
Old 05-26-2009, 10:50 PM
Only Toyota for me's Avatar
Dealer : Karl Malone Toyota
2008 Scion tC Daughter's car
Last Online: Yesterday 02:28 AM
Images: 44
Only Toyota for me will become famous soon enough.
You're running pretty close to what i'm running while towing. I run 60 rear and 45-50 front with my E rated goodyear's. With my C rated cooper mudders, i run 50 all around, and i prefer the feel of the E rated tires while towing. Much more stable and secure than the mudders.
I would try running 55 all around while towing to see if that helps. I haven't heard too many good things about the grapplers, so i can't comment on their towing performance.
I would try that, and if that don't work i'd probably consider taking them back and swapping for a different brand.
No, i don't think you have too much air in them while towing. But i do think you do when empty. I run 40 front/32 rear empty, and it handles just fine.
The only thing i can think of that would be the difference is the fact you no longer have a pooch in the tire when loaded. Therefore, the new tires have less rolling resistance and the side to side motion you're feeling is your steering. Especially over bumps; if you're holding the steering wheel with your arm rested on the armrests it will cause you to steer slightly back and forth. The steering on these trucks is very sensitive this way. I particularly feel this motion more so when towing tandom though.
So, i don't know if that helped or not but..............this has been my experience.
Old 05-27-2009, 12:21 AM
crah's Avatar
crah's Photo Albums
I will try 55 PSI all around and see how that feels. Somehow, I don't think that's going to be the answer. The feeling is very similar when it's unloaded with higher tire PSI. 40 PSI all around when unloaded feels very similar to the former P rated tires, but as soon as I have 50psi unloaded the truck feels like it's swaying (fishtailing). The steering is more sensitive. Now with the 5er hooked up, I can feel when the big rigs pass more than witht he previous tires as well as the crosswinds. A little too much sway for my comfort. I will play with the air pressure a little bit, and if that doesn't work, I will try to swap out the tires. I can't believe this isn't more of a common problem. Maybe it's with the Nittos only.
2007 DC 4x2 5.7 SR5
Old 05-27-2009, 02:51 AM
Images: 44
I don't know if it is or not, but it's possible.
Like i said, i don't experience the swaying or fishtailing at all with my 5er. Mainly when i pull tandom, and i'm moving the steering wheel over bumps.
If you haven't seen a pic of my trailer, it's quite high off the ground and i can almost sit up straight while under it. I've since lifted it another inch, which was done after this shot was taken.
Old 05-27-2009, 10:13 AM
Dealer : Copeland Toyota
Last Online: 11-06-2009 07:32 AM
Images: 7
1jeep is on a distinguished road.
1jeep's Photo Albums
I would have the same VCS issue when i first put my tires on and it was due to having 65lbs in the rear tires. I dropped it down to 55 and it was better, i do run 65 rear and 60 front when towing. I dont think i have any need for 80lbs as i will not come close to the tires load rating.
old 2007 Tundra DC 8' bed 5.7 4x4
new 2008 ford f350 oil burner
Old 05-27-2009, 10:38 AM
crah's Avatar
crah's Photo Albums
Do you have the Nitto Grapplers also? I think I figured out the unloaded part on the PSI, but the loaded is still a problem.
Like I mentioned, the side to side movement when towing is much more than what I had before the Nittos.
2007 DC 4x2 5.7 SR5
Old 05-27-2009, 10:43 AM
crah's Avatar
crah's Photo Albums
No problem. I'm just trying to figure this one out. A sway bar would probably help me out a lot also, and my trailer is a little unlevel, but it was that way with the old tires too. I'm sure it's a combination, but I will figure it out this weekend.
Thanks for the help.
2007 DC 4x2 5.7 SR5
Images: 7
Toyo open country AT 275/65 18 E rated and they are much firmer than the previous C rated tires i had.
What pressure did you have when towing? Any E rated tire should be more stable than P unless you went with some mud tires then the blocks would cause an issue.
Old 05-27-2009, 12:12 PM
Dealer : Toyota of Temecula Valley
2007 Toyota Tundra,
2005 Scion xB,
2001 Toyota Tacoma XCab 4X4
Last Online: 11-05-2009 10:22 PM
svedspx is on a distinguished road.
svedspx's Photo Albums
I have the Hankook RF10 E load in stock 18 size and I had the same problem. Front end felt loose and wind had more effect than I expected. Took me a couple of weeks to figure it out. I ended up changing the pressures to 38 front 39 rear when unloaded and 39 front and 50 rear when the fifth wheel is in tow. My pin weight is lighter (1300#) than yours. When weighing the set up I found that only 40# was transfered to the front axle so I keep the front pressure about the same, maybe a pound or two more. Others have found that no weight is transfered to the front when the fifth wheel is loaded. Keeping the front pressures lower was the key for me to get about the same handling as the old Pmetric tires. Good luck.
Old 05-27-2009, 06:38 PM
crah's Avatar
crah's Photo Albums
I think you pretty much summed up what I wanted to hear. I have a long trip over the weekend and will adjust the air pressure to see if it helps.
Thanks for the confirmation. It looks like some tires are more subseptible to this problem than others.
2007 DC 4x2 5.7 SR5
Old 05-27-2009, 06:43 PM
crah's Avatar
crah's Photo Albums
My first post has all the air pressures loaded and unloaded. I noticed that you have the 8' box. Maybe that makes a difference also. If I ran your pressure when unloaded, I would still float everywhere on the highway. 40psi all around seems to staybilize things when unloaded.
2007 DC 4x2 5.7 SR5
Old 05-27-2009, 08:37 PM
Images: 44
Interesting...............Thanks for sharing.
I've always run the fronts higher when towing, but maybe next trip i'll try your approach.
Old 05-28-2009, 02:13 AM
TundraBay's Avatar
Dealer : Wayne Toyota
2007 Toyota Tundra,
Last Online: Today 10:27 AM
TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One.
TundraBay's Photo Albums
Maybe I'm just ham-fisted, and don't feel what's going on, but the BFGs T/A KO's seem to not change much in terms of handling whether I'm running 40 or 55 PSI.
I keep changing a little bit by bit to see if there is a sweet spot, where it feels "perfect" and 40 front whether towing or not, 38 rear empty/ 50 towing seems to be about as good as it gets. The only time vsc and so on kicks in is if my foot develops a bit of lead in it, that can make the tail a bit squirrely, otherwise not so much.
[Tundra Bay]
Proud Member CBTMA
Radiant Red
