Go Back   Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Towing
Old 06-02-2009, 07:18 PM
Dealer : Fremont Toyota Scion
2003 Toyota Tundra
Last Online: 09-23-2009 11:56 AM
Molon labe is on a distinguished road.
Molon labe's Photo Albums
Default Another sway control Question
I have a 2003 SR5 Tundra with tow package. I am pulling a 2005 Rockwood Ulta lite Model 2605. it has a dry weight of around 4,600. I am using a Husky WDH with 1000 # bars. I just bought it and it has this setup. The box length is about 24 feet with almost 4 feet of hitch. I want to put a sway control on it but only have a couple of hundred dollars to spend. What is my best bet. I am looking at camping worlds Reese friction type or the Huskey friction type is so cheap i could buy the right and left instead of just the one side as with the reese brand. Do I need a right and left? Any suggestions?
Old 06-02-2009, 07:56 PM
2005 Toyota Tacoma
Last Online: 10-16-2009 01:27 PM
droolingmess is on a distinguished road.
droolingmess's Photo Albums
Default Re: Another sway control Question
The only time I have seen 2 sway controls used is on 35' plus trailers and big heavy park models. Try one side first. Take it out on the highway and drive about 55. The traffic will be blowing past you and you will get a real good idea if you want two sway controls. Most likely you will just need to figure how much you need to tighten the one side and it will be enough.
Old 06-02-2009, 09:50 PM
2003 Toyota Tundra
Thanks droolingmess. Any suggestions on the Husky (Which is like 67 dollars) or the Reese brand which is 129.00 at Campingworld.
Old 06-02-2009, 10:10 PM
2005 Toyota Tacoma
I use a Husky that works fine for me. Both Eazlift and Reese are about twice as much as the Husky and best I can tell they do the exact same thing. Remember to clean your sway control with a wire brush between uses to keep is working 100%. You will probably see folks say never back up with the sway control on. Not always true. An easy way to check is to take your ball mount off the truck, then put it and the sway control on the trailer. Move the ball mount through a full range of motion and see if the ball for the sway control hits the coupler when full to one side. If it does you want to remove the sway control when making severely tight turns. If the the rear edge of the ball mount hits the coupler before the sway control ball don't bother to remove the sway control when backing or making tight turns.
Old 06-03-2009, 11:14 AM
Flyguy108's Avatar
Dealer : Bondys Toyota
2008 Toyota Tundra Desert Sand Mica,
1999 Toyota Sienna Sable Pearl
Last Online: Yesterday 03:02 PM
Flyguy108 is on a distinguished road.
Flyguy108's Photo Albums
Post Deleted
2008 Toyota Tundra 5.7 Crew Max
2008 Keystone Passport 280BH
Curt 1000/10000 WDH
Prodigy P3 Brake Controller
Friction Sway Control
Old 06-03-2009, 05:40 PM
Moderator
Dealer : Performance Toyota
2008 Toyota Tundra Slate SR5 4x4,
2005 Toyota Sienna XLE
Last Online: Yesterday 09:01 AM
Images: 23
tomhole's Photo Albums
What kind of bars do you have on that Husky? If they are trunion style, you can add a Reese Dual Cam HP to the setup for $169 and have one of the best sway control systems out there. I had the friction type (single) on my 25' trailer and it worked fine. Or so I thought. I put a Reese Dual Cam HP on it and the difference was very noticable. You're pushing the capability of the legacy Tundra with that trailer, spend the few extra quid and make it as safe as possible.
Tom
Hitch and Sway Bars Combination on Sale
Old 06-03-2009, 11:23 PM
2003 Toyota Tundra
Thanks Tom. The listed trailer weight is like 4,050 but i added the 600 #s for the stuff they add on like Ac and awning. i will look into the Reese Dual Cam but i think i have the type that is shaped like an L and u shove the short end from the bottom up into a round hole. Not sure if that made sense. I am taking it to the scales next Tuesday to see the truth.
Old 06-05-2009, 06:21 PM
The Raisin's Avatar
Dealer : Toyota of Puyallup
Last Online: 10-30-2009 12:09 AM
The Raisin is on a distinguished road.
The Raisin's Photo Albums
I run dual sways on mine. I have a 26' TT. I am using the E-Z lift style sway controls.
Mark
07 Tundra 5.7 DC Radiant Red
2" leveling kit 275/70-18 Toyo MT's
Firestone ride-rite airbags
Old 06-08-2009, 11:40 AM
Dealer : Power Toyota Irvine
2008 Toyota Tundra Silver CrewMax LTD
Last Online: 08-12-2009 05:19 PM
Images: 2
Finatik is on a distinguished road.
Finatik's Photo Albums
I used to use the friction control but went to the Reese Dual Cam and LOVE IT. While the friction control worked the difference was hugely noticable. Oncoming trucks - No sway. 70 mph - no problem. Feels super tight and I don't have to crank the thing down. Just set it up like a normal WDH and off you go. It's well worth it IMO.
2008 Crewmax LTD - Metallic Silver
JBL Nav, Full tint, Back Up Camera, Paragon Bed Cover, Sport Pedals Sun Roof, Duel Sony Video Headrest system.
Towing: Tekonsha P3 controller, Reese Dual Cam Sway system.
Next mod: Lockpick 2 for front video on nav
Old 06-09-2009, 09:02 AM
Flyguy108's Avatar
Post Deleted
Curt 1000/10000 WDH
Old 06-10-2009, 12:34 AM
Sean Woodruff's Avatar
Dealer : Grand Blanc Toyota
Sean Woodruff is on a distinguished road.
Sean Woodruff's Photo Albums
I think the post above is correct. All the sway bars are made in China so there's really no reason to buy the branded version. After all, they are just steel plates.
Don't forget you have to loosen the tension on a sway bar in wet weather.
ProPride, Inc.
800-960-4767
www.ProPrideHitch.com
Old 06-10-2009, 11:55 PM
2003 Toyota Tundra
Wow thanks for the info guys. Sean i did not know about the wet weather and loosening the sway control friction. I put a friction controller on and it seems to work great. On a different note my WDH when all set up makes my rear end of my truck squat down about 3.5 inches. Should my trucks rear end sit at the same height when it is empty and when it has the trailer hooked up?
Old 06-11-2009, 12:10 AM
Flyguy108's Avatar
Post Deleted
Curt 1000/10000 WDH
Old 06-11-2009, 11:12 AM
2003 Toyota Tundra
Hey thanks flyguy those are great articles. i read them both and will tackle it today. Thanks again.
