Old 07-13-2009, 04:09 PM
Dealer : Lynch Motors
Last Online: 11-13-2009 10:29 PM
campertom is on a distinguished road.
campertom's Photo Albums
Default What can I do to get a smoother ride when towing?
I am towing a 34' trailer (2007 Crew Max SR5 w/tow package). Tongue weight is 1000lbs, front and rear axles are both well under max. GW is just under max. I use an Equilizer WDH, 1000lb bars. I have had no trouble with sway, and the ride is mostly comfortable. But, whenever I run into a rise or dip in the road, I get a bit of trampoline effect. The larger the bump, the larger the bounce. It is very unsettling, though never feeling at all like a loss in control. Looking in the rear view window, I see the trailer rocking front to back as it hits the bump, rocking two or three times after the bump, before settling down. In the truck, it is like being dropped onto a trampoline.
I'm thinking I should look into replacing my Tundra with a 3/4 ton truck, but before I go down that route, I wondered if there was anything that could be done with shocks, springs, tires, or anything else to lessen the bounce.
Old 07-13-2009, 04:47 PM
Dealer : Dublin Toyota Scion
2006 Lexus LS430
Last Online: Yesterday 06:29 PM
bbarada is on a distinguished road.
bbarada's Photo Albums
Default Re: What can I do to get a smoother ride when towing?
I recommend the Bilstein 5100 shocks. The fronts are adjustable, and I set them on the middle setting. The rears aren't adjustable. Really dampens out the pogo effect but doesn't make the ride any rougher.
2008 DCSB Limited 4X4, Slate metallic, 5.7, Line-X, Weathertech, TRD sway bar, debadged, Bilstein 5100's, bed extender, billet grill, Spintech muffler.
Old 07-13-2009, 05:18 PM
Jowett Engineering's Avatar
Preferred Dealer
Dealer : K-M Toyota
Last Online: Yesterday 10:36 PM
Images: 10
Jowett Engineering has much to be proud of. Jowett Engineering has much to be proud of. Jowett Engineering has much to be proud of. Jowett Engineering has much to be proud of.
Jowett Engineering's Photo Albums
I'll second the shock change. The wallow you get is mostly a result of the lack of rebound dampening in the rear shocks.
We dyno'd the stock Tundra TRD Bilsteins and found them to quite (overly IMO) stiff in compression, and decent on rebound. I'm guessing you don't have the TRD package?
Brian
Jowett Engineering
Extreme duty parts for the Tundra that works and plays.
Webpage coming soon!
2008 DC TRD Supercharged w/ AWD
Old 07-13-2009, 05:44 PM
Art64's Avatar
2007 Toyota Tundra RCSB5.7SR5WHTSports
Last Online: Yesterday 09:50 PM
Art64 will become famous soon enough.
Art64's Photo Albums
Rancho 9000XL adjustables have excellent rebound control. I have Firestone airbags and when the truck is not loaded, it gets a lot of kick-ups on dips and bumps. Tried Bilstein HD's but not enough rebound damping. Rides smooth, until you hit a dip, then the rear is airborne!
Old 07-13-2009, 05:51 PM
mxsjw's Avatar
Jedi Ninja in Training
Dealer : Toyota of Puyallup
- Other - 2003 VW Passat,
Images: 10
mxsjw's Photo Albums
Are you sure it's shock re-bound, or could it be "porpoising"?
You may need to re-set up your WD hitch, check the instructions that came with the hitch, or search the towing section of Tundra Solutions for advice.
Thread moving to towing.
Beer please!
Old 07-13-2009, 06:47 PM
2007dctundra4x4's Avatar
Dealer : Appleway Toyota
Last Online: Yesterday 10:34 PM
2007dctundra4x4 is on a distinguished road.
2007dctundra4x4's Photo Albums
firestone ride rite airbags are by far the best purchase i have made as far as towing is concerned...i tow a 32 foot travel trailer with a front kitchen so the tongue weight is also 1000+, and i also have the topper which isn't very light either, rear end does not drop at all
2007 DoubleCab Tundra TRD 4x4
Silver Sky
Sway-a-way Coliovers
Total Chaos UCA's
Mickey Thompson Baja ATZ 35x12.50x20
BMF Novacane wheels
SnugTop camper shell
Black headlight mod
Plated body mount
Kenwood DNX7100 Nav/ipod/backup camera
Old 07-13-2009, 07:23 PM
TundraBay's Avatar
Dealer : Wayne Toyota
2007 Toyota Tundra,
Last Online: 11-16-2009 10:10 PM
TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One.
TundraBay's Photo Albums
If he's got the SR5, does that imply TRD, or is only the Limited which pretty much automatically comes with TRD?
Anyway the other thought is maybe the Equalizer is set too high? That will tend to un-weight the rear end (have you weighed your rig?) and any upwards force for example from a bump will result in the rear end bouncing against the trailer weight. I'd definitely try a few different settings before totally giving up.
3/4 ton ride in my own experience was worse, whether loaded or empty.
[Tundra Bay]
Proud Member CBTMA
Radiant Red
Old 07-13-2009, 07:25 PM
Moderator
Dealer : Performance Toyota
2008 Toyota Tundra Slate SR5 4x4,
2005 Toyota Sienna XLE
Last Online: Yesterday 07:07 AM
Images: 23
tomhole's Photo Albums
I second the recommendation to check everything else first. Rear truck tires should be at max pressure. If you still have the P rated tires, replace them with LT tires. Make sure the trailer tires are at max pressure as well.
Next up is the WDH. How have you determined it is set up properly? Weights are the best, but measuring the wheel well drop before and after hitching up is good as well.
If all that is done, then I would add airbags. Or the Rancho adjustable shocks. 1,000 lbs is a lot of hitch weight well behind the axles, so they may need some help.
Tom
Old 07-13-2009, 09:28 PM
The weight distribution seems pretty good - both from the scales and the measured height. I haven't heard the term 'porpoising' before, and don't follow what the difference is between that and 'bounce'. My truck does not have the TRD package - standard suspension and springs for the tow package, whatever those are. I did add air lifts, and keep them at 20lbs while towing. I tried higher pressures, but that made the truck bounce (as opposed the the trailer bounce) worse.
So, recheck weights and WDH, make sure tire pressure on the trailer and truck are max, Rancho adjustable shocks, LT tires ... anything else?
Old 07-13-2009, 10:16 PM
I just ran into this definition of porpoising on an Airstream forum - suggesting that shocks are the right solution for that as well
Porpoising is a problem on concrete roads when the expansion joints are just far enough apart compared to your wheelbase and speed. The bounce from the joints is just right to reinforce the rig bounce as it goes down the road. Sometimes this porpoising can be reduced by removing spring bar tension on the hitch which allows it to be more flexible. A better solution would be to make sure that the spring bars and the tow vehicle axle springs are properly rated for their loads and to install good shock absorbers.
Old 07-13-2009, 10:55 PM
TundraBay's Avatar
2007 Toyota Tundra,
That's exactly what happens to me on a few concrete highways in Central Wisconsin with my 5th wheel! Usually I just slow down a bit and the problem goes away. (Maybe I'm overloaded?)
[Tundra Bay]
Proud Member CBTMA
Radiant Red
Old 07-14-2009, 01:32 PM
Sean Woodruff's Avatar
Dealer : Grand Blanc Toyota
Sean Woodruff is on a distinguished road.
Sean Woodruff's Photo Albums
Porpoising and bounce are the same thing. It is a weight distribution issue. Like someone above said, try resetting your hitch. Sometimes it is just a matter of fine tuning the entire wight distribution and it will go away.
ProPride, Inc.
800-960-4767
www.ProPrideHitch.com
Old 07-14-2009, 03:01 PM
cwit's Avatar
Dealer : New Country Toyota
2007 Toyota Tundra,
2006 Toyota Camry-Solara black moon roof
Last Online: Yesterday 04:03 PM
Images: 3
cwit is on a distinguished road.
cwit's Photo Albums My eBay
If you have airbags you can pretty much forget the shocks. I would say it's in your hitch. I would try less air in airbags It sounds like you may be bouncing on air. I have this problem if I put to much air in.
Charlie & Linda
Old 07-14-2009, 04:07 PM
TundraBay's Avatar
2007 Toyota Tundra,
I'm not sure of this cwit, because if there's inadequate damping on rebound (which I understand the non-TRD suspension may have) better shocks will slow down the bounce. I'd think what Jowett wrote makes sense. Although you are right in that too much air can make it feel like you are on something hard or non-compressible. Especially if there's very minimal effective hitch weight due to weight distribution.
[Tundra Bay]
Proud Member CBTMA
Radiant Red
Old 07-14-2009, 05:26 PM
I've played with the air bag pressure and hitch settings quite a bit. I know well what it feels like to have the air bags at too high a pressure.
In my opinion, the bounce begins when the trailer's back end rises on a bump, pushing the nose down and thereby pressing down on the truck. I expect this part of the effect is probably unavoidable, but the rebound bounces (after shocks) should be avoidable to some degree. I tend to agree that better shocks sound like they would smooth out the entire bounce experience.
I'm not even sure the air lifts were a good idea. The back end of the truck is far from being bottomed out. With WDH in place (and minimal pressure in the air lifts), the back end drop with a load is only about 1/2" lower than no load. After reading a bunch of other posts, I'm wondering if a set of super springs would have been a better choice than air lifts. It has occurred to me that my P rated tires (stock tires) could be part of the bounce problem. I'm thinking that I will try shocks first, then tires, then SuperSprings. My tongue weight should be a bit higher - I'm at 12% of total now. But, payload is a concern and limits there make it difficult to push the tongue weight higher on this (otherwise very capable) payload handicapped truck.
