Old 07-16-2009, 12:45 AM
Last Online: 07-24-2009 05:12 PM
dadofthree is on a distinguished road.
dadofthree's Photo Albums
Default Best place to install a brake controller?
I have a 2007 CrewMax SR5 and have to mount a Prodigy brake controller. I really want to mount it in the opening between the cigarette lighter and the 12V DC plug (see photo attached). If I drill a hole in the back of this opening, I'm not sure if I can get the wires snaked to the plug under the steering column. Has anyone out there done this? If so, I'd like to hear how it went. Otherwise, where else have you installed your brake controller? Thanks.
Old 07-16-2009, 10:16 AM
Default Re: Best place to install a brake controller?
By the way, the Prodigy controller fits very nice in this opening when using the cradle-type holder. I planned on using industrial double-sided tape to mount the cradle in the opening.
Old 07-16-2009, 11:30 AM
DaveGS4's Avatar
Dealer : Toyota Of Lake Norman
2009 Toyota Tundra SR5 DC 5.7 Slate
Last Online: Yesterday 06:58 PM
DaveGS4 will become famous soon enough. DaveGS4 will become famous soon enough.
DaveGS4's Photo Albums
Do3,
I'm posting a few links I had saved off from my install when I was researching that might be helpful for you below. Some of these are for the P3, but I found them helpful (even though I bought a prodigy myself).
Prodigy Brake Controller w/ connector install
P3 Install, Where did you cut?
installing a trailer brake controller
Tekonsha P3 Install in Crewmax
My wife, brother-in-law and I looked at putting ours in both the area you're considering and the spot pictured below and found the one where we ended up easier from a dash-removal & wiring stretch perspective. IMO its also more convenient to reach when you're driving which is an important factor for a brake controller.
We had to dremel a half-dime-sized area of the trim where it's installed (on the back side) to make sure the slider at the bottom wasn't constrained which we could have avoided if we wanted it to stick out a bit more. It fights tightly in the installed area and we were able to use side mounting screws that came with the Prodigy to secure it in the trim box when popped out of the dash.
Tow: 2009 Tundra DC SR5 5.7 Mods and Adds: Prodigy, under seat storage, Avic-F90BT Nav w/ HD module, backup camera, TRD 18w/ CrossContact LX e-rated,
glass break sensor, Homelink Mirror, Hardwired Valentine One w/ Blendmount, TRD rear sway, Valor tip, bed step, G4 tonneau Next: 35% tint, helper springs or bags
Haul 2008 Continental Cargo Enclosed Car Hauler 22ft V-nose, Reese WDH
Daily: 2005 Lexus LS430 Ultra-Luxury * PCS * ML * Rear Fridge * Massaging and Reclining Rear Seats * Vaistech SL-I * Coastal Lockpick
Track: 1998 BMW E36 M3/4 track car (wife's)
Float: Sea Ray 240 Sundeck
Old 07-16-2009, 01:30 PM
DaveGS4,
Thanks a bunch for the links and pictures. I figured someone else had to have done this. I have to learn how to use the search feature better on this forum. I serched, but nothing useful came up (my lack of search technique I'm sure). I'm going to tackle this project this weekend.
Old 07-16-2009, 01:41 PM
stevencrosbie's Avatar
NASH
Dealer : Dick Poe Toyota
2007 Toyota Tundra,
- Other -- 2001 Hyundai Elantra
Last Online: Today 12:33 AM
stevencrosbie is the One. stevencrosbie is the One. stevencrosbie is the One. stevencrosbie is the One. stevencrosbie is the One. stevencrosbie is the One. stevencrosbie is the One. stevencrosbie is the One. stevencrosbie is the One. stevencrosbie is the One. stevencrosbie is the One.
Send a message via AIM to stevencrosbie stevencrosbie's Photo Albums
Good luck. These controllers are awesome!
-Steve
2007 Toyota Tundra Crewmax Limited 5.7 2wd TRD White, Sonar, Cold kit, 20% tint, 3M Clearbra, XM Radio; N-fab Nerf Bars, Line-X, 275/70-18 Goodyear Wrangler Silent Armors
2007 Polaris Sportsman 700 EFI Best toy ever (Rear basket, front rack, hand guards, K&N filter)
http://truedelta.com/ Good alternative to Consumer Reports
CBTMA- Member
